Question about Nikon Coolpix 4300 Digital Camera
Why cf card format will not work? The message says the card cannot be used. I purchased a new card and it gives the same message. I am so sad. I have enjoyed this camera and I cannot afford to buy another one. any help would be appreciated.
    Champion:
  • 226 Answers
Hi msaalady, your camera have defective pin connector in CF housing or memory compression circuit damaged.
Please send to Nikon service
Regards
Posted on Mar 19, 2011
I took the CF card out of my Rebel XTi EOS camera to look at the pictures on my computer. When I put the CF card back in the camera I am getting the message "There is a problem with the CF card. ...
This is an old posting but I'd like to comment that once the memory card is used in a computer it won't read in the camera again until you format the memory card. Make sure you have all your pictures on the computer before formatting the memory card. A memory card must be formatted in the camera it is going to be used in.
Jan 01, 2011 | Canon EOS Rebel XSi Digital Camera
I have a Cannon EOS Digital Rebel Xti. When I try taking a picture, I keep getting an error message indicating there is a problem with the CF Card. I have replaced the card several time but keep getting...
What you require is to format the Compact Flash Card. The CF card should be formatted when new and after every download. Format the card in the camera it is going to be used it. Constantly deleting pictures on the memory card will cause major corruptions and total failure. Formatting cleans the memory and allows the camera to communicate properly with the CF Card.
I going to give you several diagrams on where to go in your camera to format. these diagrams are screen shots right from your manual.
Dec 29, 2010 | Canon Rebel XT / EOS 350D Digital Camera
I installed a new cf card in my canon camera. It says "card not formatted" and when I try to format it, it says "cannot format. change CF card". what gives?
Check if you're using a compatible CF card in the Camera. You can look in the user manual of the Camera to check for the compatible CF cards.
If the CF card that you're using is compatible but not working in the Camera then try using the card in other Camera to determine if the issue is with the card.
If the Card works normally in other Camera or device then reset the Camera to the original factory settings.
Even after resetting the Camera to the original factory settings if the CF card doesn't work in the Camera then you may try using any other compatible CF card to determine if the issue is with the CF card reader in the Camera.
Oct 30, 2009 | Cameras
New 4GB CF card for E5400, camera gives 'out of memory' message
So far as I am aware, the 5400 will support only up to 2GB cards. As to the firmware upgrade you mention, I don't recall that that has any bearing on the max. card capacity; but it's worth doing for the RAW format support (for me, at least). Cheers and good shooting. Davo, Tas.
Oct 06, 2009 | Nikon Coolpix 5400 Digital Camera
Canon rebel xt error messages
error 99 can most times be remedied by taking a standard pencil eraser and carefully cleaning the gold contacts at the back of the lens and the gold maching contacts in the lens opening of the camera... BE CAREFUL not to let eraser crumbs into your camera... keep it clean... reset the battery and give it a whirl.... did it solve the 99 issue?
for the CF it refers to the cf card... here's what I've found on this:
Canon reports that this error code may appear on your digital camera’s LCD (liquid-crystal display) when there is an error reading from or writing to the inserted CF (CompactFlash) card. This error code occurs most often after a user has tried to eject a CF card before the camera has finished writing data to the card.Solution:
Canon suggests that you first try to use a different CF card. If you do not see the error message when you use the new CF card, the first card is probably damaged.
Before you take the next step, drag the files from the CF card to a location on your hard drive to back up the files. Next, you can use Windows’ ScanDisk utility to check the CF card for errors. If you use a Mac, you can use Disk Utility (in Applications\Utilities\) in OS X.
If ScanDisk or Disk Utility fails to resolve the CF card problem, insert the CF card in your camera again. Then format the CF card. On most Canon cameras, you can do this by pressing the Menu button, selecting the Format tab, highlighting Format, selecting Format, and choosing Yes. Make sure you have backed up the data on the card before you do this. Formatting the card will delete the images from the card. After you format the card in your camera, use ScanDisk or Disk Utility to check the CF card again. If you still encounter errors while using ScanDisk or Disk Utility, you should discard the CF card because it is damaged.
If the error still occurs after following the steps above, your camera may need repair. Contact Canon’s technical support for further assistance.
hope this solves your issues....
let me know
K
May 29, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
Card for above camera
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I used the procedure set out by dwafellman and it worked for me too! His translations from the French are, in English: Control Panel (configuration panel)>Administrative Tools (administrator utility)>Computer Management (computer utility )> Disk Management (disk utility) in Storage (stockage). I. e., Control Panel>Administrative Tools>Computer Management>Storage>Disk Management.
Mille merci, dwafellman. Vouz m’avez sauvé un voyage á Office Depot pour retourner mon mémoire Flash.
imallan
Aug 22, 2008 | Konica Minolta DiMAGE 7 Digital Camera
Roland SPD-S Flash card error
The card I have always been using is now also suddenly giving this message. I found an old SanDisk 16MB and a 1GB SanDisk that works perfectly in my Boss 864 and they also give the same message. Trying to go into formatting brings the message "no card!"
May 13, 2008 | Roland Spd-S Sampling Percussion Pad...
CF Card Error
Check your memory card to see if its locked!
Jan 03, 2008 | Vivitar ViviCam 3915 Digital Camera
Nikon Coolpix 4300 Digital Camera Logo
46 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
