Question about Acer Aspire One Netbook 8.9" Notebook
When I turn on my netbook. It boots for abour 45sec. Then completely shuts down.
  • 31 Answers
This is a problem with the motherboard. It is no longer able to route the power properly so it turns off. It will need to be replaced and the easiest way to do this is to contact the manufacturer. If it is less than 1 year old the repairs should be free.
Go to support.acer.com
Posted on Mar 16, 2011
Stuck on loading services
things to try 1-unplug,remove battery - wait 30 sec,reseat RAM,turn back on.2 unplug remove battery hold down power button 45sec plug in,no battery,turn on.3 use startup repair.4 press Alt + F10 to restore.
Oct 20, 2014 | Acer Aspire AS7741Z5731 Netbook
BOOTMGR is missing from my Gateway LT25 laptop
press f8 while starting lunch repair
or try check disk utility by booting with any boot tools
Dec 22, 2013 | Gateway LT2514u 10.1in Netbook 1.66GHz 1GB...
My netbook wont turn on
  • check wether there is any battery problem...
  • Or else if netbook shows booting screen before shutting down. try safe mode log in... (mostly keep pressing "F8" key, it will show menu..)
Oct 18, 2012 | Lenovo IdeaPad S10-1208Uw Netbook
Shuts down immediatley after booting up
I can assume from your description and this "click" sound that you are facing an HDD problem. I would suggest downloading Hiren's BootCD from this link. Burn the content on a disk and boot up from it. Then start some of the HDD tests like HDD Regenerator and examine the results.I hope this helps!
Nov 20, 2011 | Acer Aspire One Netbook
When i start my gateway netbook lt20 a black screen pops up asking to start windows normally or 3 other options.. why?does this happen?
Usually because you didn't shut windows down properly before turning your computer off or completely draining your battery. If that is the case then simply select start windows normally and as long as you follow the correct shut down procedure it shouldn't happen again. If it does there may be a problem with your windows instalation.
Aug 17, 2011 | Gateway LT2021u Netbook
My acer aspire one netbook will boot then shut completely down after a few seconds
Did u hit the netbook anywhere??? Check to see if its getting hot to the bottom where the cpu is, it could be that the clock(fan) is blocked with dust or isnt working properly and the shutting off is a safety feature to protect the pc from internal damages
Dec 08, 2010 | Acer Aspire One PC Notebook
My Acer Aspire One netbook shuts down at 38 seconds into booting up... I've timed it a dozen times and no matter I do or don't do (log in, etc) the screen goes balck and it shuts down at 38 seconds. I...
The problem is because your software might have accidentally deleted system files... You can repair your windows using your setup windows disk....(Recommended) OR try starting your laptop in safe mode and try restoring........
Nov 07, 2010 | Acer Aspire One Netbook 8.9" Notebook
Systems shut down
Sounds like a software error, Try using system restore to set back the pc to an earlier time. Also try starting up in safe mode and uninstall any software that you may have installed.
Sep 28, 2009 | Acer Aspire One Netbook 8.9" Notebook
My TOSHIBA MINI NB205-n313/9 10.1 inch net book will not turn on
The laptop is not turning on?
Remove the battery and try boot the machine on AC power only. If the computer starts up turn it back off, reinsert the battery and try to boot the computer again.
If it still won't boot with the battery inserted then i suggest you send or take the computer back as there is a hardware problem.
Regards.
Sep 15, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Sony vaio boot up in normal mode
boot to the repair partition and reinstall windows it sounds like a registry problem reinstalling should fix
Aug 02, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
