I have a tiny computer but after turnin it on it doesn't start, it just shows ''of mode'' on the monitor,so whats the problem?
  • acidburn07 Mar 16, 2011
    Can you hear the computer turn on? The fans and such?
  • camden91 Mar 16, 2011
    Yeah i can hear it turnin on includin the fan revolvin!
  • 31 Answers
Since the computer seems to turn on fine, the problem is most likely with your monitor or its cables. Make sure everything is connected securely. If this does not work, you will want to try plugging you computer into another monitor. The least likely, if the previous steps do not fix the problem, is that you're graphics card in the computer is dead and needs to be replaced.
Posted on Mar 16, 2011
Soyo monitor MT-NI-DYLM1998 "out of range."
Your windows 7 screen resolution is set too high and your display doesn't support it. There are 3 possible solutions to this problem:
1. Press F8 during startup and choose "Enable row-resolution video"
2. Press F8 during startup and choose "Safe mode" and change screen resolution there, then reboot.
3. You can always use another display (if you have one) to set screen resolution to lower value.
Oct 15, 2012 | Soyo Computers & Internet
Dell Latitude D830 running Windows 7. Also running laptop screen plus additional monitor. I was watching a visor from cnbc.com when the addt'l monitor went blank and the laptop screen went a broken...
Hallo there
I hope you have got your screen beack, if not try to restart your computer in safe mode.
The restarting can be done in the following way:
1. Click START, click TURN OFF COMPUTER, and then click RESTART
2. While the computer is starting, press and hold down the F8 key until the Startup Menu appears
3 Use the UP ARROW and DOWN ARROW to select Safe Mode, press ENTER.
Now to the display settings
1 Open Display Properties in Control Panel
2 Click the Settings tab
3 If for some reason you are not in safe mode go through following:
In Colour quality, clock to alower settiing
Move Screen Resolution slider to the left if you want to reducethe size of the desktop
To Refresh frequency click Advanced and check the Adapter and Monitor.
4 After you have made your changes click OK
restart the computer if you are told to do so. But do not do it in safe mode..
Good luck
Kobrun
Feb 29, 2012 | Dell Computers & Internet
HP W2007 + Xbox 360 = Constant Sleep Mode
the monitor is bad
if it will not power on,
or show NOSIG< with XBOX on then turned off the monitor must show NOSIG>
why not test the monitor on any pc made even laptops VGA jacks works, so that works, its not the monitor.
and bad xbox video caused. but is not it. as you said.
the menu needs sync lines active. to pops the OSD button menu.
so the monitor is bad.
or the cable.
what is w2007, lets see.?
its old. at 1680 x 1050 @ 60 Hz
this old monitor runs CCFL lamps.]
im shocked it glows at all up to now.
ever do flash light trick test?
see got data, but no back light, CFFL is dead.
HP W2007
users guide last page.
This HP product contains mercury in the fluorescent lamp
in the display LCD that might
require special handling at
end-of-life:
that means CCFL died, also all do, soon.
(as short as 2 years, full time , they die. 20k hours)
out of your service manual it shows.
ccfl-wcj1avqu0msqxnqr1cdquwfl-1-0.jpg what any running pc connected the OSD menu most work
not in sleep mode.
if there is sinc, H/V pins active
that OSD must work or the blacklamp is dead
use flashlight see, there is data there, see?
Sep 09, 2017 | HP W2007 LCD Monitor
When i on my pc then the lg screen show me message analog power saving mode and then screen turns black. how can i overcome this problem
I would say that it doesn't see any signal coming from the computer. Check your output. Check the video drivers. Try another video display.
Aug 10, 2011 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Tells me I'm in a power saver mode. Screen is blank. Model is 2241V
That message comes up when the monitor doesn't get a signal from computer, and enters power save mode until computer comes on. This usually means that the computer's not starting up when you turn the power on. It may also mean that some problem has occurred with the computer's video circuitry.
Begin by checking that the computer is actually starting up properly. Look for the normal startup signs (lights on the computer showing power and disk access, fans running, sounds through the speakers). If you're sure that the computer is working and getting into Windows, try another monitor. This will tell you if the monitor is bad or if there's a video issue with the computer.
Jun 03, 2011 | LG Computers & Internet
After starting, my monitor displays "power saving mode".
Go into the menu and reset the monitor to factory defaults.
Aug 28, 2009 | LG L1915S 19" LCD Monitor
I just connected my venturer lcd tv to my computer for use as a monitor but everytime i turn my external hard drive on or put a memory stick in, everything freezes.
I turned booted the computer in safe mode before turnin on the hardrive then when it was picked up i restarted back in normal mode and its been ok after that
Jan 24, 2009 | Computers & Internet
Computer wont turn on
You might try turnin yer PC off & unplug. Then open the case & carefully remove the battery. Let sit for 5 min. Re-install the battery & put it back together. Plug in & turn on. IF you get a screen givin you the option "last known good configuration" take it
Good Luck
Dec 04, 2008 | E-Machines eMachines Desktop PC
Samsung SyncMaster 712n monitor will have small blue & white tiny checkers on the screen. will go away if i click the mouse. sometimes the entire screen has those tiny blue & white checkers.
Surely the monitor lets you change it's 'standby' settings so that it doesn't show that; or change your computer's power savings modes not to include standby?
May 29, 2008 | Computers & Internet
CRT Monitor-Compaq presario VM700
Hi Snandy, I absolutely despise monitor and computer sleep or hibernation modes. Before I started routinely disabling this on all the computers I supported my users were always having problems no matter how computer literate they were. I know this sounds simplistic and you may have already done it but have you just unplugged the monitor? If that doesn?t work maybe the PC itself has gone to sleep as well. Try moving the mouse, hitting a keyboard key. If that doesn?t work try pushing the power button on the computer to turn it on. If all else fails pull the power plug on the computer itself, plug back in and it should start up. I would suggest disabling all of this via Windows Power settings in the control panel. Let us know if you have any other questions and again please don?t forget to rate the post.
Feb 02, 2007 | Compaq V700 17" CRT Monitor
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
