Question about Video Cameras
Touch screen control panel switchs have failed but camrea body will release tapes ok, is it just the panel ? repairable?
    Genius:
  • 1,812 Answers
Yes it is. the LCD/touchscreen module will need to be replaced. This can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Posted on Mar 18, 2011
2003 Cadillac deville trunk randomly opens on its own when sitting and not running occasionally what could be the cause.
Do you know anything about automotive electrical testing ? how to read a wiring diagram ? How to use a DVOM - digital volt ohm meter ? You can find a free wiring diagram here http://www.bbbind.com/free_tsb.html
The trunk release is controlled by an electronic control moduel .
Trunk Release Relay
Output Controls
The rear integration module grounds the trunk relay when commanded ON. The rear compartment should release.
This vehicle has a very complex body control system of three different computers
The body control system consists of the following 3 modules:
• The Dash Integration Module (DIM)
• The Instrument Panel Module (IPM)
• The Rear Integration Module (RIM)
Each of the 3 body control modules integrate a number of functional systems under the control of a single module. Each module is connected to the Class 2 serial data circuit, many of the control functions are implemented by Class 2 messages.
. Rear Integration Module (RIM)
The various RIM inputs and outputs are described in the corresponding functional areas as indicated on the RIM electrical schematics.
The RIM functions include the following:
• Automatic level control
• CIGAR relay control
• Class 2 communication requiring RIM interaction
• Content theft deterrent
• Fuel door control
• Fuel level sensor input
• Heated seat control
• HVAC blower control
• LK/CYL relay control
• Park brake relay control
• Rear defog relay control
• Rear park assist chime control
• Retained accessory power (RAP) relay control
• Reverse relay control
• Transmission shift inhibit
• Trunk release relay control
• Various controls for the interior lamps
Luggage Compartment Description and Operation (General)
Rear Compartment Lid (trunk) release actuation is controlled by the following components.
• Rear Compartment Lid Release Relay
• Instrument Panel Module (IPM)
• Rear Integration Module (RIM)
• Valet Switch
• Rear Compartment Lid Release Switch
• Rear Compartment Lid Release Actuator
Battery voltage for the coil side of the trunk release relay is supplied through the Valet switch (with the valet switch in the OFF position) by the ALDL fuse located in the Underhood Fuse (Bussed) Block. Battery voltage for the switch side of the trunk release relay is supplied by the Body fuse located in the Rear Fuse (Bussed) Block. When the rear compartment lid release switch is momentarily pressed, it provides a ground circuit for the trunk release signal of the Instrument Panel Module (IPM). When the IPM senses that the switch has been activated, it sends a Serial Data Class 2 message to the Rear Integration Module (RIM). The RIM then provides a path to ground on the F/TNK DR REL relay control circuit. The trunk release relay is then energized, and battery voltage is applied through the switch side contacts of the trunk release relay to the rear compartment lid release actuator. The actuator is connected to ground through a ground splice pack located at the left rear corner of the rear compartment, near the left tail lamp connector.
Mar 01, 2017 | Cadillac DeVille Cars & Trucks
99 GMC Sierra headlights & running lights won't work!
Headlights Circuit Description
The headlights are controlled by the body control module (BCM) via the AHL Relay when the headlamp and panel dimmer switch is the AUTO position. When in the AUTO mode, the BCM receives a signal, (voltage) from the ambient light sensor, based on the voltage of the signal of n the sensor the BCM turns the day time running lamp (DRL) lights OFF and the headlights ON. The headlights can also be turned on by placing the headlamp and panel dimmer switch in the head position.
The relay coil is fed by the headlamp and panel dimmer switch or the BCM and the battery B+ buss bar in the underhood bussed electrical center (UBEC). The BCM supplies current to the relay based on the input from the ambient light sensor via CKT 352.
The relay output feeds the LT HDLP and RT HDLP fuses to supply current to the low and high beam lamps on CKT 1340 and CKT 1240. The ground for both the low and high beam lamps is supplied via CKT 524 and CKT 525 to the dimmer switch. The dimmer switch uses CKT 1850 for a ground to G203.
Some circuits are monitored by the BCM, and upon failure may set a DTC.
Park/Side Marker and Tail Lamps
The park/side marker and tail lamps are split between the following 4 fuses:
The FR PRK
The LR PRK
The RR PRK
The TRL PRK
These fuses receive voltage from the park lamp relay. When the headlamp and panel dimmer switch is in the auto position, the body control module (BCM) controls the relay by grounding CKT 1080 based on the input of the ambient light sensor. The park LPS fuse supplies battery positive voltage (B+) to the relay at all times.
When the headlamp and panel dimmer switch is in the PARK position, the relay is by passed through the INT PRK fuse. Current flows from the PARK LPS fuse through the headlamp and panel dimmer switch to the INT PRK fuse in order to feed the following fuses:
The FR PRK
The LR PRK
The RR PRK
The TRL PRK
Park Lamps Inoperative
Step
Action
Value(s)
Yes
No
  1. Turn the ignition OFF.
  2. Connect a scan tool.
  3. Turn the ignition to the ON position.
  4. Using the scan tool, check for any DTCs in the body control module (BCM).
Does the scan tool show any DTCs ?
Go to Diagnostic System Check - Body Control System in Body Control System
Go to Step 2
  1. Turn the headlamp switch to the park position.
  2. Connect a test lamp from (back probe) terminal B of the headlamp and panel dimmer switch to ground.
Does the test lamp light?
Go to Step 4
Go to Step 3
Locate and repair the open in CKT 240 (ORN) between the switch and the mid bussed electrical center (MBEC).
Is the repair complete?
System OK
Connect a test lamp from (back probe) terminal A of the headlamp and panel dimmer switch to ground.
Go to Step 6
Go to Step 5
5
Replace the headlamp and panel dimmer switch. Refer to Headlamp Switch Replacement .
System OK
6
Connect a test lamp from the INT PRK fuse, located in the left bussed electrical center (LBEC), to ground.
Go to Step 7
Go to Step 8
7
Locate and repair the open in CKT 74 (LT BLU) between the MBEC and the UBEC.
System OK
8
Locate and repair the open in CKT 74 (LT BLU) between the headlamp and the panel dimmer switch and the LBEC.
System OK
Aug 11, 2016 | GMC Sierra Cars & Trucks
What might be wrong with the trunk release on this 2007 Cadillac DTS? (It's not the valet switch)
Which fuse were you checking? There are two fuses in the trunk release circuit - one underhood (ALDL) which feeds the trunk/fuel door release circuits via the valet switch and also the ALDL circuit; and one under the back seat (BODY fuse) for the trunk release.
Unfortunately, relay control signals for these releases run through the IPM (Instrument Panel Integration Module) which handles the release buttons on the dash, and the RIM (Rear Integration Module), which receives these signals from the IPM and handles them and the trunk release button on the keyless remote.
If the fuel door release is working at the dash and the trunk release is not, the ALDL fuse should be OK and the problem may still be with the BODY fuse, trunk release relay or wiring. If that isn't the problem, then I suggest you check for IPM and RIM DTC's (error codes).
Nov 10, 2014 | 2007 Cadillac DTS Sedan
Bizhub c 450 error c 3752
Fuser Heat Error. Sometimes this code can be cleared by using the reset procedure outlined below. If the code returns then you will need to have the unit serviced.
Reset Procedure: 1. Turn main power switch OFF.
2. Turn main power switch ON while pressing the Menu/Select key.
3. Keep pressing the Menu/Select key until the LED turns OFF on the control Panel.
4. Check to make sure that "Trouble Reset" is displayed on the control Panel
after LED turns OFF.
5. Pressing the Menu/Select key.
6. Check to make sure that "OK" is displayed and the it has been reset.
7. Turn main power switch OFF and ON again, and make sure that the machine properly
starts.
Apr 08, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Reset hp t790
In Diagnoses mode EEPROM reset has to do for resetting,
Entering the Diagnostics Menu
1. Make sure the product is switched off with the Power key on the side of the Touch Screen Panel, and not with the power switch on the back of the product.
2. Press and release the Power key to switch on the product.
3. Wait for about 10 seconds until the 6 buttons on the Touch Control Panel have come on and then press and release one after another Cancel> Home> Help buttons.
4. The 6 buttons on the Touch Control Panel will then blink 4 times; then wait until the product completes the initialization sequence and shows the Diagnostics menu.
5. In the Diagnostics menu scroll to EEPROM reset..
But we strongly recommends that useres are not suppose to do this activities, printer may disturbed all the way...
Nov 11, 2012 | HEWLETT-PACKARD T790 InkJet Plotter...
Fujitsu li 2727 black screen on starting, power light on but wont display anything. tried hard reset and taken accesible hardware out and back in but still nothing.
Most laptops have a backlit display panel, usually a black screen means that the rear illumination has either failed or the switch which places the laptop into sleep mode when you close the lid has failed or jammed. Most sleep switches can be seen around the spine or hinges of the display panel and gentle coaxing with a wooden toothpick can usually release them but DO NOT use a probe made of metal as this could cause catastrophic damage if it touches and of the internal circuitry.
If you find that the sleep switch is working, take the laptop to a qualified repairer as laptops are really bad to disassemble and the display is NOT a repairable item. The inverter for the backlights is usually contained within the trim surrounding the display panel but may sometimes be hidden inside the base of the unit. THIS INVERTER OPERATES AT HIGH VOLTAGES. NEVER TOUCH IT OR ATTEMPT ANY KIND OF REPAIR WHILST THE INVERTER IS CONNECTED TO THE POWER SUPPLY - YOU HAVE BEEN WARNED.
May 11, 2011 | Computers & Internet
F7 Error on GE Profile electric oven. No response from keypad.
The F7 error code on your oven indicates the touch pad has failed. To repair it, you will need to replace the touch pad which is listed as a control panel.
If you do the repair yourself, disconnect the power to the oven. Take the 3 screws out above the door that holds the control panel on to the oven. Pull the control panel out at the bottom and lift it up, then pull out the top and drop it down so you can see the back side of the control panel, and you will see a ribbon connector going from the touch pad to the electronic oven control (ERC).
There is a latch holding the ribbon connector to the ERC, raise the latch to release and pull the ribbon out of the ERC.
Replace the part and reverse these instructions to replace the control panel.
Hope this helps.
Thanks for using Fixya.
Dec 15, 2009 | GE Ovens
My little girl was playing with my htc and put a 3" wrapping tape on the touch screen. when i was taking it off, the clear cover was coming. I pull it about half way before I took the tape off. then the...
Try calibrating the device again.To recalibrate:
Tap Start >> Settings. Go to System tab and tap on Screen. Now select to Align/Calibrate screen from there and follow the instructions. Tap Ok after the calibration is complete. Soft reset the mobile and then check again,
Nov 11, 2009 | HTC Touch P3450 Smartphone
F.14 maytag gas range
The error code F-14 indicates that the ribbon connector between the touch pad and the electronic oven control is disconnected. The recommended repair is to disconnect the ribbon connector from the electronic oven control and re connect it firmly.
If this doesn't correct the error code the recommendation is to replace the electronic oven control.
If you want to attempt this repair yourself, disconnect the power to the oven and open the door. Remove the three screws above the oven door that are holding the bottom of the control panel to the oven frame. Pull the bottom of the control panel out about 1 inch and down and it will release. The ribbon connector is a flat tape like cable, and there is a latch arm that you have to release before you can disconnect the ribbon.
Good Luck and please rate FixYa!
Jan 09, 2009 | Kitchen Ranges
Video Cameras Logo
340 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
