Question about Apple Chevrolet Silverado 2011 11 Direct Ipod/iphone Adapter
Ipod shuffle will not work in 2011 chevy silverado
  • 902 Answers
How do you have it connected?
Posted on Mar 16, 2011
How do you charge an ipod shuffle
Connect the included USB cable to your iPod Shuffle.
Plug the opposite end of the iPod Shuffle cable into an open USB port on your computer, which must be turned on.
Check the light on the iPod Shuffle. If the light has turned on, the iPod Shuffle is properly charging.
Using iPod charger
Plug the iPod charger into a working electrical outlet.
Plug the opposite end of the iPod Shuffle cable into the USB port on the iPod charger.
The iPod Shuffle should begin charging immediately.
hope this helps
Sep 18, 2012 | Audio Players & Recorders
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
1st series ipod shuffle...working fine did latest install from itunes and now ipod will sync but won't play...does repeating of green and orange lights. Tried the restore and resetting but still not...
Here's simple steps to cure the problem if your iPod shuffle won't play and does that green-yellow-green-yellow-green-yellow blinking thing:
  1. Plug in iPod shuffle
  2. You'll notice the "Podcasts" play list under your iPod volume.
  3. Delete the "Podcasts" playlist.
  4. ITunes will re-sync
  5. Unmount the iPod Shuffle and everything should be fine.
If that doesn't work try the link below. It's for the iPod Shuffle (1st generation) restore utility.
Hope it helps.
http://support.apple.com/kb/HT1238
Oct 24, 2009 | Apple iPod shuffle MP3 Player
How can i unfreez my ipod with out loosing my music
  1. Remove your iPod Shuffle from iTunes and also remove your shuffle from the USB dock.
  2. Turn off the iPod Shuffle by moving the off/on button to the left (when off you shouldn’t see green). Wait a couple of seconds and then turn the Shuffle back on by moving the off/on button to the right (you should see green again).
  3. Your iPod Shuffle should be reset.
Hope this works for you
Sep 27, 2009 | Apple iPod shuffle MP3 Player
I Pod shuffle (2nd. generation) won't hold a charge
Hold in the play button for 10 seconds to reset. If that fails:
iPod shuffle Software Update and Restore
Apple periodically updates iPod shuffle software to improve performance or add
features. It is recommended that you update your iPod shuffle to use the latest
software.
You can choose either to update or to restore the iPod shuffle software.
If you choose to update, the software is updated, but your settings and songs are not
affected.
If you choose to restore, all songs and data are erased from your iPod shuffle. All
iPod shuffle settings are restored to their original state.
To update or restore iPod shuffle with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software install file and follow the onscreen instructions to install the
iPod shuffle Update.
3 Connect iPod shuffle to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod shuffle software.
If you use the iPod Updater application and it doesn’t see that iPod shuffle is
connected to your computer, turn iPod shuffle off and turn it on again.
Mar 15, 2009 | Apple iPod shuffle Second Gen. Silver (1...
take the ipod back and buy a sony, ipod suck I have been waiting on the "ipod help line" for 30 mins on my mobile.
My ipod shiffle won't work at all!!
Dec 24, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Cant get shuffle to work when not conected to pc
How long have you had the unit? If it's been a year and a half or 2 years your battery needs to be replaced. They loose their ability to retain a charge in that time frame, and when you test a good battery or a bad battery they will both read 3.6v as a tester does not put a load on the battery, meaning you have 3.6v when the unit is off but when it turns on (load) it drops to zero. You could also try resseting the unit, to do so follow these instructions. To reset iPod shuffle: Disconnect iPod shuffle from the computer (if connected). Move the switch on the back of iPod shuffle to the off position. Tip: When iPod shuffle is off, the green stripe by the switch is not visible. Wait 5 seconds. Move the switch on the back to the play in order or the shuffle position. The green stripe will be visible in either position. iPod shuffle is now reset. If after resetting iPod shuffle you are going to attach it to your computer, be sure to place the switch in the off position. If you were resetting as part of some troubleshooting steps, continue with those steps now. For general troubleshooting steps see the iPod shuffle troubleshooting and service FAQ. To reset iPod shuffle: Disconnect iPod shuffle from the computer (if connected). Move the switch on the back of iPod shuffle to the off position. Tip: When iPod shuffle is off, the green stripe by the switch is not visible. 1st generation 2nd generation Wait 5 seconds. Move the switch on the back to the play in order or the shuffle position. The green stripe will be visible in either position. iPod shuffle is now reset. If after resetting iPod shuffle you are going to attach it to your computer, be sure to place the switch in the off position. If you were resetting as part of some troubleshooting steps, continue with those steps now. For general troubleshooting steps see the iPod shuffle troubleshooting and service FAQ. http://docs.info.apple.com/article.html?artnum=302110 Hope this helps.
Sep 15, 2007 | Apple iPod shuffle MP3 Player
Green/orange flahing light on IPod and no music.
From Apple.com Support Website. If the front status light on your iPod shuffle blinks orange and green when you press any button, then your iPod shuffle is experiencing some type of error. Try these troubleshooting steps to resolve the problem. To troubleshoot the iPod shuffle error light: 1. Turn off your iPod shuffle 2. Wait a few seconds 3. Turn your iPod shuffle back on again If this does not resolve the problem: 1. Check to make sure there are songs on your iPod shuffle 2. Use iTunes to add songs to iPod shuffle and try again If your iPod shuffle continues to display a blinking orange and green light, use iPod Updater 2005-02-11 or later to restore iPod shuffle, and then add songs with iTunes. If your iPod shuffle still shows a blinking orange and green light after trying all of the above steps, your iPod shuffle may need service. Best of Luck.
Sep 11, 2007 | Apple iPod shuffle MP3 Player
Shuffle not working, blinking green-yellow led.
Hi
Ur Ipod shuffles needs to be reset to factory setting, you will find the utility for Mac and windows machine at:
http://support.apple.com/kb/HT1293?viewlocale=en_US
http://www.techspot.com/downloads/3726-ipod-shuffle-reset-utility.html
1. Reset the ipod using the utility
2. Run itunes application to create profile : after you have reset the Ipod just start itunes and it will ask you to provide a profile name, just provide any name and select okay.
I had the same issue, got it sorted using the windows utility.
Should work for u as well.
Thanks
Krishnendu
Mar 20, 2006 | Apple iPod shuffle MP3 Player
Apple Chevrolet Silverado 2011 11 Direct Ipod/iphone Adapter Logo
329 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
