The Screen is zoomed in and we dont have a remote or a manual for the tv what can we do
  • 8,457 Answers
Picture screen sizes changes or zoomming out this function only can fixed this on the original remote functions only.Try website like Remotes.com to buy an original remote.
Posted on Mar 16, 2011
  • 902 Answers
Not sure what model tv you have but there should be a menu on the tv. seach thru it and select the zoom option if not. shut and unplug the tv for 20 minutes that will reset it back to factory settings for you let me know if this helps!
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: tv zoom without remote
Have to get the correct remote-no way around that.
Posted on Jun 14, 2012
My GE tv is in like a permanent zoom mode i dont have a remote cause the tv was giving to me and my fiance by her aunt its a older tv manufactured in 2001 please help
down load the users manual for the tv..if you can get it..and see if theres a procedure to get into menu mode..and change the screen aspect
Mar 09, 2014 | Televison & Video
How do I make the screen on my sanyo tv full- It has a black bar top and bottom
Your TV remote control (not the cable box remote control) would have to have a button that would allow the changing of the TV screen sizes. My Sony TV control has a button called, ' wide', and when pressed will change my screen to either, full, wide zoom, and zoom. Only zoom gets rid of the black bars on my TV. If no button, than the screen size will be determined by the broadcaster.
Feb 10, 2013 | Sanyo DP26640 LCD TV
Tv zoom without remote
Jun 14, 2012 | Televison & Video
LG 50" the pitcher is off the screen each side by
Ok, first make sure you or someone in family didn't hit the "HD Zoom" on your cable remote or whatever kind of remote you have. On ours - Cable- if you hit it once it is in "Normal" picture which on ours has black around edges on a non Hd channel. Then if you hit it again it Zooms once makes pix very large and if you hit button a third time brings it into a wide screen Zoom that fills the Tv screen. If we are viewing HD channels I put it on Normal which will fill the screen and give you the best HD pix. If we are viewing a NON HD channel, then normal will have black on sides, so I hit the Zoom a couple times to fill in the screen. My brother in law had this problem and couldn't figure out why his Sports channel Scores were always half cut off the screen! it was zoomed in too much for that channel. His sports channel was in HD so needed to be on normal instead of zoomed in.
if it is not the Cable remote then this is a second possible cause:
The other thing that happened to me was - we hardly ever use our original TV remote that came with the TV. but one day our picture looked weird and the cable remote didn't adjust it. One of us had hit the "P SIZE" button on the TV remote. this changes your pix from - 4:3 ratio to 16:9 ratio and vice versa. I put clicked that button and on the TV it shows whether it is at 4:3 or 16:9. For newer wide screen TVs you want that set at 16:9 ratio.
All cable company remotes probably are a bit different so check with your company ... to find out where the zoom control is on their remote.
Feb 27, 2011 | LG Televison & Video
I can't get the zoom to decrease on my tv. is it a problem with the tv, or the cable box?
This is the TV. Look for an aspect ratio or picture size or other wording button on the TV's remote control and READ your TV owner's manual. John
Jan 28, 2011 | Philips Televison & Video
Lost manual to work remote.Need template to work remote. My mom somehow zoomed the picture. She enjoys basketball, but is now unable to view the score on the margins.
Look in ur tv remote control for a button that said like VIEWMODE,P.sizes or Zoom buttons,pick one of these button fine a picture mode that fit ur tv screen.
Nov 22, 2010 | Dynex DX-L32-10A 32" LCD HDTV
TV zoomed in
Look at your remote or On-screen menus for ratio settings. The remote might say zoom or ratio. The menus will probably have it under video and then Aspect Ratio. You'll probably need to hit go through several settings to get to the correct ratio. (some choices are 4:3, 16:9, Full-screen - the best choice depends on the set and the source video)
I hope this helps.
(my remote (slightly different TV) has the zoom just above mute so I hit the wrong button often.)
Apr 24, 2010 | RCA 36V550T 36" TV
HD TV screen is zoomed to far out. How do
Use the Picture, Zoom, or Aspect button on the TV remote to cycle through the available screen sizes. You may also be able to set screen size in a Setup-Picture (or Video) menu.
Jan 18, 2010 | Televison & Video
Heads are cut off off
It sounds like you may have the zoom mode enabled on the TV source. A lot of HDTVs have settings for how different modes like 4:3 format source video is displayed such as Normal, Full, Wide, Zoom and Wide Zoom. Each signal input may have a different display mode and that is why DVDs look ok and TV does not. Not all TVs have that feature but most of the ones that I have dealt with do.
It may also be a screen centre adjustment in the cable box or satellite receiver.
I hope I was able to give you a viable solution.
Cheers
Jan 04, 2009 | RCA R52WH73 Projection Television
Sanyo 32" Tv about 4 yers old problem
Problems with screen size
Look out for 2 x 2.2uF electrolytics (sometimes red in color)
Vertical height oversize
The eprom was found to be faulty (nvm)
Pressing the screen format button displays wide, smart, zoom and 4:3 modes but settings have no effect on picure
Enter TT35 in the service mode to select a 4:3 CRT
Nov 23, 2007 | Sanyo DS32920 32" TV
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
