Question about Electrolux Vacuums
My built-in Electrolux vac is about 10 years old and I want to clean and oil the main suction motor. At which points do I oil the motor and will 3-in-one oil work or is there a special lubricant. John
  • 77 Answers
Do not oil the motor as it is not required, nor is there any place to put oil. the carbon brushes should be replaced though. carefully remove one brush and bring it to a vacuum repair facility. they should be able to match it up. there is a # on the side of the motor
ie: ####-## put a 116 on the front of # and you should have mfr. part # of motor. you may need that to obtain carbons.
Posted on Aug 02, 2008
How do I get reverse suction with the electrolux epic 6000?
I have no idea just what reverse suction would be or how to get it from ANY vac. If you're looking at getting the blowing air from the vac instead of suction, then simply move the hose from the suction end to the exhaust end.
May 25, 2014 | Electrolux Vacuums
Electrolux el7020a brush motor wont run
take the cleaner apart and make sure that the wires are all hooked to the on and off switch that got to the beater bar that is the main part of the problem improper wireing
Mar 22, 2014 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux cyclone power 1900w no suction with main attachment
If you've tried several different attachments and they all exhibit the same poor suction problems, you should completely check the parts of the vac that are common to all the parts that have the problem.
Since the motor creates good suction without attachments, I suspect the problem is the hose. Either an obstruction or a crack. Typically, if you block the end of the hose, the pitch of the motor's sound will go up slightly - like it it is spinning faster (it is). You can keep removing parts from the vac intake until the motors sound decreases - and that will indicate the part that has the obstruction. If it is a hose, you should clear the obstruction with a "snake" or other object like a pole.
If the motor sound does not change, then there is likely a split or crack somewhere between the intake of the vac and the device. You'll have to check it carefully - or if possible - connect it to the output of a vac and seal / cover the end. Feel along the length of the hose, etc. for air being blown out. Repair the opening and you should be "good to go"
May 12, 2012 | Electrolux Vacuums
Why has air suction pressure has dropped off to almost no suction? Filter cleaning did not help.
Do any of the ports have greater suction than others and are they closer to the vacuum motor unit? You appear to have a piping clog and locating it's position is the primary problem. If you have a portable vacuum, try placing it's hose in the exhaust port of the main unit and insert the pickup hose in a wall port near the main vacuum so that both units are on. The combined suction may pull the clog loose and draw it into the filter of the main unit. The other remedy is to remove the piping from the main unit and see if suction is good at that point, then work your way out to the nearest wall port. Hope some of this helps!
May 24, 2010 | Electrolux Central Vacuum
Have an electrolux 2100 canister vac, it has lost suction power thru the years. no clogs in newer hose or in sweeper. even with new bag, filter and belt only increases power minimally.
Have you ever over the years replaced your brushroll ? Have you tried dropping a coin thru the hose from one end to see if it comes out the other end ? Have you taken the wand loose from the elbow ( the swivel part of your carpet sweeper) to see if there was a blockage ? Does the motor make a strange noise ? Have you ever had a tune-up on your vac.
You might think about taking your vac to your Aerus/Electrolux shop.
Nov 19, 2009 | Electrolux Vacuums
Low suction
1) Have you checked the filter? If it is clogged your suction will be low. Also, you could have a pipe loose where you can't see. Make sure that you can get a coin to go all the way through the hose. make sure the suction motor ( the unit ) is coming on.
2) Call the repair man.
Aug 10, 2009 | Electrolux Central Vacuum
The symptoms you describe are typical of a vac that has a blockage (hence poor suction). It cuts out because it's over-heating. You need to check the hose, the filters and anywhere else where something may have got stuck. Blockages are often caused by things like paper clips, but can be caused by something as apparently harmless as a piece of paper which gets stuck and then debris builds up behind it and causes a log-jam.
Feb 10, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux central vac problems
I work on many types of units. If you electric floor brush runs but you have no suction then there is possibly a problem with the relay board that allows you to turn on the suction from the hose handle. This is a low voltage (24 V) switching loop circuit that will cause the 120 V motor in the unit to run.
Inside the wall valve are two brass pins. NOTE: there are 120V valves installed on some systems known as a Super Valve. A shock hazared exists if you work on that type of valve. That being said. In the round portion of the valve you can use a garage hose that has a 360 deg. chrome ring to test the valve. The ring completes the circuit causing the unit to power up and suction at the end of the hose. If the suction is weak, there is a colg in the pipe. If you hear no airflow, the relay inside the unit did not energize or the motor is bad.
To test: go to the unit and turn the switch on the side to "manual" if the unit turns on the motor should be ok. DO NOT RUN THE UNIT without and open valve. In some brands dammage to your motor will occure.
If the unit did not run, look for a small button near the switch. This is a circuit breaker for the motor. If it is poped out and you hear a "click" when you press it in there is most likely motor problems and someone should be contacted for repair.
Hope this helps!!
Mar 07, 2008 | Electrolux Central Vacuum
Vacuums Logo
60 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
