Question about Porter Cable 4 5 Gallons 150PSI Job Boss Oil Lube Mobile Air Compressor ? C3551
Job Boss 4.5 Gallon 150 PSI Portable Air Compressor Looking on line I have a similar problem. Air Compressor's empty I plug it in, it runs, but sound like its under a load and eventually blows the fuse. Some have said it might be a bad start capacitor. How do I fix this.
  • 323 Answers
SOURCE: Will only charge to 40 psi, is supposed to charge to 150
You may have a problem still related to the original reason it was reconditioned.
However, you should have a regulator that you set to the tank pressure you want to maintain. Most have a tool regulator as well and 40 psi sounds like that is what it is set for.
If you do have a tank pressure regulator and it is still not charging above 40 psi, then either take it back or pick up a new regulator for under $20 at Home Depot and replace the gauge you have now.
Also, sometimes the gauge will have a needle tilted so that one end presses against the glass, and if you tap the glass hard with your finger it will move on around to the correct pressure.
Finally, if you are not experienced with small compressors, look under your gauge and see if there is not a black knob that pulls out and pushes in to turn and change the pressure.
Sirwriter
Posted on May 22, 2009
manhandy
  • 146 Answers
SOURCE: craftsman 15 gallon air compressor 150 psi is not
leak, listen without any hose attached to it
Posted on Jun 26, 2009
  • 143 Answers
SOURCE: I have a porter cable 4.5 gallon 150psi air
That is what the relief valve is set at, you need to
either increase the pressure on the relief valve or
reduce the pressure on the pressure cutout switch. Stephen
Posted on Sep 06, 2009
roniecon
  • 6927 Answers
SOURCE: no air pressure thru quick connect to tools-bag regulator?
I dont know if it is like mine,but if you can let the air out of it and remove the regulator knob,and it`s components,you may can set it to just to be open all the time,in other words,by pass the control knob valve.Shout back at me if I can help.
Posted on Nov 06, 2009
  • 22 Answers
SOURCE: i have a 22 gallon 5.5 hp. when start it up it
Air regulator or pressure switch.
Posted on Sep 11, 2010
Why can't i get over 35 lbs on my job boss air compressor?
Check for internal leaks in compressor - compression rings on the cylinder braking often.
Another problem would be fittings or piping leak - usually a simple O-ring replacement will do a job.
May 13, 2014 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Regulator will not exceed 90 psi.
Nicholas:
It is possible to replace the regulator with a higher capacity regulator. Almost all air tools warn against using more than 90 PSI, and I think that your regulator is limited to 90 PSI for safety reasons... (but why on a compressor capable of 150 PSI I don't know). If you need more pressure, buy a replacement regulator (doesn't have to be Sears) and use a 1/4 inch nipple or a short length of air hose to connect it to your compressor.
Jun 04, 2013 | Air Tools & Compressors
I have a porter cable 6 gallon compressor. The motor used to cut out at 150 psi, but now it cuts out at 135. Is this a faulty tank pressure gauge misreading the pressure or a motor cutting out too early
it could be your air pressure adjustment knob, where your air line hooks up, which controls the psi to a lower or highist seting to adjust for different tools and uses.
Aug 26, 2012 | Porter Cable C2002 6 Gallon 2 Compressor
Does not auto turn off
Sounds like the pressure switch is shorted together. Unwire the switch and see if it shuts off.
Apr 08, 2010 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Air Compressor will not stop once plugged in
check tank pressure as it may be the rings n not getting to set pressure or faulty pressure sensor
Mar 22, 2010 | Measuring Tools & Sensors
Compressor won't kick back on when its suppose too
The tank check valve is probably bad. Folow the large discharge line off the head, disconnecting one end of it. If you get air out of the line you have a bad check valve. If you don't get air you are probably looking at a valve job.
Apr 04, 2009 | Dewalt d55151 factory reconditioned emglo...
Wont pressure up
Check drain plug on bottom of tank, check hose connections on top of tank.
Lugnut61
Jan 14, 2009 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Compressor Support
Home Use: Compressed-air power tools can dramatically decrease the amount of time spent on a project. Many homeowners will use smaller, portable units (either hand-carried or wheeled) that move easily from the garage to the house, yard or roof. Common air toolsAir Tools such as brad nailersAir Nailers, reversible drillsAir Drills, and impact wrenchesAir Impact Wrenches require about 0–5 CFM (Cubic feet per minute — units in which air flow is measured). It's important to know if the compressor you purchase will drive the air tool you'll need for your project. For example, smaller air nailersAir Nailers run on 2 to 5 CFM at 70 to 90 PSI, while larger shearsShears, sandersSanders and polishersPolishers require up to 10 or more CFM and 100 to 120 PSI. Business Use: Air compressors used for business/professional applications are often classified “industrial grade.” They're packed with features that let you take on more demanding jobs with more horsepower, more CFM, more PSI and more (longer) run times. Though some industrial-grade compressors are portable, many are stationary units with large-capacity, ASME certified air tanks (up to 120 gallons), greater HP, more CFM air volume and faster recovery time to run a wide variety of air tools for as long as you need them to do the job.
Aug 27, 2008 | Jenny Products Inc AM780-HC4H 4 Gallon...
Porter Cable 4 5 Gallons 150PSI Job Boss Oil Lube Mobile Air Compressor ? C3551 Logo
79 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
