Question about Breville Fresca BES860 2Cup Coffee Maker
Hi, my breville be5860 has been playing up. It was not turning off properly when i pressed the off switch it continued to make a humming noise. It has also been shorting out the power. Please help
    Novelist:
    Champion:
  • 232 Answers
Your machine is seriously faulty take it back for replacement before your house burns down.
Posted on Jul 30, 2011
Drum not turning
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced.
Now if you press the start button and the machine starts to hum and continues to hum its possible that something has gotten caught in the blower wheel and binding the motor up. Depending on the make and model the location and access to it vaaries.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 06, 2012 | Kenmore Dryers
Khhc2090s trouble
The sensor errors are probably just from opening the door and interrupting the sensor cook cycle.
By the way, you should always press "Stop" before opening the door of a running microwave. Otherwise, the door switches will prematurely fail.
I would first check the door switches and their mounts. See this help file.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also download manuals, installations info, and parts lists here.
dee77f7.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 25, 2011 | KitchenAid Microwave Ovens
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
Apr 10, 2011 | Jmlab Electra 905 Speaker
Humming sound when Sony DVD player is turned on. The player is attached to a TV. The sound continues when a DVD movie is played.. The intensity of the humming changes with changes in the Video.
Is the humming just from the power on or is it when the DVD is spinning some media will spin with a loud humming noise something to do with the balance similar to an unbalanced car wheel, just a lot quiter. Burn the DVD using ImageBurn create an ISO and reburn.
If it hums without the DVD spinning it is probably the transformer on the PSU on it way out this can happen at any time it is caused by the voltage step down coil becoming damaged in some way and the lower voltage provided causes the noise.
If this is the case I suggest a new PSU or at least a new Transformer.
Jan 07, 2010 | Televison & Video
Won't run
If "won't run" meaning; "does not tumble/spin" this can be a couple things;
1. Defective Drive Belt (Likely): Broken or jammed (not properly attached to motor/pulley). Nothing will happen when pressing start; unit will not heat or rotate/tumble. "Normal ware and tear"
2. Defective Door Switch (Very likely) - Very common due to constant "slamming" of door. The door switch enables power to be passed through-out machine when door closes for safety purposes. Switch located at door area and can be tested for continuity. "Nothing will happen when pressing start; unit will not heat or tumble/turn". * Fairly easy to replace; two mounting screws.
3. Defective/Jammed Motor (Rare, but possible): You may hear a "humming noise" and burning smell. Also, excessive lint in blower housing may jam the motor from rotating. "Does not come on; does not tumble/turn"
Remember to disconnect power from unit before servicing.
Jan 27, 2009 | Kenmore 659 Electric Dryer
Breville hand blender doesn't blend continuously
I have the same problem. Mine used to work, has only seen light use, and now it runs for about 1 second before it shuts off. Expensive POS. There don't seem to be any solutions either.
Nov 18, 2008 | Breville Cordless Hand Blender - Silver
Loud noise from subwoofer on standby or while playing music
Hi There, Please advise us what happens when you turn off the sub woofer is the hum still there....??
From YUBEUT.
Nov 27, 2007 | Teac CD-X8 CD Shelf System
Hum and left channel doesnt work
Are these new speakers? My sub hummed when I had it in plugged in to the wall outlet with a light switch connected. As for the speker not working maybe a wire is loose inside the speaker cabinet. If it was dropped or something.
Sep 25, 2007 | Boka 2000 Computer Speakers
Breville Fresca BES860 2Cup Coffee Maker Logo
117 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
