Question about Cameras
Hi its nokia coolpix s4000 my camera's touch screen does not work at all i cant do it any changes or any thing but it works every thing perfect except touch screen. its new camera. please help?
SOURCE: SONY DSC-T70 blank screen! touch screen camera T^T!
The same thing happened to my Sony DSC-T70 today after I dropped it. White screen with green vertical lines. Need help!
Posted on Apr 19, 2010
  • 11967 Answers
SOURCE: camera's lens is stuck
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 23, 2010
lock123
  • 6831 Answers
SOURCE: COOLPIX S4000 CAMERA LENS STRUCKED
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 20, 2010
  • 102366 Answers
SOURCE: how I could download photos
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Nikon Transfer or any other photo cataloging program.
Posted on Dec 30, 2010
  • 361 Answers
SOURCE: i dropped my nikon coolpix
Yes, it probably can be fixed, check with Nikon regarding the cost including shipping. It may well be cheaper and quicker to just buy a new one.
Posted on Jan 04, 2011
Touch screen isint working!! Help! Full battery! Not used often! Never dropped
You have software problem . Please get it fixed at dealer then.
Regards, Jay
Feb 26, 2011 | Nikon Coolpix S4000 Digital Camera
I want to buy a Kodak camera--that has the video feature that allows me to take a video - review it- and then take a snap shot from the video- the descriptions of the camera don't specify this feature. I...
I would recommend you to buy Nikon Coolpix S4000 Nikon's Coolpix S4000 creates touching memories by combining 12.0 effective megapixels, 4x wide-angle Zoom-Nikkor glass lens and an amazing 3.0-inch High Resolution HVGA (460k-dot) touch-panel LCD with sensitive touch. The Coolpix S4000 also features HD (720p) movies for high quality movie recording. The Coolpix S4000, with Nikon's EXPEED image processing concept, 4-way VR Image Stabilization System and Smart Portrait System enables you to get incredible pictures, incredibly easy. Nikon's Scene Auto Selector automatically analyses the scene you are taking and adjusts the scene mode for you. All you have to do is compose, then touchYou can check out more detailed review for Nikon Coolpix S4000. http://hubpages.com/hub/Nikon-Coolpix-S4000-12-MP-Digital-Camera
Jan 08, 2011 | Kodak Cameras
My nikon coolpix s4000 screen says battery exhausted, how do i fix the problem
i think you should change the battery, my coolpix 4300 had the same problem as yours, and after i replace the battery with the new one, the indicator never showed again
Jan 02, 2011 | Nikon Coolpix 3200 Digital Camera
If I buy a used camera do I need the cd-rom to upload the pic takened by the camera to my cpu
Dec 18, 2009 | Nikon COOLPIX L10 Digital Camera
I am buying a Canon SD970 IS digital camera. What
I would recommend you to buy Canon PowerShot SX210IS 14.1 MP Digital Camera with 14x Wide Angle Optical Image Stabilized Zoom and 3.0-Inch LCD. Decidedly slim and sleekly refined, the PowerShot SX210 IS packs a feature set that reads like a wish list. The 14.1 Megapixel CCD joins a 14x 28mm Wide-Angle Zoom for imaging power to spare. Frame your shots in the bright 3.0-inch widescreen PureColor System LCD, with the Low Light mode for sharp images in dimly-lit situations. It also captures stunning HD movies with Dynamic mode for enhanced image stabilization when shooting movies using wide-angle settings. Capture smooth HD video (720p) with stereo sound for a truly natural, high-quality HD experience. The PowerShot SX210 IS not only goes wherever you do, but takes your photography and video to a whole new place, too. You can check out more detailed review for PowerShot SX210 IS http://hubpages.com/hub/Canon-PowerShot-SX210IS-Digital-Camera
Nov 16, 2009 | Canon PowerShot SD890 IS / IXUS 970 IS...
Nikon S210- Coolpix 8.0-Megapixel Digital Camera - I want to buy this model...please can you help me out to buy it.
Sep 29, 2009 | Nikon Coolpix 8.0-Megapixel Digital Camera...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
