Question about Refrigerators
I have an Amana SRD26V and it is not freezing have cleaned all vents front and back and the motor runs and cuts off normaly , light is on and fridge part is cold . What could this be?
HVACRH20
  • 237 Answers
SOURCE: Fridge does get cold
Sounds like the motor starter/capacitor may be faulty. How long does the compressor run for? Do you hear a clicking every few minutes from the compressor? If a power surge fried the defrost timer that too could give similar results.
Posted on Dec 20, 2006
Krazytech
  • 725 Answers
SOURCE: amana side by side does not freeze nor does it get cold
first check you freezer back for frost if a lot of frost defrost the whole freezer ,,, then plug back in and see if it will work..
let me know
Posted on Jul 08, 2008
SOURCE: Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Posted on Mar 10, 2009
wheelshot
  • 102 Answers
SOURCE: Amana refrigerator stopped cooling.
Have you been hearing a clicking noise coming from behind the unit? This is the first indication of a failed compressor relay. Pull the unit out and unplug it. Remove the back cover and go to the compressor. You will find a device on the side of the compressor that has the wires hooked to it. This is the compressor relay and overload. It may be under a black cap. Remove the cap to access it. It may have 2 pieces to it or it may just have the 2 pieces encased in a white and tan box. Remove this box and shake it. If it rattles like gravel in it then it is bad. If it is in 2 pieces then it will have a brown relay. This is the piece that will rattle if bad. The white and black piece with one wire is the overload. They most never go bad. Use this replacement part kit...8201786 and follow the detailed instructions included in the kit. Thanks for the question. Hope this helps.
Posted on Apr 11, 2009
  • 212 Answers
SOURCE: Amana 'side by side not freezing slightly cool
sounds like you have a restriction in your filter drier. or you could be low on freon. both sealed system issues. you need an appliance tech to check your cooling system
Posted on Jun 21, 2009
Freezer won't stay consistently cold
replace temp sensors in fridge and freezer (easier to do together) should work fine...
Feb 04, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Please help mdl # BX21VL s/n 9910131900 freezer works fine refidgerator does not. no cold air blowing out of vent
If you have an error code showing or flashing then try is Powering off the FF at the AC mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured.
Try completely defrosting the FF as despite common belief these units are not totally frost free.
If the Freezer and the Fridge are not cooling enough then check that the condenser is not iced up and that the fan is running correctly. These are located behind a panel in the lower half of the freezer at the rear and can be accessed from inside the freezer compartment.
In modern uprights if the freezer part is working OK and the fridge is not working correctly it means that the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working Ok then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
In stand alone fridges the answer could also be that the cooling panel at the rear is dirty and needs thoroughly dusting / cleaning / unblocking and checking that there is enough space around it to cool properly and that it is not near any heat sources such as an oven, air vent, microwave exhaust, etc.. It could also be caused by a problem that has resulted in a loss of the refrigerant gas and will need regassing by a service engineer. Also check that the thermostat is working correctly, turn it up and the fridge compressor motor should kick in, turn it down and the motor should turn off. Also make sure that the fridge is not iced up, or overloaded, so cool air cannot circulate inside it. Best call a service engineer asap.
Nov 11, 2009 | Amana ABB1927DE Bottom Freezer...
Amana Fridge with bottom Freezer. Freezer is working fine, but the fridge is warm. What can I do?
It most likely means that the air vent from the freezing unit has stuck in the closed position which causes the fridge to not be any where near as cool as it should be and if it is too cold then the vent is stuck in the open position. The vent is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up, which can be caused by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail.
In stand alone fridges the answer could be that the cooling panel at the rear is dirty and needs thoroughly dusting / cleaning / unblocking and checking that there is enough space around it to cool properly and that it is not near any heat sources such as an oven, air vent, microwave exhaust, etc.. It could also be caused by a problem that has resulted in a loss of the refrigerant gas and will need regassing by a service engineer. Also check that the thermostat is working correctly, turn it up and the fridge compressor motor should kick in, turn it down and the motor should turn off. Also make sure that the fridge is not iced up, or overloaded, so cool air cannot circulate inside it. Best call a service engineer asap.
Oct 14, 2009 | Amana Refrigerators
Frozen items in refrigerator
In side by sides if the fridge side not working correctly it means that the air vent from the freezing unit has stuck in the closed position which causes the fridge to not be any where near as cool as it should be and if it is too cold then the vent is stuck in the open position. The vent is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up, which can be caused by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. Best call a service engineer asap.
Aug 29, 2009 | Amana Refrigerators
Amana arb2557cw condenser coils freezing, fridge not cooling
There are a few things that it could be. Do you mean the evaparator coil? This would be the coil on the inside of the freezer, the condenser is outside the unit. If the evap. coil is freezing, you could have to much in your freezer blocking air flow. You could also have a evap. fan not running. Check the owner's manual for the location of the defrost timer, it could be bad. The thermostat needs to be checked and set so that it is at a reasonable level. One last thing to check would be the condensate drain. Make sure the drain is not plugged or the line is not plugged. Good luck.
Jul 31, 2009 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Amana SPD26VW runs, lights on, does not freeze
I called Amana and found the "sealed systems" are still under warranty. It cost me $85 for a service call and the fridge is working. The problem was a plugged "capillary line."
Jun 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Apr 12, 2009 | Amana ARS2464B Side by Side Refrigerator
Amana Bx22s5W freezes food in the crispers
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Jan 25, 2009 | Amana Refrigerators
Refridgerator is freezing food
if you only have one thermostat put it in the middle if you have two put both in the middle,but it sounds like your thermostat is bad that's why it is freezeing the food in the frig.it's not shutting off,let me know-mike
Sep 26, 2008 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
