Question about Zuma
Top part of Zuma loads (on fb) but the bottom part doesn't. Says "done" ~
  • 5 more comments
  • Lorraine Finw Mar 16, 2011
    I have no idea how to update my flash player.
    Can you tell me how to update my flash player? I'm not having problems with any of the other games, just Zuma.
    Hi ~ I downloaded the flash player, adobe air
    I try this every time. Seems like originally it worked, but that no longer helps.
    I did that from the links you sent me last night.
    IE 8
  • Lorraine Finw Mar 18, 2011
    I changed to Foxfire and everything is back to normal, and I am discovering some features I really like on Foxfire.... so thank!
    President:
  • 739 Answers
Hi..
Normally it is a matter of the application. Logout yr facebook and then clean your browsing history and cookie files on your internet browser and then update your flash player. Normally it will return to normal
regards
Posted on Mar 16, 2011
  • 1 more comment
  • HTS Sri Aman
    HTS Sri Aman Mar 16, 2011
    Click Here!!! to doenload flash player, adobe air and shockwave player
  • HTS Sri Aman
    owh .. like that. If so, most likely a problem only on your internet browser. if so you better fix your internet browser first. may I know you use what internet browser and operating system ?
  • HTS Sri Aman
    HTS Sri Aman Mar 19, 2011
    you're welcome
    Do not forget to accept my solution solve your problem, so that I can receive proper compensation from fixya.
    I also represent you to express our thanks to fixya.com for creating this space for all facilities.
    Guru:
  • 767 Answers
When this happens, try clicking the refresh button on your web browser or by pressing the F5 button on your keyboard.
  • 1 more comment
  • Jean-Pierre Damstra
    Jean-Pierre Damstra Mar 16, 2011
    To get the latest version of flash player go here:http://get.adobe.com/flashplayer/
    And it still doesn't show the bottem half of the game? What Web browser are you using?
    Your internet explorer may be clogged with Temporary Internet files and cookies. I suggest downloading a program to clean this all up. It's called CCleaner, you can get it here.
    Just download, install and then run it. Under the Cleaner Tab on the left, you can tick the kinds of files you want removed. Leave it at default, but if you want to keep autocomplete form history unclick that box. Then Click Analyze and give it a few moments. Once it has completed the analyzation click Run Cleaner. This will then delete un-needed files that are clogging up your IE.
    You can also use this program to speed up your PC. Just go to the Registry Tab on the left. Once in it click Scan for Issues. Give it a few moments. When complete click Fix selected issues...
    You don't need to make a back up changes to the registry so click No unless you really want to just in case. Then click Fix All Selected Issues on the next window. Then close.
    If this doesn't work then I suggest trying another web browser like Apple Safari, Firefox or Google Chrome. Internet Explorer does have a tendency to have problems when it comes to some Facebook games.
Why can I only load the top of fb page on my pc?
Check to see if your adobe flash player is up to date.
Oct 21, 2015 | HP Pavilion Computers & Internet
My profile picture will not show what do i do help
See if this helps. I couldn't get Firefox or Chrome to bring up my FB images, same as pic above.
in case problem is not dissolve that means if you are using router you reboot or check the setting
once try connect LAN wire and try
So I opened up IE and logged onto FB and it worked perfect. ( IE is NOT my regular browser).All photos, headers the works all showing up. I then opened Chrome up and cleared my cache for the past week, incase some sort of bug was there. I reset my Firefox brower, by getting rid of add ons. To do this go to Firefox help, troubleshooting, click reset Firefox button on top right hand side. Then tried FB in Chrome and Firefox and they are both loading FB perfect too, now.
Don't know if it was an FB bug, or if loading FB in IE first solved the problem. Try running the IE browser and signing into FB, maybe that will fix the problem. Then log off and try logging into FB again with your other browser. If you still see a problem, then the other steps I did re Chrome and Firefox may help you. Good luck!
May 17, 2014 | Facebook Social Network
Zuma 49cc overflow line leaking gas
floats sticking keeping it from stopping fuel fill in carb bowl. Result over flow and out ..try opening bottom screw on bottom of carb let fuel flow out than close screw.{located on bottom of carb bowl usually next to a nipple or fuel line} If that don't work tap on side of bowl with something. If that don't work your going to have to remove carb and investigate..good luck..
Dec 25, 2013 | 2005 Yamaha Zuma
2005 Yamaha Zuma won't start
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
ZUMAFORUMS NET View topic Help my zuma 50cc won start anymore
Yamaha Zuma won start
Yamaha YW50P Service Manual
OEM parts for Yamaha
Yamaha ZUMA YW50T Owner Manual
Oct 26, 2012 | 2005 Yamaha Zuma
My fb is hang or log. it doesn't work
Please clear the internet surfing history on your PC clean the cache, the cookies and browsing data or downloads. It will also be good to do a registry clean up with a virus/spam/worms check with a de-fragmentation.Once this is done log in once again to confirm or use a PC to confirm if this relates to a site issue or your PC which could have OS faults.
Mar 12, 2012 | Computers & Internet
Not to open my games in facebook
Try checking whether you have the latest versions of Adobe Shockwave and Flash players:
http://www.adobe.com/shockwave/welcome
If that doesn't work, look into removing old versions of the programs:
http://kb2.adobe.com/cps/141/tn_14157.html
Check again when you're done, to make sure you have the latest versions.
Also, when I play some games on fb, I have to right click on the main screen of the game once it loads and choose low quality, and clear the browser cache*, in order to make them run reasonably fast.
(*Delete browsing history in IE 8 by clicking on Tools, then Delete Browsing History; make sure all boxes are checked except the top one, and click ok. Wait for it to work- if it doesn't within a few seconds, minimize the main window until it does.)
Good luck, and I hope this helps!
Jul 01, 2011 | Microsoft MSN Battles
I can not play country life...error 4011
Jun 30, 2011 | Country Life lite
Im unable to access my fb games lately. When I click the app on my fb page it says, page requested not found. The link doesnt look the same. When I change it, it switches back.
It is possible that you enabled Secure Browsing (https) on your account. Many games do not allow you to have the https connection. To turn this off you could click on Account, then Account Settings at the top right. When that page loads there are several options. Towards the bottom is Account Security. Click Change. Uncheck
Secure Browsing (https) Browse Facebook on a secure connection (https) whenever possible
Click Save and try again. When you are done playing your games if you are still concerned about your security you can repeat this process and then check that box and save when you are finished gaming.
May 04, 2011 | Facebook Computers & Internet
I am Unable to access my farm im FB. It starts loading and reports "Done" in the left bottom corner, but no graphicks is loaded. Can you assist?
Click on the refresh button twice. Facebook has said, "They are having trouble with farmville, and working on the problem."
Dec 06, 2009 | Facebook Social Network
Zuma Logo
137 people viewed this question
Top Zuma Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a Zuma Facebook App Expert? Answer questions, earn points and help others
