Question about Daewoo Washing Machines
My daewoo dwd-ld1412 airbubble 8.5 kg front load washer, is showing error message on every load i do, on mostly 60 degree washers, it was purchased september 2010. am very frustrated. Cheers Lori
  • 108 Answers
SOURCE: My front load LG Washer has a mildew/musty odor.
Make about 3 quarts of boiling water on the stove. Pour one cup of bleach, and a few capfuls of pine sol into the washer (just pour them directly into the washer through the front door.) Now, if you have a faucet near the washer, turn on the hot water until the water is hot- then turn it off.
Now start a "hot" load, and after the water starts to fill, pause it, and add the really hot stove water. This will raise the water level high enough to wash off all the gunk that has built up between the spinning inner barrel of the washer and the outer barrel in which it sits.
For future reference... only use HE detergent, never use liquid fabric softener, always take the clothes out as soon as possible after the load is finished, and leave the door open when you are done.
Front loaders are kind of known for this problem.
Posted on Jul 22, 2009
ginko
  • 19396 Answers
SOURCE: Daewoo Washer Error E8
Hi.
E8 is fault connection from CCU (Control board) to balancing sensor.
When you get E8, this is often because of a faulty control board.
Try first disconnecting power for a couple of minutes, to reset the appliance.
If you still get E8, then you need to call a technician. Testing is done jumping the two wires to the sensor to bypass the sensor, then replacing either sensor or control board.
If you want to arrange a repair, then you can call the phone number listed on the machine owners manual.
Regards.
Posted on Nov 08, 2009
SOURCE: Daewoo washer - LE error message
replace the lock switch
Posted on Dec 27, 2009
  • 3 Answers
SOURCE: E8 code when washer fills on front loader daewoo
E3 CODE WHAT MEANS
Posted on Apr 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
What does error message F-10 mean
Please consult the electrical schematic attached to the machine. It's has all the error codes listed and what to do to troubleshoot.
Jan 03, 2016 | Hotpoint Ultima WT960P Washer Front...
I have a washer dryer combo (daewoo DWC-LD1412) am I able to use the dryer without having to do a load of washing?
check the hand book ( download from the net if you have lost it) you should be able to program it to dry with out a wash as you should be able to hang the washing with out using the dryer
Jun 25, 2015 | Washing Machines
I have a Daewoo washing machine DWD-F1011 S, 7 KG..IT STOPS AND gave us an error with code E8.. HOW CAN WE SOLVE IT?
this is what I found E8 Washing machine motor error detectedA fault has been detected with the main drive motor.
  • Check motor connection block
  • Abnormal loading condition
Mar 13, 2015 | Daewoo Washing Machines
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
How to clear impellor
Top unscrews, impellor lifts off. Any tangled items can be pulled clear
May 19, 2012 | Daewoo DWD-WD3011WW 4.0 cu. ft. Capacity...
Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
Apr 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Error codes
If this machine is like other of its type then you may find the manual taped to the inside of the machine near the bottom side panel.
open the bottom access panel (3 screws on bottom front lip) and look for it as it will have the codes. near where the filter is .
while you were down there cleaning the filter did you check that the pump impellers move freely and were not clogged with any debris.
Jan 28, 2008 | Maytag EPIC MFW9700S Front Load Washer
Error codes
if this is a fridgidaire washer, I guess it's a clogged coin catcher. You have remove the front access panel and clean it out. I am working on that now.
Nov 05, 2007 | Washing Machines
Washing Machines Logo
178 people viewed this question
Top Daewoo Washing Machines Experts
Owen Barnes
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
