Question about Garden
I was attempting to change the combination on the 7002 Ilco Unican Kaba lock and I don't know if I entered the wrong code or what happened but now I can't get it to accept any code. How do I reset it so I can try again?
4 Suggested Answers
SOURCE: Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Posted on Aug 22, 2009
SOURCE: How to reset codes in Kaba ilco Unican 4000 access control
The factory-default master code for Unican 4000 is 12345678
Posted on Mar 08, 2011
  • 97 Answers
SOURCE: my master lock is locked
If this is an older masterlock with a serial number, you can fill out the form located here http://www.masterlock.com/pdfs/lost_combo_form.pdf
Read the below from masterlocks website: Due to increased security concerns nationwide, Master Lock recognizes the heightened need for additional safety measures. We no longer provide lock combinations in response to phone, fax, or email requests. Please follow the procedure outlined below to obtain the combination to your lock and submit your request to:
Master Lock Warehouse
1600 W. La Quinta Rd
Suite/WHSE # 1
Nogales, AZ 85621Procedure:
  • Print out the Lost Combination Form from a printer friendly page, or download the PDF file.
  • Have your Lost Combination Form notarized by a Notary Public to prove that you are the owner of the lock (you can include up to 6 combinations on one notarized form).
    • Note: Inmates at a correctional facility - in addition to the lost combination form, you must submit your request on official prison letterhead. In lieu of notarization, the form must be signed by a prison official.
  • Photocopy the serial number on the back case of your combination lock. This copy MUST clearly show that the lock is not attached to anything. Be sure to hand write the serial number on the photocopy.
  • Mail the original completed, notarized Lost Combination Form and the photocopy of the back of your lock to the address above.
Note: It will take approximately 4 to 6 weeks to process your request for a combination.
Note: If the form is not fully completed and notarized with a raised seal or rubber stamped seal, or if the serial number is not legible on the photocopy, your request will not be honored. Master Lock does not reimburse for any Notary fees.
Posted on Aug 28, 2011
How to make a house keeping authrization key
I don't know whether this can be done. I recommend that you contact Kaba Ilco directly for assistance:
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Oct 11, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Model 1011... door opens without any combination. how do i fix the lock to open only with combination?
"If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution
Solution: Follow the procedure for changing a combination except omit step 3 (do not enter
the existing combination)."
I excerpted the above from the full instructions on how to change the code. If you don't have them, got to this link:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
and go across from L1000 to the last column, "Tips".
When you hover your mouse over PDF, two choices will appear; left click on the upper one, "Changing the code/..." to download it.
The download will be a PDF file format. If you are unable to open it, you will need to download and install Adobe Reader on your computer. There is a link (Get Adobe Reader) at the top right of the literature grid.
When you do get the download open, you will have the stepwise procedure and illustrations necessary-but don't forget to omit Step 3, if you believe that you have the ZERO code problem!
Good luck--and please provide feedback if this helps!
Aug 15, 2011 | Simplex Kaba Ilco Unican 1011 keyless...
Door opens without any combination. how do i fix the lock to open only with combination?
Lost combination on the unican 1000! How do i get it back or set a new number in it?
I will give you several sources of information for you to pursue.
First is a link to a chart where you can download PDF files for your lock ( the L1000):
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=l1000
There is a link on that page where you can download and install Adobe Reader in order to open and view PDF files, if you don'ta already have it installed on your computer.
Aditionally, here is a link to a website wherein it is described how to change the combination on the unican lock:
http://www.lilocksmith.com/keyless_Locks/unican1000.htm
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
May 17, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Unican LL1011 lock - the code opens the lock correctly. If a wrong button(s) is pressed the lock does not open as I would expect but when the correct code is entered it then fails to open
I recommend that you contact Kaba Ilco with this problem--there may be nothing wrong with it at all, but you need an answer.
Jan 28, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Door does not lock when closed.
Jan 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Had to replace a return spring under the clutch and now the clutch arms won't reset the combo pack if a wrong code is entered.It does work if the right code is entered
I recommend that you contact Kaba Ilco directly with your problem.
Jan 18, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
When i turn the knob without entering the combo, the door opens. When I enter code, the door doesnt open. The passage knob is in the correct position.
Jan 07, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
WE HAVE THIS LOCK INSTALLED AND IT HAS THE TYPICAL FACTORY SETTING CODE (2/4 THEN 3). WE DON'T KNOW HOW TO CHANGE IT! HELP
You will find a link to download the manual for your model on this page:
Hover your mouse over "PDF" under the "TIPS" column and the two choices of "Changing the Code/Combination" or "How to Reset a Lost or Unknown Combination" will appear--move your mouse over the appropriate one and click to download the info.
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader, if the file will not display for you.
Jan 06, 2011 | Simplex Kaba Ilco Unican LP1000...
Nov 12, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
