Found some quick solutions including the manual for you
first here is the link for hte code list and manual http://www.rcaaudiovideo.com/remotes/2-3-devices/?sku=RCRN03BR
which i got from various sites after researching your problem for about 30 minutes please let me know if this works i hope i helped i tried really hard
if that doesnt work try these methods PLEASE LET ME KNOW IF I HELPED
for this first method you need the direct code which is 04
- Manually turn on the component you want the remote to control.
- Locate the Brand Codes in the Code Lists.
- Press and hold the component key you wish to program. The illuminated ON·OFF key turns on and remains on.
- While holding the component key down, press and hold the ON·OFF key. The illuminated ON·OFF key turns off.
- After holding both keys down for three seconds, the illuminated ON·OFF key turns back on.
- Release both keys. The illuminated ON·OFF key remains on.
- Refer to the Brand Codes. Press and release the appropriate brand
code key (Numbers 0-9), using the number keys. The illuminated ON·OFF
key blinks once.
- Note: If you do not press a valid Brand Code Search key, the
illuminated ON·OFF key blinks four times and turns off. The last
programmed code under that component key is retained.
- Press and release the ON·OFF key repeatedly until your component
turns off. Each time you press the ON·OFF key, the illuminated ON·OFF
key blinks, and the next code is sent. The Brand Code Search begins with
the first code in the chosen brand list for that component and cycles
through all the codes for that brand. If your component turns off, you
have found the correct code. (If it cycles through and the illuminated
ON·OFF key blinks four times and turns off, all codes in the chosen
brand list have been searched and another programming method should be
tried. The Brand Code Search mode is exited.)
- Once you have found the correct code, save that code by pressing and
releasing the STOP key. The illuminated ON·OFF key turns off. You must
press the STOP key to save the code or the correct code will not be
stored!
- To confirm that the component key is programmed with the correct
code for maximum functionality, test the component. Attempt to control a
variety of the component's functions with the remote. If some of the
features of your component do not work, program the remote with a
different programming method.
if not try this for auto code search
STEP :
- After holding down both keys for three seconds, the illuminated ON·OFF key turns back on.
- Note: If you press an invalid key during Auto Code Search, the
- Press and release the PLAY key, then wait five seconds to see if
your component turns off. If your component does not respond, continue
to press the PLAY key every five seconds until your component turns off.
Each time you press the PLAY key, the illuminated ON·OFF key blinks ten
times and a block
of 10 codes is sent to your component. This process continues until all
of the codes in the Code Lists have been searched. (If your component
has not turned off after all codes have been searched, the illuminated
ON·OFF key blinks four times and turns off. The Auto Code Search Entry
method is exited.)
- When your component turns off, you know the correct code is in the
last block of 10 codes sent. Press and release the REVERSE key. Wait two
seconds to see if your component turns on again. If your component does
not respond, continue to press the REVERSE key every two seconds until
your component turns on again. This will isolate the correct code in the
last block of codes sent. Each time the REVERSE key is pressed, the
illuminated ON·OFF key blinks.
- Note: If you accidentally press the REVERSE key after your component
responds, press and release the FORWARD key. Then, wait two seconds to
see if your component turns off again.
- Once your component turns on, you have found the correct code. Save
the new code by pressing and releasing the STOP key. The illuminated
ON·OFF key turns off. You must press the STOP key to save the code or
the correct code will not be stored!
- When you press the STOP key, the code is stored.
Thanx very much for the responses! Unfortunatey, these are essentially the same techniques and info provided in the paperwork with the remote. The search methods do generate multiple codes which will turn the VCR/DVD on and off, but do not provide full functionality via this remote. (EX: The MENU function doesn't work). So I'd like to drill down into this, to the point where somebody can tell me the specific code that speaks to this device.
