My picture isn't as bright as it used to be. Is there somethning that can be cleaned or lamp changed?
  • 8,457 Answers
Ur tv is a DLP projection tv?Yes,the tv projection lamp is dying,sould be replaced.If this is a LCD or Plasma tvs is notthing u can do,as the tv getting older the screen brightness will get dimmer and dimer as tv ages,only thing u can do is to go into the Menu goto PICTURE SETTING.Go go down to Brightness increase it and the Contrast increase it too.
Posted on Mar 16, 2011
On my WD-60C9 60 DLP HDTV the picture is really dark, colors are still ok but the entire picture is dark
Have you tried changing the brightness and contrast with the picture controls? If that doesn't solve the problem, it's possible the lamp box and lenses in front of the bulb need cleaning.
Feb 20, 2017 | Televison & Video
26" Insignia TV, screen is
Go to your menu and choose picture. See if your settings are normal or if the brightness is turned down. If it isn't then it's a problem with the T.V.
May 04, 2011 | Insignia LCDTV26 26 in. Television
Replaced lamp in 55vg825 approx 1500hrs ago & lately the picture has lost brightness compared to when the new bulb was installed. Is there another adjustment or is the bulb defective already? Past...
bjac,
You are correct about lamps working or not, but that is the extremes. Over the course of operation all lamps lose brightness as the hours add up. All lamps will lose their brightness over time.
Typically lamps only last at best 6000 to 8000 hours. That is not long if the unit is used most of the day everyday. In addition the cheaper the quality of the lamp, cost and manufacture, the quicker they go down hill.
Assuming that you have a low quality lamp what you are experiencing is normal. You may be able to improve the brightness and clarity of the picture by cleaning the lenses, mirrors and screen. I have a tip at
http://www.fixya.com/support/r4690955-clean_lense_screen_in_projection_tv
This tip is labeled projection tv but is also appropriate for cleaning an LCD or DLP unit.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 14, 2011 | Hitachi UltraVision CineForm 55VG825 55"...
The overall picture is not bright like it use to be. like about half the brightness. picture is fine just not bright
suggest replacing the lamp. when the lamps are reaching the end of their life the tv will take a long time to show a picture and you may see a drop in brightness. part number 915P061010 i would really suggest getting a mitsubishi original lamp there are alot of generics out there and they are junk. good luck
Jan 06, 2011 | Mitsubishi WD-65733 65" HDTV
Sony KDF-E50A10/4 dark picture
Dark picture is indication that tv needs new lamp.
Replace lamp in tv get bright picture, please buy Sony original lamp for good picture in tv.
Jun 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Replaced wd-62525 lamp, picture dim
Cleaning the mirrors will not increase the brightness much. I would double check the lamp setting in the Menu and also the setting of the picture and brightness settings. Many times these are adjustable independently for different inputs. Besides this, I would look at the Ballast and or the Power Supply to cause the problem. I would recommend a professional to look at it if it is not correctable from the Main Menu of the set.
Hope this helps,
Skyassoc
Jul 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Replacement lamp not bright
as i previously posted, my picture was dim, muddy looking after replacing lamp with osram lamp. i fixed mine by taking the screen off and cleaning the small mirror. it had a thick layer of dust on it, cleaned with a microfiber cloth. no water, no glass cleaners. i also used a very fine new small paint brush and dusted the projector lens which also had a dust film. brightness, contrast and clarity returned!
Mar 05, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Sony rear projection TV
If your tv uses a lamp then change the lamp
Apr 27, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Why does picture brightness change up and down on LP70.
Hi there
Sounds like the lamp is going , but it could be the Ballast as well ( lamp's powersupply ) Rather have a certified technician look at.
Mar 22, 2008 | InFocus LP70+ Multimedia Projector
Mitsubishi WD52525 Brightness
Usually a bad lamp. If the lamp you replaced is new, then cleaning the internal mirrors (especially the small triangular one) and clean the projector assembly as well. The lamp ballast supply may be weak as well, but I seldom see this.
Mar 04, 2008 | Televison & Video
Televison & Video Logo
184 people viewed this question
Top Televison & Video Experts
Electro Med Services...
