Question about GE Profile WPRE6150KWT Colossal Capacity Washer
Washer will not spin or ajatate. I need to remove the front panel to see what up?
  • GE Master
  • 8,220 Answers
Use downwards force to relieve tension on the spring clips holding that front panel on.washer will not spin or ajatate. I need to remove - themobilian_1904.jpg
Video how to:
Once yall have the front panel removed yall will notice the motor has a green blinking light on it.
The motor blinks on and off all the time It blinks faster when running. That is normalment mon ami.
If it ain't acting right it will display flashes:
1 flash bad motor
2 flashes slipping belt
3 flashes corrupted software bad motor
4 flashes failed mode shift circuit
5 flashes little green men (bad motor)
6 flashes locked motor check for objects between tub
7 flashes bad lidswitch.
8 flashes motor overheated too much soap
9 flashes brake resister is toast bad motor.
To Reset the Inverter Board: Push the timer knob in so the washer is idle. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds.
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.washer will not spin or ajatate. I need to remove - themobilian_27.pngthemobilian_27.png
Service manual and more HERE
Posted on Mar 16, 2011
Nd on screen will not spin
How to fix a Samsung Washernd washer error code. You can make this repair your self and in most cases without parts. Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain. When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front. If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise. If the front panel does not have the access panel the washer will need to be slide forward. With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible. Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Nov 10, 2012 | Samsung WF337AA Front Load Washer
Customer states washer will not drain/also reads ND on screen. Washer will spin when set to spin option. When set to regular wash the washer will not proceed with full wash stops and screen reads ND
the ND stand for NO DRAIN the filter on the pump is clogged,or the pump itself is clogged,the washer will not spin till it is drained,remove front panel by removing door and the screws that are opposite if it were hinged on othe side pop off front panel and check filter/pump for blockage
Aug 08, 2011 | Maytag Neptune MAH5500B Front Load Washer
The washer (#WBSR3140GWW) does not spin on the spin cycle and the clothes come out very wet. What could be wrong??
The most probable trouble is the belt is streched and needs replacing. To replace belt remove front panel by placing a putty knife about two inches inward from the ends of front panel push the putty knife in and release clips for front panel.remove panel and belt will on bottom under the motor. On a lot of GE washers the oil in transmission leaks and soaks belt in oil so soon new belt will be oil soaked and needing replacment again if ya see a lot of oil in base belt will fix temporarly till its oil soaked,the fix then is to replace washer since trans. replacement is more than new washer
Gene
Aug 03, 2011 | General Electric WBSR3140GWW Top Load...
How do you remove the ajatator
watch this video it will show you how to remove the agitator
http://youtu.be/N26MCQKuXn0
Jul 22, 2011 | General Electric WBB2090G Top Load Washer
My kenmore elite washer has a very loud banging noise when it spins
U will need to remove the washer drum and check the washer drum stablizers and the washer drum bearing, do this to see what is wrong and how far u need to go in this repair.First open the door and spin the inner tub to make sure the tub spins freely, if not you have big problems.
If it does then remove the lower front panel. There are 3 screws along the very bottom of this panel that you can remove and then the panel will come off. Check to make sure the shocks are not cracked or broken under the tub. If not and the unit just recently started shaking a lot, then replace the shocks as they are probably worn out. If it's been shaking since the day you've gotten it and it just seems to have gotten a little worse, then purchase Shake Away pads which are specifically designed for front load washers to sit under the feet of the washer and reduce vibration dramatically.
May 07, 2010 | Washing Machines
Loud noise during spin cycle
what kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
Jan 31, 2010 | Washing Machines
I think a overloaded the washer and it wouldnt spin.
Frigidaire washer will not take a overloaded tub without causing belt problems.
Unplug the washer.
Remove the 2 screws on the very bottom of the front washer panel.
Slide the front panel down slightly and remove it from the cabinet.
Inspect the belt around the motor pulley and transmission.
If it is worn at all it needs replacing.
You could plug the washer back in and set it to Spin cycle and watch for the motor to turn and the belt slipping to verify a bad belt.
Keep your hands,fingers and tools away from all moving parts.
Jan 24, 2010 | Frigidaire FGX831F Top Load Stacked Washer...
I cannot remove the basket from the tub.
i am a maintenance man at U OF I and need to change the tube seal on this washer but dont know how to remove the ajatator btoolmanA illicom.net
May 12, 2009 | Whirlpool LCR7244H Top Load Washer
Front load washer wont spin
it must drain before it will spin.if water is standing in it .remove power take off frount panel.remove screws that keep pump onthe washer move towards bucket and open pump and clean out.God bless tom
Dec 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE Profile WPRE6150KWT Colossal Capacity Washer Logo
1,243 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
