Question about Nikon D90 Digital Camera with 18-105mm lens
The access lamp is blinking even when the camera is turned off.
    Champion:
  • 226 Answers
Hi rhie_honey, this is normal when you put the memory card.
Regards
Posted on Mar 19, 2011
Why is red light blinking
The red lamp you are referring to is called the Access Lamp. This lamp usually illuminates if the camera is reading or writing information to the memory card. If this is blinking erratically, this could indicate an issue with the memory card. It is recommended that you try using another memory card with the camera to isolate the issue
Jan 20, 2015 | Cameras
Memory access lamp continually blinks even when off...camera functions normally( as far as I can tell) but lamp drains battery even when off
This may be that your memory card has a fault and the camera is trying to write to it.
Can you try another memory card?
Memory cards can develop faults.
A memory card format in the camera may help but this will wipe all your photos.
Jun 16, 2011 | Nikon D90 Digital Camera with 18-105mm...
When i try to turn my camera on it flashes a small red light and then it won't turn on, how do i fix this?
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
Oct 21, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Nikon D90 Memory Card Access Blinking
It's a deadly common problem of D90. Fixation:Simply go to the DSLR repair shop and ask them to change the power circuit board of the camera. Will take $60-70 if the board available. Reason of issue:The power control IC get short and feedback the battery power to the battery causing the draining out and other problem like the top LCD back lamp turned ON after turning on the camera. Careful:To avoid this issue in future, after full charge of the battery, do not put it in the camera right then. Wait for the battery to cool down for 5-10 min and then put it in. With the full charge, the battery hold high ampere for a short time. It could damage the power distributor IC suddenly if you put it in the camera right after a full charge. Best, Leo>>from personal experience<<
Jun 14, 2009 | Nikon D90 Digital Camera with 18-105mm...
New Nikon d90 the memory access lamp does not stop blinking
I'm experiencing similar problem, but when i connect it to computer via USB , it seems to go away.
Problem resurfaced again after a week.
Jun 09, 2009 | Nikon D90 Digital Camera with 18-105mm...
Memory access lamp flashes
WHEN POUTTING INN A MEMORY CARD ON NIKON DSLR CAMERAS THE GREEN LIGHT WILL BLINK ONE TIME .
IF IT CONTINUES TO BLINK THE CARD COULD BE BAD AND TRY TO FORMAT IT .
ALSO YOU COULD HAVE A BAD COMPRESSION BOARD.
Oct 29, 2008 | Nikon D70s Digital Camera
Sony DSC H7 Access lamp always on
the battery is not in good condition.you need to charge the battery adequeately and also check the green ligt in the charger when you plug in.
Oct 22, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Nikon D90 Digital Camera with 18-105mm lens Logo
109 people viewed this question
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
