Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a kingstrone flash disk 16gb and the usb itself has bee broken so i get a 2gb flash and take the usb from it and put it in the 16gb and i tried to put it in computer but it alwyes have alight and no response so did anyone would help my by a circuit digram or something like that thks
  • Kingston Master
  • 27,725 Answers
Click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Posted on Mar 16, 2011
How much price 8gb 4gb,2gb and memory card 4gb, 2gb
what country are you in?
2GB and 4GB will be extremely hard to find unless on clearence
8GB is soon being phased out
16GB is average these days
Sep 29, 2015 | Electronics - Others
16gb pendrive
try to format it using this program http://www.softpedia.com/get/System/Hard-Disk-Utils/HP-USB-Disk-Storage-Format-Tool.shtml
May 22, 2013 | Kingston 16GB 16G 16 GB DataTraveler...
Please insert disk into removable disk
have you tried other a different flash drive of something like a usb charger etc? If it works then then the problem is with the flash drive, if not them its with your USB port
Apr 28, 2013 | Kingston 16GB 16G 16 GB DataTraveler...
My tv does not support san disk 16gb cruzar blade
The device may be of "too low of quality"-- meaning..the device may be too "SLOW" to record the stuff you want to record...
Lower (cheaper) storage, is often not as "FAST" to record, as higher quality device... sadly.. the simple solution..return the device, and try another.
Nothing wrong with your TV....
Oct 16, 2012 | SanDisk 16GB Cruzer Blade - USB Flash...
My new imation usb 16gb is only 14.4gb in its actual properties, is this normal?
it is normal that you dont get the exact allocation size on disk itself and on the disk label, normally it only has a 500 to 800 mb difference.
Sep 04, 2012 | Imation 16GB USB Flash Drive 27125
Hi there, I have SanDisk 16GB Cruzer Slice USB Flash Drive and every time i put it into the computer, it can't be read nor located. In the beginning i was able to use it, but after two weeks i got this...
Try reformatting it to FAT32 ... instead of MacOS Extended Journaled:
**THIS WILL DELETE ALL THE DATA ON THE DRIVE**
1. Open Finder
2. Applications 3. On the left column, you should see your thumb drive. Click on it.
4. Click on the "Erase" tab near the top
5. For "Format:" select "FAT32"
6. Click on the "Erase..." button
Nov 25, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have sandisk cruzer 16gb. When i try to copy file more then 2gb i get an error: the disk in the destination drive is full. why I'm getting this error? thanks
If the flash drive is not full its because the format that a flash drive uses is FAT32 and that wont let you copy anything over 2Gb's im pretty sure
Aug 09, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a 16gb flash usb drive and it sais write
well u should format it...**** how?
there is some programes that can make the format (rather then the right click format cz it wont work), and there is a 75% working solution.....
controle pannel.....administrative tools....device managment.....drive managment(or somthin similer)...,
there u will see your flash , right click and format. done!
if not google under "usb softwares"... gd luck
Oct 24, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Will a San disk 2mg Micro Sd Memory card fit in a Lg Cookie
according to reviews yes up to 16gb MSD
http://www.gsmarena.com/lg_kp500_cookie-2536.php
Aug 14, 2009 | SanDisk 2GB microSD Memory Card
Pny 16gb attachi flash drive reccognized by my computer but says insert disk into drive when I left click it
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Apr 14, 2009 | PNY Attach? 16GB USB 2.0 Flash Drive
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
87 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
