Question about Casio fx-300ES Calculator
In the bottom of the screen where the answer goes it says 0x10 to the 0 power and i want to know hot to get rid of it
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
If you want to set the calculator to display a fixed number of decimal digits, press SHIFT MODE 6 then the number of digits to the right of the decimal point. If you want a floating decimal display, press SHIFT MODE 8 then 1 or 2 to select NORM1 or NORM2 mode. Either way, if the magnitude of a number is too small or too large to display normally, the calculator will switch to scientific notation. This is all on page E-8 of the manual.
Posted on Mar 16, 2011
I'm unable to get rid of digital display boxes at the bottom of my screan
See previous answer to almost identical question you posted.
Mar 16, 2012 | Hitachi Televison & Video
I cant view the whole screen, the top and bottom are cut off?
thats normal if you have a wide screen tv. either your tv or your cable box must set your picture to zoom or stretch to get rid of the bars. via cable box its in settings then aspect ratio or display settings and same goes for the tv. let me know if this helped.
Mar 17, 2011 | Televison & Video
Westinghouse 26 ..... TV will turn on and stay on for about 5 minutes and then screen goes black.... used to be able to turn it off and then it would come back on and stay on.. now it doesnt
Hello TRH12300, there is a few things missing to be able to completely answer your question, for example when the TV goes black can you still hear the audio? What is the color of the power indicator light at the bottom of the screen? What is the model # you are talking about. This could be several thing with the most common one being the inverter board but with out knowing the model # I cannot tell you if it is a LIPS (power/invert board), inverter board itself, or it can also be the T-Con board or the main board. What I can do is please send me an email answering all the questions asked here to westytech@westinghousedigital.com so I can help answer your questions and get your TV back up and running in no time. Also once we are done please rate my answer.
Feb 05, 2011 | Westinghouse 26" LCD Flat-Panel HDTV
Acer black screen no beep with memory taken out
Check if you have image connecting an external monitor to laptop.
Oct 17, 2009 | Acer Aspire 5100 Notebook
Power supply connection for pioneer eq-6500
top left - orange.....goes to aux or memory wire
top right - blue.......goes to the remote wire used with amps
bottom left - black.......goes to the ground wire
bottom right - red........this goes to your hot wire
May 31, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
I installed a now 40 gal. electric water heater, made by Reliance, problem: I have power going to the top thermostat and element, but there is no power going to the bottom element.please help, thanks Mike...
How they work. First you need to know that cold water goes into the tank near the bottom (because of the "dip tube" inside the tank) and hot water is taken out at the top. Also hot water naturally rises.
so... when the tank is full of cold water the top element will come on and heat up the top 1/3 of the water then the bottom element will come on and finish heating the rest of the tank.
Apr 19, 2009 | Water Heaters
Problem with letter stick on screen
Hold 2 volume controls down together until the P goes
Sep 01, 2008 | Thomson 24WK25U 24" TV
Zenith D60WLCD
Long story short: The blue fog problse is the light engine. Specificaly, the filter for the blue LCD gets to hot and over time starts to burn up and disinigrate. (I just tore my set apart thinking maybe it was the blue panel and found this was indeed the culprit for this problem). As far as a solution? You will either need to replace the light engine (expensive) or replace the light filter which means tearing the thing completely apart. then there is the problem of where to get a replacement filter. Does ANYONE know where? As far as the lamp goes, might be time to replace it. You might be better off just getting rid of that TV and get a new one.
Jul 18, 2008 | Zenith D60WLCD Television
Hi All,, I have a Fjitsu Siemens Amilo Pro V2060,, It`s working fine then screen goes blank,,greenish colour, i switch off, then on again everything fine,, this is periodic,, I have also noticed,, on...
Sounds like it is getting too hot. NEVER USE YOUR LAPTOP WITHOUT BEING PROPPED UP. Use a fan to blow on it while it is propped up.
Laptops breath from the bottom. If you leave it flat, it will get too hot. Also check the inside for dust or dog hair. Be very careful taking a laptop apart. Some mnfr sites have step by step directions. Do not take it apart if you are not sure that you can. You might be lucky that it is not damaged because a Pentium will shut down when it gets too hot most of the time.
Rate me if this helps.
May 29, 2008 | Siemens Computers & Internet
Casio fx-300ES Calculator Logo
85 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
