Question about Brother MFC 6800 All-In-One Laser Printer
After paper jam am getting error 77
After clearing a paper jam I Got error 77 called factory support (india) told to turn on while pressing menue. message came up tp unplug and send to repair station,
  • 6,487 Answers
Try this one:
1) Unplug machine.
2) Hold down menu key while plugging in machine.
3) Enter 99 while holding down menu key
4) After it says "PLease wait" hit the stop/exit button to get out of the maintenance mode
Hope that helps.....
Posted on Aug 01, 2008
What is mean by call sevices code H5-01 in sharp mx printer
H5-01 means repeated paper jams on the Sharp photocopiers.
Once the paper jam is cleared properly, you need to clear the error condition.
Put it in 'Copy' mode
Press on the keypad:
P * C * 14
Click execute and press 'Yes'
Then press the 'Copy' tab.
This will reset the menu and jam condition.
May 21, 2015 | Sharp Office Equipment & Supplies
How can solve error H5 in sharp 5516s?
P * C * 14
Oct 04, 2014 | Office Equipment & Supplies
My display screen on my Brother MFC-240C says "Paper Jam" and there is no jam. How do I reset it?
You press Menu/Set 2,0,3, then press up/down arrows set faxibility to on. Press menu/Set, then press up/down arrows to turn call waiting on or off. Press Menu/Set and lastly press Exit/Stop.
Sep 12, 2012 | Brother Multi-Function Center MFC-240C...
Machine is on and showing "error message #77 and says to unplug machine and call dealer. What is error 77?
Error #77 refers to a mechanical problem, but I'd say about 7 times out of 10 it's a mistake. Fortunately, Brother fax machines have override commands :). Try this:
1. Turn the power off and unplug the power source.
2. Press and hold the menu button and plug in the power source (don't let go of the menu button!).
3. Hold the menu button for 5 seconds after plugging in the power source.
4. Release the menu button and press "91"
5. If the screen still shows the error code, press "99".
Hopefully this will override the error and you can get back to work :) .
Hope this helps! Good luck!
Aug 30, 2010 | Brother IntelliFAX 2800 Laser Fax
After clearing a paper jam on my MP460, I get another error message, 'the paper is jammed. Clear the paper and press [ok]', which can't be removed. Pressing [ok] has no effect and I can't get into the main...
A few possible solutions:
- Open the top of the printer and look along the print path for pieces of paper.
- Press the reset button.
- Turn off the printer first and then unplug it. Plug it back in and turn it on. Wait for it to start up.
Bot
Apr 12, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Error 77 is apprearing
Unplug the unit.
Hold down the menu key while plugging back in / powering up.
When finished initializing, hit 99.
Wait to status comes back and hit 91.
This supposedly happens due to a power surge or outage.
If this doesn't work for you try reversing the numbers above.
I have a bad memory, it might be 91 first then 99 but, you definately have to hold down the menu key.
Sep 11, 2008 | Brother IntelliFAX 4100 Laser Fax
Reset error codes for Canon imageRUNNER 3300i
We followed the instructions from your tech. on which buttons to press to get into the menu function and then followed the directions for clearing the error code. After that turned the printer off and back on and the error code reset and the printer worked like a champ.
Jul 02, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
2575 paper jam
This worked for me. If "Paper Jam" error message continues to appear after jam has been cleared, turn off power to printer. Navigate to Control Panel - Printers, right click on HP Photosmart 2570 series icon, click on Delete on drop down menu. This deletes printer from your system. Turn on power to printer. Printer will re-install (may need original installation disc, may not). "Paper Jam" error message should no longer appear.
Mar 27, 2008 | HP Photosmart 2575 All-In-One Printer,...
Brother IntelliFax 1840C
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If that doesnt give you the code then try going into service mode by pressin menu key then *, 2 , 8, 6, 4  super quick!! Display goes blank or Maintenence mode is displayed, if not... not quick enough, do again to you get it, then press 77 start, error should display. press 99 to exit Maintence mode, dont play with other numbers!!
a couple of the most common errors are
Error 41 needs new print head costly
error 46 waste ink full, need new waste tank
Whats yours?
Oct 30, 2007 | Brother IntelliFAX 1840C Plain Paper...
Brother MFC 6800 All-In-One Laser Printer Logo
264 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
