Question about Frigidaire Refrigerators
FMR14 Refrig stopped cooling. Compressor is working, but coolant appears to be leaking from inside.We will take apart to look inside for leak. Suggestions? Others have similar prob?
  • 142 Answers
SOURCE: Every 2 mins the compressor tries to go on and after 15 seconds stops.
If the compressor tries to go on every two minutes, then the relay is functioning.
1. If the compressor has failed, it might be getting hot and tripping the thermal overload to shut itself down. It will cycle like you say and will be unable to cool the fridge.
2.It's also possible that you have lost refrigerant from the system. When the compressor goes on, the pressure drops below a threshold value. The system sees that there is not enough pressure, and shuts down. Once the pressure rebuilds, it tries again.
3. If the fins in the rear of the fridge are clogged with dust/debris, the system will not be efficient enough to cool. I doubt this is the case as the compressor would generally just stay on for a long time... longer than 2 minutes.
Try turning the thermostat to the coldest setting possible for both the fridge and the freezer. If the unit still cycles off after 2 minutes, consider repair.
Posted on Mar 14, 2008
JOE LLAMA
  • 26 Answers
SOURCE: Subzero 611 Refrigerator not cooling, freezer fine
It sounds like a defective ref section evaporator. This is common, due to poor quality metal used in fabrication. If you call subzero, they will more than likely fix it as they are aware of this issue. It probably wont cost you anything if you get them involved.
Posted on Mar 31, 2008
22yooper
  • 828 Answers
SOURCE: Kitchenaid Superba compressor
The compressor relay is located on the compressor under a cover. Before you go to the compressor I would check for other problems that you can see and hear. If the compressor is running there is nothing wrong with its relay.
1. Check the condenser and make sure it is clear and free of dust.
2. If the compressor is cool or cold check for a bad temperature control.
3. Check the freezer compartment for frost on back wall.
Posted on May 30, 2008
  • 59 Answers
SOURCE: our fridge stopped cooling-the gas is leaking-any danger to us
NO ITS NOT A DANGER TO YOU FREON HAS NO HARMFUL GASES
Posted on Apr 30, 2009
zr800o1le
  • 19 Answers
SOURCE: Refrig/Freezer not cooling
"compressor not functioning". You Probably need a New Compressor. I have a Family Member whos Refrig/Freezer Compressor had to be replaced under Warranty when it was only 2 years Old.
Posted on May 12, 2009
I have a fmr14 combination vending machine thats notcooling
It probably needs regassing but may have a leak. a fridge engineer should advise.
Aug 25, 2014 | Retail Supplies
I have a goodman central air unit. It was not cooling had service man out the first one said the compressor. So he was sending someone out to replace the compressor. That guy said it was not the...
Calll him back out. It sounds like the air cond. is losing refrigerant rather quickly. When the refrig. leaks off, the compressor over heats and kicks off on internal overload. The first guy probably didn't see that, but the second guy caught it, but didn't check to see where the refrigerant leaked off. Call him back they should warranty the refrigerant if it is all leaked off again
Jul 16, 2011 | Goodman Heating & Cooling
My frost free fridge freezer comes on for five minutes every half hour and is not cooling very well, what's the reason for this?
1 Check the thermostat settings i.e. temperature control. Hope it is not on the lower number. 2 If the thermostat setting is OK then there is every possibility that the cooling gas has leaked out. Call the technician and get it recharged. 3 Also check the compressor that it is working properly.
Jul 31, 2010 | Refrigerators
1996 nissan maxima gle, 3.0L auto. There is Coolant leaking from the front of engine behind a/c compressor as best as i can tell. I know the engine has an enternal water pump, what is the best way to tell...
You will have to see it. There are dentist type mirrors available in auto parts strore that will allow for you to see it, PLEASE do this when the engine is relatively cool. e.g. start-up. The coolant generally travels straight down, although this is not always the case it is a good indication as to the locatioon of the leak. It is impossible for the coolant to leak from between the block and pan. It appears so as the coolant travels along the rim of the oil pan on its way to the ground. If you can get a thin cardboard strips in there you can tell where the wet starts and stops
Mar 21, 2010 | 1996 Nissan Maxima
Loosing coolant no visible leaks about 1/2 gallon every 100 miles
How To Find & Fix Coolant Leaks
WHERE COOLANT LEAKS OCCUR
Coolant leaks can occur anywhere in the cooling system. Nine out of ten times, coolant leaks are easy to find because the coolant can be seen dripping, spraying, seeping or bubbling from the leaky component. Open the hood and visually inspect the engine and cooling system for any sign of liquid leaking from the engine, radiator or hoses. The color of the coolant may be green, orange or yellow depending on the type of antifreeze in the system. The most common places where coolant may be leaking are:
Water pump -- A bad shaft seal will allow coolant to dribble out of the vent hole just under the water pump pulley shaft. If the water pump is a two-piece unit with a backing plate, the gasket between the housing and back cover may be leaking. The gasket or o-ring that seals the pump to the engine front cover on cover-mounted water pumps can also leak coolant. Look for stains, discoloration or liquid coolant on the outside of the water pump or engine.
Radiator -- Radiators can develop leaks around upper or loser hose connections as a result of vibration. The seams where the core is mated to the end tanks is another place where leaks frequently develop, especially on aluminum radiators with plastic end tanks. On copper/brass radiators, leaks typically occur where the cooling tubes in the core are connected or soldered to the core headers. The core itself is also vulnerable to stone damage. Internal corrosion caused by old coolant that has never been changed can also eat through the metal in the radiator, causing it to leak.
Most cooling systems today are designed to operate at 8 to 14 psi. If the radiator can't hold pressure, your engine will overheat and lose coolant.
Hoses -- Cracks, pinholes or splits in a radiator hose or heater hose will leak coolant. A hose leak will usually send a stream of hot coolant spraying out of the hose. A corroded hose connection or a loose or damaged hose clamp may also allow coolant to leak from the end of a hose. Sometimes the leak may only occur once the hose gets hot and the pinhole or crack opens up.
Freeze plugs -- These are the casting plugs or expansion plugs in the sides of the engine block and/or cylinder head. The flat steel plugs corroded from the inside out, and may develop leaks that are hard to see because of the plug's location behind the exhaust manifold, engine mount or other engine accessories. On V6 and V8 blocks, the plugs are most easily inspected from underneath the vehicle.
Heater Core -- The heater core is located inside the heating ventilation and air conditioning (HVAC) unit under the dash. It is out of sight so you cannot see a leak directly. But if the heater core is leaking (or a hose connection to the heater core is leaking), coolant will be seeping out of the bottom of the HVAC unit and dripping on the floor inside the passenger compartment. Look for stains or wet spots on the bottom of the plastic HVAC case, or on the passenger side floor.
Intake Manifold gasket -- The gasket that seals the intake manifold to the cylinder heads may leak and allow coolant to enter the intake port, crankcase or dribble down the outside of the engine. Some engines such as General Motors 3.1L and 3.4L V6 engines as well as 4.3L, 5.0L and 5.7L V8s are notorious for leaky intake manifold gaskets. The intake manifold gaskets on these engines are plastic and often fail at 50,000 to 80,000 miles. Other troublesome applications include the intake manifold gaskets on Buick 3800 V6 and Ford 4.0L V6 engines.
INTERNAL COOLANT LEAKS
There are the worst kind of coolant leaks for two reasons. One is that they are impossible to see because they are hidden inside the engine. The other is that internal coolant leaks can be very expensive to repair.
Bad head gasket --Internal coolant leaks are most often due to a bad head gasket. The head gasket may leak coolant into a cylinder, or into the crankcase. Coolant leaks into the crankcase dilute the oil and can damage the bearings in your engine. A head gasket leaking coolant into a cylinder can foul the spark plug, and create a lot of white smoke in the exhaust. Adding sealer to the cooling system may plug the leak if it is not too bad, but eventually the head gasket will have to be replaced.
If you suspect a head gasket leak, have the cooling system pressure tested. If it fails to hold pressure, there is an internal leak. A "block tester" can also be used to diagnose a leaky head gasket. This device draws air from the cooling system into a chamber that contains a special blue colored leak detection liquid. Combustion gases will react with the liquid and cause it to change color from blue to green if the head gasket is leaking.
Head gasket failures are often the result of engine overheating (which may have occurred because of a coolant leak elsewhere in the cooling system, a bad thermostat, or an electric cooling fan not working). When the engine overheats, thermal expansion can crush and damage portions of the head gasket. This damaged areas may then start to leak combustion pressure and/or coolant.
Cracked Head or Block -- Internal coolant leaks can also occur if the cylinder head or engine block has a crack in a cooling jacket. A combustion chamber leak in the cylinder head or block will leak coolant into the cylinder. This dilutes the oil on the cylinder walls and can damage the piston and rings. If the coolant contains silicates (conventional green antifreeze), it can also foul the oxygen sensor and catalytic converter. If enough coolant leaks into the cylinder (as when the engine is sitting overnight), it may even hydro-lock the engine and prevent it from cranking when you try to start it. Internal leaks such as these can be diagnosed by pressure testing the cooling system or using a block checker.
A coolant leak into the crankcase is also bad news because it can damage the bearings. Coolant leaking into the crankcase will make the oil level on the dipstick appear to be higher than normal. The oil may also appear frothy, muddy or discolored because of the coolant contamination.
Leaky ATF oil cooler -- Internal coolant leakage can also occur in the automatic transmission fluid oil cooler inside the radiator. On most vehicles with automatic transmissions, ATF is routed through an oil cooler inside the radiator. If the tubing leaks, coolant can enter the transmission lines, contaminate the fluid and ruin the transmission. Red or brown drops of oil in the coolant would be a symptom of such a leak. Because the oil cooler is inside the radiator, the radiator must be replaced to eliminate the problem. The transmission fluid should also be changed.
continue...
Mar 12, 2010 | 1998 Oldsmobile 88
Loosing antifreeze
continue..
Mar 12, 2010 | 2007 Hummer H3X
My car runs hot very often when stopped but cools when accelerate
You may need to get the coolant system pressurized, with a coolant pressure tester to see if you have a small leak...and it sounds like it may be internal..which means you wont see the coolant on the floor, it is going inside the motor...possible small head gasket leak...
Nov 30, 2009 | 2002 Dodge Stratus
Refrigerator not cooling very well, upper freezer appears tobe ok
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 29, 2009 | Kenmore Refrigerators
Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
when you removed the back panel inside refrig was there any sign of cooling, perhaps only top 1 pass of the coil was frosted, or completly warm no signd of frost at all?
Feb 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
51 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
