Question about Tatung Televison & Video
The picture on my lcd, flat panel Tatung begins to flash pixelated pieces of the picture I'm watching. These pixels appear on the right bottom of the screen, (when your looking at the screen). If I reset the the tv using the reset button, this effect will stop and the picture is fine for about 15 minutes and then the flashing resumes. Everything else is working properly.
  • 1 more comment
  • Deborah Woodley Mar 16, 2011
    First, thanks for your prompt reply.
    I thought, at first, that it was a problem with my cable box or hdmi cables. I bought new hdmi cables and the problem persists. It also happens when watching a dvd or other medium. I'm sure it's the set.
    It was very helpful and a really quick reply. I am going to bite the bullet and give it a try.
    Thanks for the suggestion. I am going to give it a whirl, tomorrow.
    I did send a favorable comment. You've been great,
    President:
  • 1,654 Answers
Does this happen while watching the tv through a cable service or satallite service or does this also happen when watching a DVD through a player?
Pixelation occurs when the incoming signal to your TV is weak or incomplete. As a result, the TV doesn't have all the data it needs to process the image correctly, and pixelation occurs. In layman terms, it can be thought of as the TV's manifestation an incomplete image. The causes of this problem usually stems from incomplete or incorrect digital or analog signals. The other causes are weak cold solder joints in one or more of the buffer boards, or tuner on the set. If your handy and know how to solder, you can take the boards out of the set and look for bad solder joints on the board and simply re-solder them. If it is not the cable or satallite and your hesitant to take the boards out to look for bad soldering, then I suggest you have a tech look the set over. If it is still new enough that you have a warranty let the dealer who sold this to you take a look at it. Let me know how you wish to proceed.
Posted on Mar 16, 2011
  • Dcramer531
    Dcramer531 Mar 16, 2011
    I wish you the best of luck on this and if you could kindly give me a vote for helping I would appreciate it so that I can help others as well. You might also find that one of the boards is simply not seated good and this can also cause this, try checking the boards for looseness, but make sure the set is unplugged and has been off for at least an hour before doing this. There ae capacitors that store power in them and they can shock you.
  • Dcramer531
    Thank you and if you need furthur assistance feel free to contact me, if you still have the issue, get a repair shop to look at this and give you an estimate on a repair, they will or should be able to pin point the issue, and if I can help fix this with you on your own with the knowlege of the shop telling what the problem is, I will be glad to help.
Tip
"Aero features are'nt running in window's 7"
Solution: Check that your computer meets the minimum hardware requirements for running Aero:
1-gigahertz (GHz) 32-bit (x86) or 64-bit (x64) processor
1 gigabyte (GB) of random access memory (RAM)
128-megabyte (MB) graphics card
Aero also requires a DirectX 9 class graphics processor that supports a Windows Display Driver Model Driver, Pixel Shader 2.0 in hardware, and 32 bits per pixel.
For best results, you might also want to follow these graphics processor recommendations:
64 MB of graphics memory to support a single monitor with a resolution that is less than 1,310,720 pixels (for example, a 17–inch flat panel LCD monitor that has a 1280 × 1024 resolution)
128 MB of graphics memory to support a single monitor with a resolution from 1,310,720 to 2,304,000 pixels (for example, a 21.1–inch flat panel LCD monitor that has up to a 1600 × 1200 resolution)
256 MB of graphics memory to support a single monitor with a resolution greater than 2,304,000 pixels (for example, a 30–inch wide-screen flat panel LCD monitor that has up to a 2560 × 1600 resolution)
To turn on window frame transparency, the color scheme must first be set to Windows Aero.
1.Open Personalization by clicking the Start button Picture of the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
2.Click Window Color and Appearance.
3.Select the Enable transparency check box.
To change the color scheme to Windows Aero
1.Open Appearance Settings by clicking the Start button Picture of the Start button, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Window Color and Appearance. If the Appearance Settings dialog box is not displayed, at the bottom of the page, click Open classic appearance properties.
2.In the Color scheme list, click Windows Aero, and then click OK.
Check that your theme is an aero theme and not a normal theme. Themes are available in normal and aero and can be confusing. Set your theme as an aero theme and you should get the aero window working.
These steps will help us to have AERO running.
Thank's and Regard's:
Pcs365.8
on Jul 13, 2010 | Computers & Internet
Dead Pixels on Sharp Aquos 70" LED TV
If pixels are gone on all channels - Exchange it
Can't fix it yourself unless you are tv technician
It is quite common for few pixels to be dead but that is usualy not noticable
Feb 06, 2012 | Sharp LC70LE732U LCD TV
Sylvania 6632LCT 32" the bottom
Vertical colors bars appearing and disappering are the causes by the board that call the T-CON board it is dying or the fiber optic cable that connected to it lose or damages internally.Mostly of the times about 99% of the times the T-CON board it is dying and it is not decodering pixels codes correctly anymore before it send those pictures pixels codes to the tv LCD screen panel.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-CON board for the replacement.
Jun 29, 2011 | Sylvania 6632LCT 32 in. LCD Television
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
I have a samsung series 5 530 lcd. The picture is to big for the screen. I've tried everything in the manuel. help
Also, Check the picture menus for a pixel-to-pixel or 1-to-1 mode. This allows you to watch an HD signal with no overscan.
Jan 10, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Pro pixel LCD tv has sound but not picture, can see a flash when it is turned on but goes black
Refer to others I have posted to for this topic...defective lcd controller board.
Thanks
Josh
Oct 30, 2007 | Samsung LN-S4692D 46 in. LCD HDTV
Horizontal pixel line
I have seen this B4 here is a link that may help. http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Mar 31, 2007 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Televison & Video Logo
122 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
CoppellTVRepair.com
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
