Question about Pyle PL6984BL - 6"x 9" Four-Way Quad-axial Speaker System Car Speaker
I have the PL6984BL in my car that I just installed. The back right one sounds bad, with a slight buzz while bass is playing. This buzz goes away when i touch the cone from underneath, AND if i push up on the magnet at the bottom. Since they are new, and both of them aren't doing it (the other one sounds fine) I have no idea what could be wrong with this one.
I had the same problem and was able to fix it by tighening the big phillips head screw in the center of the rear of the speaker (under the blue lable). You will feel an indentation in the center of the blue label on the rear. Use an exacto blade to cut a 3/8" dia circle through it to expose the big phillips head screw. Add a liitle lock-tite and really crank it down snug. Doing this seemed to fix mine, though it could possibley be a coincidence.
-BostonEngineer
Posted on Oct 22, 2011
My tape decks buzz but when i touch it with my bare finger it goes away
It can be a bad ground inside the deck or broken solder joint. I have fixed this case often but can not tell you exactly the problem unless I see the unit.
Feb 15, 2014 | Technics RS-TR272 Single Cassette Deck
I have a 2000 Honda Accord and as I accelerate over 45 mph the care starts making a progressively louder humming/buzzing sound. When I turn slightly to the right the noise will go away. Any ideas wh
sounds like the wheels are out of balance, is there a slight vibration through the steering wheel at this speed? and does the problem stop if you go faster (please drive carefully)
Jan 24, 2012 | 2000 Honda Accord
They also try to play the bass
a crossover cuts the certain tones out of the sound.example: the high side cuts out low and mid tones,or the mid side cuts out high and low. The only problems this could be is that the crossover is not set right or not wired right. These speakers should be plugged into the high side of the crossover. If wired right and set right then your crossover is no good.
Mar 23, 2010 | Kicker KS13 Car Tweeter
Bass speaker buzzing
I've had this problem too multiple times. Usually when it happens, the battery dies soon after, and once I replace the battery, the buzzing goes away. If you are having the same problem as me, try putting a fresh battery in :)
Mar 09, 2010 | Skull Candy Skullcrushers Headset
Audio buzzing
Check the cables because this sound comes when the polarity of wires interreact with each other.
May 07, 2009 | Vizio GV42L 42 in. LCD Television
Perfect ten bass amp, guitar
can you use headphones? if so do they sound normal. probably have bad filter caps. 2200uf caps big ones, go bad and lose their capacitance and cant process the low end notes, sounds like a motorboat or ******* out. speaker may have issues as well. get the caps from mouser.com and careful of stored voltage on the capacitors it is deadly....... those caps are less than 2 bucks each.
Jan 21, 2009 | Ashdown Perfect 10 Bass Combo Amp Car...
Noise from speakers when playing basses
hello, check and see if cabinet has loose screws or if back panel is tight,bass can vibrate screw loose.good luck! also look for anything caught in the woofer causing the noise.
Jul 28, 2008 | Audio Players & Recorders
Buzzing bass Amp combo
The problem you have mentioned is a common one with old sets, but it also occurs in new ones also, though not frequent. You can fix this just by changing the electrolytic filter capacitors in the power supply and sub filters on the amp PCB. The new capacitors should be of the same or higher voltage rating and same capacity rating as of the existing ones. And as it is such an old one, it is better to change all the electrolytic capacitors to avoid any further problems.
Nov 23, 2007 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Pyle PL6984BL - 6"x 9" Four-Way Quad-axial Speaker System Car Speaker Logo
148 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
