Question about Ingersoll Rand 1/2" Super Duty Air Impact Wrench
Loosing too much air, loosing power - Ingersoll Rand 1/2" Super Duty Air Impact Wrench
    Sergeant:
  • 259 Answers
It sounds like you have to call the company and get a rebuild kit for that unit.
Posted on Mar 16, 2011
Gtr 1000 loosing power
Hi, Colin and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Damaged or restricted fuel tank venting system.
4. Dirty or damaged air cleaner element.
5. The accelerator pump is inoperative.
6. Vacuum piston assembly malfunction.
7. Enrichner valve is not seated or leaking.
8. Restricted fuel supply tract.
9. Plugged bowl vent.
10. Loose or plugged fuel and air jets or passages.
11. Improper fuel level.
12. Worn or damaged needle or needle jet.
13. Loose or plugged main jets or passages.
For more information about your issue please visit the websites below. Good luck and have a nice day.
http://www.tradebit.com/filesharing.php/search/0/kawasak+gtr+1000
Sep 12, 2015 | Power Motorcycles
Loosing pump suction when vacuum pool
keep out all the air inside the lines. When Pumps loose power suction is because there is some air inside the lines.exaust the air inside the lines
Aug 08, 2014 | Intex 2100 Gph 95 Hp Sand Filter Pump With...
Why dont my car gain power ?
check air filter < clean or replace > check air mass, replace ,
check air Vacuum hoses if remove or cut out .check solenoid valve vacuum if working by S.w on and off (click sound when on )
Jul 25, 2014 | Skoda Fabia Cars & Trucks
Lacks power as you push throuttle down
Robert Knorr: Check your Air Filter, may be clogged with oil or dirty. chocking off the air . idle is ok need less air. acceleration need more air , can't be done..bigAl
Apr 19, 2014 | 1993 Dodge Shadow
ENGINE LOOSES POWER
i would check high flow air meter located on air intake
Feb 05, 2014 | 1999 Volkswagen Passat
Engine warning light say "engine over heating" and heater blows only cold air and the vehicle looses speed
Loosing power is probably the computer trying to protect the engine from damage. The actual problem could be low coolant or a problem with the water pump.
Jan 30, 2014 | 2008 BMW 535i Sedan
Power steering hose came loose right front part of car all the fluid ran out. Can I screw it back together/
Yes, if it just came loose, you can just screw it back in snug, the re-fill power steering fluid. Start the car, idle for a few seconds, then turn off and check fluid level beacuse the air will need to bleed out. power steering is a re-circulating system, so the air will just bleed out when it reaches the resevoir.
Oct 16, 2011 | Cars & Trucks
No power to my wall sleeve air conditioning unit. Outlet has power.
its very common with all the vibration within the wall unit for wires to come loose try tighting all wires if this does not work call a tech it should simply be a loose cable ..very common
Jun 24, 2010 | Sharp Comfort Touch AF-R120EX Air...
I'm loosing air on my 3hp air compressor, as soon as i pull that trigger on my compressor for about 2 second it looses air. No holes in the air hose nothing is wrong but just loosing air
Are you talking about the power switch or the trigger of an air tool?
If it is the power switch then how much air are you losing?
At start up most air compressors will lose a small amount of air through the unloader valve. As the compressor builds psi this valve will close. Once the max psi is reached the motor will shut off then a few seconds later the unloader valve will open again releasing the pressure in the cylinder. If your leak does not abate as psi builds you might need to replace your switch and valve.
Mar 26, 2009 | Air Tools & Compressors
Infinite Switch Replacement
one switch cant affect them all check for a central power problem low voltage weak breaker loose wires on cord loose terminals in outlet box etc.
Feb 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Ingersoll Rand  1/2" Super Duty Air Impact Wrench Logo
168 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
