Got a tv and it has a german plug. The plug was changed to a regular one and with an antanea it only plays 2 channels. If hooked up to cable will it play those channels through cable?
    Problem Solver:
  • 5 Answers
I don't see why it wouldn't unless the cable plug on the TV is bad or the circuit that goes to that plug. Get cable and try it or take it to a friends house that has cable and see if it works
Posted on Aug 01, 2008
On TV1 screen stays blue and no sound go to AV1 DVDplayer have pic and sound The tv was given to told it worked is it a code
Did you scan for channels after hooking up the antenna?
Have the tv scan for available channels in your area.
Should be on the tv menu to scan for digital or analog channels.
Feb 05, 2016 | Olevia LT27HVX 27 in. LCD Television
Connecting to a video game console
Hooking your PS2 Up To your Stereo
Just got a PS2 and trying to hook it up to your TV, stereo or both? Here are instructions to help you get everything working smoothly.
First, some basic cable definitions. These are pretty much standard for ANY system or stereo you ever get, so it's good to learn them.
RED CABLE - right channel for stereo sound (get it - Red Right?)
WHITE CABLE - left channel for stereo sound
YELLOW CABLE - video signal
Your PS2 plays games and plays DVDs. So it is generating signals that go OUT of that box. You want those signals to go IN to your TV. The most simple way to do this is to simply plug them into your TV, if you have no stereo system hooked up and nothing else attached to your TV. Most TVs have stereo left in, stereo right in, and video in. Most in fact have them all color coded with the above colors. So all you do is plug the cables in and turn the TV on. Some TVs have to be set to channel 2 or 3 to know to take the signal in from the Video In line, but your manual would tell you if that was the case. Here is a diagram of the straight connection.
I would really recommend hooking a stereo system into your TV, though. The PS2 has INCREDIBLY stereo sound and you really miss out on a lot if you just have the sound coming out of your TV speakers!! Especially if you play DVDs through your PS2, you want that sound coming out of the stereo system. So in this case you would send the video to your TV, so your TV can show the picture. You then send your audio (sound) to the stereo, so it can play the sound. Most stereo systems have multiple input spots so you can plug in your CD player, your tape player, your record player, etc. So just choose an input spot that isn't taken yet. Here's an image of that connection -
So let's say you don't have a tape player and therefore plug the red cable into "Tape Input R" and plug the white cable into "Tape Input L". To make the sound play, you would now press the "Tape" selection button on your stereo so it played the music coming through the tape channel. Since that's where your PS2 is plugged in, that is the sound that will come out of your speakers.
Jan 29, 2008 | TruTech PVS31170S1W 17 in. LCD Television
How to set up tv to vcr
Hook cable or antenna to in on vcr, hook either with cable from out on vcr to tv. Have tv on 3 or 4---most sets have slide switch on back of vcr.
turn both on and use vcr to change channels if you want or to play or record a movie. If not using vcr turn it off and change channels in regular fashion on the tv.
Mar 18, 2012 | Philips Televison & Video
My son bought this TV and had it hooked up to a cable connection with an HDMI cable and it worked fine. He gave the TV to me and I hooked it up to a basic cable connection with no cable box. It does not...
If your TV has an On-screen Menu you should be able to access your Tuner controls. Run your auto channel scan and you should pick up your "regular channels". You may be able to de-select the odd channels and show only the ones you want to use.
Oct 03, 2011 | Westinghouse LTV32W6HD 32 in. LCD...
How can I get my Denon 2106 to play through my television? I'm not sure what's happened. I feel like I have the cables hooked up properly. It's worked for years. My stereo plays, so it's not the speakers....
Hello: If you are trying to get the sound from the TV to come through the receiver to your speakers and are hearing nothing, I had the same problem. For some reason, and I have the question posted, the sound level requirement is much higher for the TV. I turned my receiver up to +2 decibels and the sound was there. However, if you play high def channels through the receiver, the +2 will blow your ears off. My new problem is why does the regular TV need so much volume on the dial while the high def channels only require the lower sound level. It prevents you from switching from regular to high definition channels. So, in summary, the sound is there, just turn the volume way up.
Oct 30, 2010 | Denon AVR-2106 Receiver
Cable box-dvd/vcr- tv hookup problems
buy you one of those little boxes from like walmart,,that converts rca jacks to cable pugs ,,,there real cheap,,that will do it ,,in the electrinic isle,,
May 17, 2009 | Philips Magnavox DVD/VCR Dual Player
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Just want the Orion TV (Model: STV 2763) to play VHS videos
Problem Solved:
Take your connector with the 3 colors red,white & yellow and plug into VCR OUT. The other end (w/ 3 plugs) goes into the INPUT on the back of the TV. Next insert a VHS Tape & search the TV for input or a channel below #2 for Cable#1,2,3 or AUV Channel.
In this case; Channel AUX #1
Shows / Plays Video w/ clear sound & picture.
Yahoo.
May 21, 2008 | Orion STV2763 27" TV
How to hook up cable and get more channels than 2-13????
Change setting in menu to cable from tv or antenna. May be in channel setup menu.
May 12, 2008 | Televison & Video
TV will not get cable channels
If you have it hooked up to a digital box, it shouldn't matter if the TV is on cable or antenna mode. The only thing that matters is that the TV is on channel 3. Channels will be changed on digital box. Some newer TV's use input 1 or 2 or AUX for it to work. If I were you i would hook everything up and start playing with the channels going up and down until you get a picture.
Dec 28, 2006 | Orion1934 19" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
