Question about Orion1934 19" TV
Orion Orion1934 19" TV When I
  • 902 Answers
If you are conncting it over component cable check your cables in the right spots if rca *red yellow nad white) then the cables may be bad or the refresh rate needs to be changed make sure the dvd player is selecting the correct output you are using.
Posted on Mar 16, 2011
How do i connect Orion DVD Player to LG Television with out a remote control.
The best option would be the HDMI-to-HDMI connection between your player and your TV. But because you mentioned that your TV is an old model, probably it does not have an HDMI port, in which case you have to use the RCA A/V connection. I understand you do not have a remote control for your TV, but you do not program a TV channel to watch DVD movies; you just switch between your TV and the DVD player as your audio/video sources. Here is what you have to do: check on your TV box for a button labeled 'Source' or 'Input'. Press on the button and it will alternate between TV and DVD (assuming you do not have any other device hooked up to your TV).
Dec 17, 2014 | Orion BDP3959 Player
Tip
How to Fix a Polaroid LCD TV Screen
<p>A Polaroid LCD TV delivers its picture via DVD player or cable connection to your home or office. After setting up your device and using it, you might experience technical difficulties with power loss and picture quality. Navigating through a few steps of self-maintenance will have your Polaroid TV running smoothly again in little time. You can examine your TV's power cord for damage, rewire a DVD player connection, and adjust your Polaroid's backlight.<br /> Difficulty:Moderate <span>Instructions</span> <ol> <li> <ul> <li> <span></span> Turn your Polaroid around so that the back is facing you, as a first step in correcting a power loss issue. Examine the length of the power cord from the back panel of the Polaroid to the wall outlet for damage, such as tears or rips. Replace the cord, if you see damage. Unplug the TV from the wall outlet and inspect the metal receptors (prongs) for dirt. If the prongs are dirty, clean them with a dry cleaning cloth. Plug a separate electrical device into the outlet and turn it on to confirm that the outlet is performing correctly. Plug the Polaroid TV back into the outlet, and try again.<br /> </li> <li> <span></span> Twist the Polaroid TV's back panel towards you so that the connected cables and jacks are easily accessible to you. If you're experiencing problems getting a picture from your DVD player, inspect the connection of the audio/video cables to your "Composite In" jacks. There are three cables in a standard audio/video setup: a yellow cable, a red cable, and a white cable. Unplug all three cables from their jacks to reset the connection. Insert the yellow-tipped cable into the "Video" port, which is yellow-colored to make matching the cables easier. Insert the white-tipped cable into the "L" (left audio) port and the red-tipped cable into the "r" (right audio) port. Perform the same steps on the audio/video cable out ports of the DVD player, and try again.<br /> </li> <li> <span></span> Raise the TV's backlight level, if you're having trouble seeing the picture. Push the "Menu" button (located on your remote control), and the TV setup menu will appear. Use the navigation buttons located on your remote control to scroll to "Image," and push "Ok" -- located within the navigational buttons on your remote control. A list of options will be displayed, such as "Contrast," "Hue," and "Saturation." Choose "Brightness" from the options. Use the four-way navigation buttons to raise the brightness (make your screen brighter and more illuminated) or lower the brightness (make your screen darker).<br /> </li></ul> </li></ol>
on Dec 27, 2010 | Televison & Video
I pressed " setup" on
unplug the power from the TV and the DVD. Plug them back in and try. There is nothing in the tv menu that would knock out your picture, but the dvd player menu has a couple things that would. If unplug doesn't work, tell us what brand dvd player you have.
Feb 25, 2011 | Televison & Video
Orion tv without input/output plugs
from the looks of the picture you have one audio video input port on the front of the tv. The connectors are yellow and red or yellow and white. Yellow is video and red or white are audio. Find those same connectors on the back or your dvd player, hook it up to the tv and there you go. You'll have to go to game mode or input 2 on the tv to see the dvd player.
Jul 01, 2009 | Orion1934 19" TV
Memorex DVD problem -- rollig screen on TV
How is the dvd player connected to the tv?
Mar 21, 2009 | Memorex MVD2050-BLK DVD Player
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
Cyberhome 402 DVD "rolls"
I think I had switched to the PAL format by mistake. Fixed the problem by buying a new DVD player, was cheaper than the factory fix.
Jul 30, 2008 | Cyberhome CH-DVD 300 DVD Player
Orion1934 19" TV Logo
108 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
