Question about Crown Audio Players & Recorders
Speaker output knobs producing crackling sound from speaker
  • 26 Answers
The problem is that the potentiometer that the knob is connected to is dirty. This is a common problem with age, or quality of installed potentiometer. (potentiometer is the name of the component that the knob attaches to. It usually looks like a 1/2" long cylinder)
There are multiple solutions to this problem. The first is free & anyone can do. While the unit is off. Twist the knob back and forth quickly and rapidly numerous times. Roughly 10-15 times will do. This sometimes allows for the connections within the potentiometer to reconnect, and remove the crackle.
The second solution involves some handy work. The unit's case will have to be disassembled, and the potentiometer that the knob is attached to must be found. There is usually a relief hole somewhere on the housing. Within this relief hole one can spray contact cleaner. This cleans the contact within the potentiometer which is the cause of the crackle. Once the pot has been sprayed, rotate the knob like in step 1.
If steps 1 & 2 do not work, the potentiometer will need to be replaced. This work usually needs a professional. If you are handy with a soldering iron, it can be accomplished. Look for any particular part #'s on the crackly potentiometer, and then copy these into a online parts catalog. Mouser.com and Digikey.com are excellent resources for finding parts. Upon finding a replacement, it can be swapped out, and provide the user with a crackle free knob.
As always, make sure power to the unit is disconnected. If you are unsure of electronics, please use caution, as dangerous voltages may reside that can cause personal injury.
Posted on Mar 16, 2011
STEREO HAS NO SOUND OUT OF SPEAKERS COMING FROM AMP
I suggest you begin by checking the integrity of the speakers and wiring. This is a fairly easy test to perform and I usually used a pp3 9 volt battery across each pair of speaker wires to ensure each speaker produces a similar amount of crackle and hiss as the wires are wiped across the battery terminals.
Once that test has been performed and found to be satisfactory it is time to connect the wires to the output of the device; radio or amp.
If there is no sound it will be because there is no output from the device. At this point before calling the repair shop it would be a good idea to read the instruction manual to ensure the stereo is being operated correctly.
Aug 10, 2015 | JVC Car Audio & Video
Dell xps 15 L501x sub woofer giving crackling sound
hi you can detached or disconnected the subwoofer cable, for temporary or permanent fix, as the speaker sound also produced good quality sound..
here how i disconected the subwoofer cable, it easy to find at the bootoom, see also utube video inside the link given below
http://atozcs.net/dell-xps-l501x-subwoofer-produce-distorted-crackle-sound/
Aug 09, 2013 | Dell Xps 15 L502x Subwoofer Speaker Pn57g
Crackling speaker as soon as i switch on my digital piano
It looks like the Korg c-15s has a internally mounted speaker and so I will assume that the speaker and amplifier are part of the piano base. It sounds like either the speaker is blown (crackling sounds heard as deformed voice coil scrapes the magnet structure) or the audio amplifier is distorting the audio.
Connect the piano's output to an external amplifier and speaker to properly identify problem.
Oct 17, 2012 | Korg Music
M-audio av20 right speaker has no sound coming out of it at all...
To troubleshoot the problem start with the bit that is working - the left speaker.
  1. Unplug the input leads on the back of the left speaker and swap them round.
  2. If sound now comes out of right speaker and not the left the problem is with your sound source (computer, IPOD or whatever) or the connecting cable is faulty.
  3. If there is still no sound from the right speaker try turning the volume control knob up and down quickly several times - does this produce any sound from the right speaker? Sometimes the electrical contacts get dirty and this can help clean them.
  4. Turn the speakers off using the volume control knob. Disconnect the speaker wire for the right speaker from the OUTPUT on the left speaker (push the red and black tabs downwards and gently pull the wires out. Find a small 1.5 volt battery (an AA or AAA size will do nicely) and touch the bare ends of the speaker wire briefly on the battery terminals. If you hear a slight crackling sound the wire and the speaker are okay and the problem is in the amplifier, which will need repair or replacement - not a job for an amateur.
  5. If you don't get any sound from the battery test find another piece of speaker wire (any piece of 2 core cable with bare ends will do for testing) and repeat the battery test. If you get sound then replace the speaker wire. If not remove the speaker wire again and go to next step.
  6. Lay the speaker face downwards and carefully unscrew the back panel (don't do this if it is still under manufacturers warranty - take it back for repair or replacement). Lift the back panel off carefully and slowly taking care not to pull the connecting wires inside the cabinet, which will probably be quite short. You may have to settle for just rotating the back panel slightly so that you can see inside if the wires are too short to do otherwise.
  7. Use sticky tape to tightly attach the bare ends of the speaker wires to the terminals of the battery. Touch the loose ends of the speaker wires on the two metal terminals where the internal wires are joined onto the back of the big loudspeaker cone. If this produces a crackling sound it is the internal wiring in the cabinet that needs re-soldering. Otherwise the loudspeaker unit has failed and will need replacement.
Jan 29, 2011 | M-Audio Avid Maudio 99005226600...
Crackling sound from right speaker only
I'm not familiar with that model but I am familiar with the problem. If your unit has a volume knob or a balance control which is a potentiometer you need to clean them. Go to www.mcmelectronics.com where you can find spray cleaner. I like to use blue shower as it works well and will not hurt any components. When you get the cleaner unplug your unit and locate the volume control and any others which have a rotating knob. Usually near the top is a small hole which you can spray the cleaner in. Rotate the control and follow through several times. Try the unit and it should be ok. If it isn't you will have to replace the controls as the resistance material has worn off and they cannot be repaired. Let me know how you make out or if you need anymore help.
hardrocko
Thanks for using FixYa
Feb 18, 2010 | Pioneer Audio Players & Recorders
I sometimes lose sound from my left speaker and it crackles.
this is a speaker input pin problem, like pin is dameg or input pin is not atech proparly in computer problem is still present remove the cable and install new one cable in speaker
Mar 11, 2009 | Audio Players & Recorders
Crackling noise from subwoofer????
sgangsta91,
i think your speaker cannot support the sound that your computer produce. it means to say that, they are not compatible. specially when your computer sound interface that you used is 5.1 or 7.1 interface but your speaker specs is only for generic sound, you really hear a crackling sound and more if you set to higher volume.
but it can help if you only set your computer interface to generic sound or set only in lower volume it can help. because if you continue that way, your speaker can be seriously damaged that even at the lowest volume can hear the crackling sound.
or if you really want a fine good sound system then, buy a speaker that can interface with 5.1 or 7.1 or see manuals of your computer/motherboard. for recommended specs
aclamonte
Nov 07, 2008 | Logitech X-220 Computer Speakers
Loud crackling / popping
Well gd stuart i think you need some new speakers
Jan 27, 2008 | Logitech Z-2200 Computer Speakers
221 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
