Question about Sony Playstation 3 (PS3) Console
My PS3 recognizes the HDMI input, but when I attempt to change the settings, it won't work
I recently bought an HDMI to use with my PS3, and when I hook it up to both the TV and PS3, it doesn't work! The PS3 will recognize the HDMI cable, but when i change the settings, a blank screen shows up on the TV. I have to reset the PS3 by holding the power button for 5 seconds, and then it returns to the AV settings. I have an Xbox 360 and HD cable, and the TV supports them both. Is there any way I can get my PS3 to work with the HDMI cable? Help me please! Thanks!
  • 3 more comments
  • m1w04 Aug 01, 2008
    Ravege,
    Thanks for the response. Under settings when I go to display settings and video output settings, I select the HDMI cable instead of the component, and the screen goes blank for 30 seconds, and then soon returns to the previous settings, and not the HDMI. I still do not understand the problem. do you have any other idea of what I can do? Thanks again.
  • south985 Aug 28, 2008
    i played my ps3 on big screen tv & changed settings to hdmi,now i cant change settings back so i cant play on any other tv & my mother wont let me play on big screen any more pls help
  • Anonymous Nov 27, 2008
    it only works on my tv with hdmi hook ups when i bring it some were else i dont work i cant find no picture
  • kmac721 Nov 27, 2008
    it does the same as the others say
  • Anonymous Nov 29, 2008
    i have the same problem..hey Ravege what do u mean by u have to set it up on the ps3?..on the options?
    Sergeant:
    Champion:
  • 327 Answers
Welcome to fixya
you have to set it up on the ps3 for the cable
i had the same problem on the ps3 in settings there is hdmi cable set up make sure there set to hdmi and not to av wire
Posted on Aug 01, 2008
Playstation 3 works fine useing the av hook up but won;t work with hdmi cable hook up.
First, make sure your TV is on the appropriate input for the plugged in HDMI cable. Once this is completed, turn your ps3 on. If the screen comes on and is black, turn the ps3 to standby (red light is on) and hold the front power button until the console beeps a second time. This will usually force the ps3 to recognize the hdmi input and will bring up the menu to configure the AV settings.
Aug 13, 2014 | Sony Playstation 3 (PS3) Console
No signal input ps3
Try that PS3 on another TV or monitor with an HDMI input to check the PS3 is working ok. If it is try a different HDMI cable.
Dec 16, 2013 | Panasonic VIERA Televison & Video
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
Dynex tv works. bought ps3. when hooked up to
I would suggest you check if your PS3 is set up on going through the HDMI Cable.On your PS3's XMB scroll to settings -> Display Settings -> ANd from there go down to the one that says "Y Pb/Cb Pr/Cr Super-White (HDMI)" and hit X and select the option Yes... That sets the PS3 displaying through the HDMI
If you are already have done that I'm pretty sure you know you have to change the Input on your TV to HDMI... Take your remote and hit Input -> Scroll down to HDMI on the Input Source menu and hit Enter when you get to HDMI
If the AV on your PS3 works and not your HDMI sounds like Display Settings issue...
If you have done all that, that is strange if it still doesn't work.
There are some people that are having problems with the AV Cable with the PS3, I tried this and it really does work. I switched from HDMI on one tv to a AV Cable on another and when I did that neither TV would display content from my tv. The fix for this is resetting your PS3, like on a iDevice you hold the home button and lock button, for the PS3 you hold the Power off button and the Eject button for around 10 seconds. This resets your PS3 into default video settings. Until it Turns on, Beeps, and Turns off. This should work.
Jan 01, 2010 | Televison & Video
PS3 hdmi only working on some displays
I have noticed using an HDMI cable that with some of the newer tvs you have to set up the tv also to enable HDMI for a game system. Like you said before internet tv and blueray dvd player work fine. Try adjusting the settings on the tvs themselves. I have a 50in DLP mitsubishi, and had a very troubling time getting my ps3 to work on that particular tv set while it worked flawlessly on other sets. And what I had to do was enter my tv setup menu and then power on my ps3 with both my AV and HDMI cables connected, it would pick up the AV first. Then I would alter the video settings on the PS3 for HDMI, and unplug the AV cable. Exit the tv menu and then reenter it. Then I had to setup my HDMI port from the tv to game in order for it to work, where you can set options ar usually like cable/dvd/sat, and so on. Without my TV being set to game that way it would not work. Try this and see if it helps. Good Luck.
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
How do i turn on the hdmi setting to make a ps3 work
Turn off TV, unplug it from AC socket, plug PS3 in HDMI input, turn On PS3 and then turn On TV so TV will recognize PS3 through HDMI
Oct 10, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Connecting ps3 to home cinema
For sound use the Digital Coax in, if the PS3 has digital out. Most HiFi home cinema systems have HDMI with all channels audio through HDMI. Check cinema settings to configure input for hdmi audio, also check PS3 audio output setting options to include all supported audio type by your receiver. It's not just a plug and play. Both systems need to gor through a user setup process to make sure they sync and play well with each other.
Jul 24, 2009 | Audio Players & Recorders
Picture goes to a lime green fuzz and then no piture or sound!
which AV connection are you using? HDMI or the cable supplied with the PS3, If using HDMI, you have to set the PS3 visual settings to HDMI, to do this, use the cable supplied with the PS3, and have the HDMI cable plugged in. Then while using the cables supplied with the PS3, switch the settings over to HDMI, then change the TV's input selector to your HDMI and confirm the settings changes. Hope it helps take care
Oct 17, 2007 | Sony Playstation 3 (PS3) Console
HDMI connection
Check ur video input on ur tv dude,make sure it says hdmi in yop corner,and not svideo or anything else but hdmi
Aug 27, 2007 | Sony Playstation 3 (PS3) Console
PS3/HDMI issues
the cable you purchase does not support the connection on your set.
Jan 23, 2007 | Samsung TX-R2779H 27" TV
Sony Playstation 3 (PS3) Console Logo
631 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
