Question about iBuyPower Gamer Power A557D3 FPS Gaming Desktop (Red)
My iBUYPOWER Gamer Power A557D3 FPS Gaming Desktop want turn on have it pluged in and the little green light is on that shows the mother board has power but it want turn on
  • 1,179 Answers
The best thing to do is to claim warranty support on your computer system from the place of purchase, if however that otion is not available to you, you may go through my published guides. They are listed below:
How to Remove the Side Panels of My Computer Chassis!!!
My Computer is not turning on!!! Is it dead!!! No POST!!!
How do I reset my BIOS/CMOS to defaults?
The problem may be a loose connection, be sure to push in all drives and fan connectors as well as the 4Pin CPU and 24Pin Mainboard Power connectors.
Give it a clean if need be.
Thanks
damnor01
Posted on Mar 16, 2011
WA939SLC Desktop PC quick start guide
Search box type in the details, should show what you seek.
Dec 28, 2013 | iBuyPower Black Gamer Extreme WA939SLC...
COMPUTER WILL NOT TURN ON BUT THE MOTHER BOARD THE GREEN LIGHT IS ON..WILL NOT START UP..
For one the green light is just to show that it has power. its mostly there so you don't electrocute yourself. Are there any beeps when you try to turn it on? anything on the screen at all?
Aug 30, 2011 | Dell Dimension 4700 PC Desktop
I'm wondering how do I do a factory restore on my ibuypower wa500d3 PC I am getting a dll error and need to restore it for other problems (unwanted progams ect.)
use system restore click on : start / all programs / accessories / system tools / system restore
unless you got a factory system restore cd when you bought the computer with it, you could re-install a new copy of windows and install your drivers too
Aug 22, 2011 | iBuyPower Gamer Power WA500D3 Desktop PC...
Bought new power supply, no difference power button will not even go on or light up ; however small green light on mother board lights up. als accidentaly disconnected the switches wiring to the mother...
The green light just show that the motherboard is getting power.
The power button of the front of the case is connected to the mother board, not to the power supply, usually in the extreme lower left corner along with the with the HDD and Reset Button cords; Power button wire are labeled and usually red/black.
If all wired correctly, possible bad or stuck power button or reset button.
Hope this helps.
Please rate this answer by check rating "Hands"
Feb 08, 2011 | E-Machines T3958 (827103050974) PC Desktop
I have an iBUYPOWER Gamer Power 918i desktop computer. I hooked up a monitor using a VGA connection, I'm not getting any output from the monitor. Whenever I turn the monitor on it goes into sleep mode- as...
You may have a couple of problems here, with you saying it`s a gaming PC it most likely has a graphics card installed which will likely only have outputs for DVI or HDMI, VGA is not usually supported on newer cards. What you need to look for is on the back of the PC where you are plugging in your monitor are you inserting the plug vertically, i.e. straight up and down? if so this means you are connecting to the motherboards onboard graphics which will be disabled if you have a graphics card. If you are using a VGA monitor then most likely it is a blue plug on the board you are plugging into, if you have a graphics card then the most common outputs are what is called DVI which is a slightely bigger white plug. You need to look slightly lower down from the plug you are connecting to and see if there are one or two DVI sockets which will be mounted horizontally. If this is the case then the motherboard socket will be disabled, there are a couple of solutions to this though, you can remove the graphics card which will re enable the onboard graphics and allow you to use your monitor, you can buy a monitor with a DVI input or you can buy from most PC stores a DVI to VGA converter which lets you use your existing monitor with your graphics card although the frame rates and refresh may not be so good, the latter is the method I would recommend to get going.
Hope this helps and thanks for using fixya
John
Dec 25, 2010 | iBuyPower Gamer Power 918I Desktop...
I just bought an "iBUYPOWER
call ibuypower technical support. if you brought it from them
if it's under warranty call the company you brought it from.
if you try to fix it yourself, the may not take it back. and keep your money.
that being said make sure your monitor is plug in the right port from the picture I saw on newegg, they have two ports that it can plug into a blue vga port or a white dvi. you want to plug into the one on video card.
May 24, 2017 | iBuyPower Gamer Power 918I Desktop...
Windows 7 Will not past through the ''Welcome..'' Loading screen af
Why not login without creating an account. Then go to "Users" in control panel and setup your own account again.
Mar 21, 2010 | ACM Supplies iBuyPower Gaming Desktop...
No power,power supply seems ok,green light on mother board on. when pluged in the fan runs for a couple seconds and turns off.power button has no effect.
sounds like a mother board issue,
start with pulling out all ram chips and re try,,
then try pulling all cards out like old modem and also cdroms.
if ever thing but power is unpluged its a bad mother board or CPU chip
Mar 12, 2010 | E-Machines T3958 (827103050974) PC Desktop
HP Media Center Power Up Problem
replace the power supply-from a computer store, should be no more than 30 dollars
Nov 02, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
ASUS p4s533 will not start
Your motherboard is bad and will need to be replaced.
Thanks and please take a moment to rate as fixya. Thank you.
Jul 08, 2008 | ASUS P4S533 Motherboard
iBuyPower Gamer Power A557D3 FPS Gaming Desktop (Red) Logo
197 people viewed this question
Top iBuyPower Computers & Internet Experts
General Systems...
NOEL
NOEL
Robin Hill
Robin Hill
Are you an iBuyPower Computer and Internet Expert? Answer questions, earn points and help others
