Question about Targus AMU18US Mouse
My mosue did not work at all i used it before and i use on glass table what is the problem can somebody help me
  • 746 Answers
Use a mouse pad and don't use the glass table because many times it will not work on glass table.
Posted on Mar 16, 2011
  • Shahzad  Waseem Akbar
    Shahzad Waseem Akbar Mar 16, 2011
    Let me contact if the problem will exist and for further more information.
    Best of Luck
Tip
How to Clean Scanner Glass
Steps how to clean scanner glass
1. Unplug the power cord.
2. Clean the outer case with a cloth dampened with a mild detergent and water.
3. If the document table glass gets dirty, clean it with a soft dry cloth. If the glass is stained with grease or some other hard-to-remove material, use a small amount of glass cleaner and a soft cloth to remove it. Wipe off all remaining liquid.
4. Ensure that there is no dust on the glass of the document table. Dust can cause white spots in your scanned images.
*** CAUTION: Do not press on the document table glass too hard.
5. Be careful not to scratch or damage the document table glass, and do not use a hard or abrasive brush to clean it. A damaged glass surface can decrease the scanning quality.
6. Never use alcohol, paint thinner or corrosive solvent to clean the scanner. These chemicals can damage the scanner components as well as the case.
7. Be careful not to spill liquid into the scanner mechanism or electronic components. This could permanently damage the mechanism and circuitry.
8. Do not spray lubricants inside the scanner.
9. Never open the scanner case.
***NOTE: Wipe the inside of the document cover and the scanner's document table before scanning transparencies.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
How do ya cut plate glass and what tools are recommended?
Hi,If you want to cut glass left over form old project or somebody gave it to you for what ever reason the first thing you need to do is make sure that the glass is plate glass becouse if you try cutting tempered glass its going to blow in your face.
Usually tempered glass has a stamp somewhere in the corner which proves that is tempered and the company that tempered it. After you know for sure that your glass is plate glass you need:
1.Safety glasses
2.Glass gloves
3.Glass cutter
4.Straight edge
5.Cutting table or flat surface covered with felt or short hair carpet
6.Measuring tape
7.Clamps (to hold your straight edge while you score the surface)
The thing is you dont cut glass,you score it with the cutter and then brake it.Please let me know what kind of glass are you going to cut so I can be more specific.
Nov 19, 2014 | Building Materials
Where can I get glass to put on top of my end tables?
Below is a great website that specialized in making customglass table tops. They deliver all overthe country and have been reviewed very well. http://www.dullesglassandmirror.com/glass-table-tops.asp
May 29, 2012 | Furniture
How can I remove the scratches from my glass coffee table?
Unfortunately, there is no safe way to remove scratches from glass. I don't recommend trying anything at home because you could make it much worse. If you are bent on keeping the table I suggest taking it to glassworker to see if he can sand it down with special tools.
My Cordless Logitech keyboard and mouse stopped working and I don't know how to fix the problem.
hello
use another keyboard and mosue to access your PC.
the product came with CD, divers for the mosue/keyboard combination
reinstall the drivers onto the PC , then go to DEVICE MANAGER , make sure ther anrent any issues (yellow exclamation marks, are issues)
hope this helps -- if not, let me know what model computer you have as well as OS you use.
Nov 05, 2010 | Logitech Wireless Access Duo Optical...
Whenever I click on print with my logitech mouse it doesn't alwas work. I s there a battery in it? I do not see anyway to take it apaert.
have you installed the drivers for the mosue ? what model is it (part number or model number of the mosue)
Nov 03, 2010 | Logitech Cordless Mouse
Glass reinforced concrete composite stone table broken
Believe it or not Gorilla Glue holds that sort of thing quite well. You may have a visible line, but not too bad providing you keep the pieces held together tightly for an hour or so (it foams and expands -- scrape off the excess after it dries.) I would also get some epoxy (the thin stuff, not the putty stuff) and some fiberglass mesh and reinforce the bottom. Something else -- some contractors who do foundation repair have an epoxy and carbon fiber mesh that would do that and be indestructible -- see if you can find one in your area. I could give you someone in my area, but that probably wouldn't help you. You'll have to call around. If you can't find it, the fiberglass mesh is used in boat, RV, and tractor trailer repair so one of those shops should be able to sell you some.
Nov 02, 2009 | Welding Tools
What surface works best for cordless mouse
A flat dark surface works best. Glass won't work at all. I always prefer a mouse pad so that there are no imperfections on the table surface. Although, I did see a guy use one on his belly once.
Hope this helps.
Oct 25, 2009 | Logitech Cordless Mouse
Outer glas of the dor broken its a QA make built
I will give you summary instructions on how to repair the door outer glass on a built in kitchen.
Prepare a space on a table, where to work on the door. Cover the taple with newspaper.
Remove the door. On some model you may just need to lift and pull, on others you need to free the hinges, usually undoing few screws.
Put the door on the table. Remove fragments of splintered glass if the glass is falling apart, otherwise leave it all in one piece.
On the table remove the set of screws that are holding the external frame and glass.
Remove external glass and replace it. You can use pliers and a cloth if needed.
Do operations in revers order to refit new glass.
You can find parts here:
Appliance Parts -Research, Repair & Replace.
Oct 14, 2009 | Ovens
Targus AMU18US Mouse Logo
61 people viewed this question
Top Targus Computers & Internet Experts
dhnguyen
Josh Whitehead
Josh Whitehead
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
