Question about HP LaserJet 3030 All-In-One Printer
Hp laserjet 3030 problem
I re-installed my fuser roller, but now the message I keep receiving is "door open or no print cartridge." Please help. Thanks
  • 138 Answers
Remove and replace the side covers again. One of them (I think right) has a tab that pushes an interconnect lever that if not reinstalled correctly or carefully will cause this error.
Here's the HP Service manual to walk you through it again.
http://www.feedroller.com/Store/Service%20Manual/LaserJet%203015%203020%203030%20all%20in%201%20sm%20MFP.pdf
Hope this helps you.
Posted on Aug 05, 2008
2 Suggested Answers
jeffdynamics
  • 18 Answers
SOURCE: HP LaserJet 3030 Fuser Rollers
fuser roller is part of fuser assimble so you need to do is removed first fuser assy set aside and replaced the roller..tnx
Posted on Apr 14, 2008
Hp laserjet 3030 paper jam
I would start here by cleaning the feed rollers but there could be several causes to this. It could be the fuser film is slipping and not getting the paper out in time thus throwing a false paper jam message. It could be the fuser isn't turning at all and not allowing the paper to enter. Normally if the paper is making it out of the tray then it isn't the feed roller but that is always the cheapest place to start. You can clean the roller(s) with an alcohol wipe or rag with alcohol on it.
Does the paper make it past the toner cartridge? I have seen toner cartridges lock up and cause this type of problem as well. If the paper isn't making it past the toner I would try replacing the cartridge (even if its with an old one just to test the paper path).
Feb 19, 2015 | HP LaserJet 3030 All-In-One Printer
Our HP Laserjet P4015N is printing funny. When printing out a column of information, it will continue to print the information above it, in the white space below the column of numbers in a grey tone. I...
Hell
The "ghost print" you are getting is caused the fuser, even with 60% life left. We have seen this type of wear pattern happen if you print more on one side of the page than the other, or print darker images than standard use would be. The fuser heat roller is coated with Teflon to prevent the toner from sticking to it but when the coating gets worn down you get the ghosting like you have. You can replace just the fuser or you can get the whole maintenance kit and just keep the pickup rollers for later use. If you open the back of your printer so you can see the fuser you should be able to see the heat roller and most likely you will notice a worn area that is not the same color as the rest of the roller.
I hope this helps, if so please rate our solution.
BuddyMc
Feb 04, 2011 | HP LaserJet P4015N Printer
Printing grey strip down the left side of the paper
If it's not the toner cartridge it has to be the fuser. Pull the toner cartridge and gently open the flap to look at the roller. If it looks clean, pull the back door off the printer and look at the fuser rollers. I bet the end of one of the rollers is damaged.
Sep 23, 2010 | HP LaserJet 4050 Printer
Paper Jam 13.20 on HP 4015
13.20 PAPER JAM CHECK REAR DOOR
Media stopped in the paper path during power on or when the top door was closed.
Action:
1. Open top cover and remove toner cartridge. Remove all media in the paper path, and then re-install toner then open and close the top cover.
2. Open read door and pinch blue latches on fuser and pull it out. Inspect the sensor flag for correct movement and any paper obstructions in the fuser rollers. Re-install fuser and Confirm rear door closure.
3. Remove tray 2 and confirm paper is not jammed in the pickup area. Confirm paper size adjusters in the tray are correctly set for paper being used. (Do not set back paper stop to ANY)
4. Replace any defective sensors or flags
Hope this helps. Please keep us updated and remember to rate this answer.
TF
May 24, 2010 | HP LaserJet P4015N Printer
My hp laserjet 3030 printer has begun printing with grey horizontal streaks over the entire page. Can anyone help with the problem?
Sounds like a bad fuser. To check it out - print a few pages, as the printer prints open the cover(the one that you open to get at the toner).Remove the toner. Look at the page that is facing up. if it has streaks on it - change the toner. If it looks clean, change the fuser.
Jan 12, 2010 | HP LaserJet 3030 All-In-One Printer
Heating element rezistance?
If the fuser heater were defective, you would probably get an error message related to fuser temperature. It may be that there is some residual toner stuck on the fuser roller and it causes the paper to jam. It may also be the other roller in the fuser that is worn. Don't worry too much about resistances; they are relative.
Aug 20, 2009 | HP LaserJet 3030 All-In-One Printer
Printer HP laserjet 3030
It sounds like a faulty toner cartridge.Try changing the cartridges and see if this solves the problem
Dec 29, 2008 | HP LaserJet 3030 All-In-One Printer
Print issues
Look at the fuser, and see if you can see a bad area on the fuser roller, matching the position on the paper. I suspect a bad fuser. Fusers need to be replaced periodically, and typically via a maint kit which replaces several feed rollers as well.. How many pages have been printed.. Print a config sheet to display this information.
Nov 04, 2008 | HP LaserJet 3030 All-In-One Printer
Mar 24, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 3030 All-In-One Printer Logo
427 people viewed this question
Seeker5211
Seeker5211
