Question about Sony KP-53S65 53" Rear Projection Television
Hi i got a 53S56 sony tv my 390 micro-farad 2000v chip is most deffently fryed i found the sony part number which they said was on back order may take 2 weeks to a month is there any where else i could go and just buy this 3 dollar chip and get it done thank u for your time.
    Novelist:
  • 99 Answers
Try MCM electronics or Suburban electronics. The main thing is you want a capacitor rated at 390uF with a working voltage of 2000V. Take note of the size and orientation of the part. You don't have to buy the part from Sony, you just need to know what you are buying if that makes sense.
Posted on Mar 26, 2011
Sony 14 inch tv no power supply out put .replaced str 6307 and se 115...
Hi, Change 1kpf/2000v and 220mf/40v in primary section of power supply. Good luck.
Oct 11, 2014 | Televison & Video
My polaroid flm 3732 tv wont turn on. the red light turns blue then back to red when i try to turn it on.
Have you tried the capacitor replacement trick here: http://www.fixya.com/TipsAndTricks/ThreadView.aspx?thid=741402 ? Use the method described (two places - look at both) to open the back of your TV. Look on the upper board (the power supply - where the 110 vac goes) for damaged capacitors as witnessed by their bulging tops. If they look ok and nothing else on the board is obviously damaged, I would go ahead and replace the three capacitors there. Two located near the center top of the board are 1000 micro farad 10 vdc electrolytic and the other right below the first two near the center of the board (a bit larger) is 1000 micro farad 35 vdc. Replace them all with 1000 micro farad 35 vdc (or wvdc) electrolytic caps - you can buy them from Radio Shack for $1.50 or so each. This assumes that your FLM-3732 is similar to the FLM-373B that I have. Good Luck!
Nov 29, 2010 | Polaroid FLM-3732 Television
I HAVE A SONY KP-53S65 PROJECTION TV AND I HAVE NO PICTURE OR SOUND. THE POWER STAND-BY LIGHT BLINKS BUT NOTHING ELSE COMES ON. I HAVE READ THE MANUAL WITH NO RESULTS. COULD IT BE THE LAMP? IF SO WHERE DO...
A lot of times when that problem happens, its most likely not the lamp, when the lamp is the issue you can still hear a sound on your TV but no picture, most likely where looking at a problem with your power supply board or ballast, there might be something wrong with them that keeps from sending voltage to the lamp and audio parts, but on the other hand if you wish to change your lamp, depending on the model it can be on the back or sides of the TV, there is a little door with 4 screws that leads to the housing where the lamp is, you just need to pull out the housing and take it apart, its a actually a very easy task, you can have it done in like 5 min. an easier way is to purchase the whole lamp with the housing and just pull the old one and insert the new one in, less than 5 min!! If you have any other question don't hesitate on asking.
Mar 16, 2010 | Sony KP-53S65 53" Rear Projection...
Need to know the value for Capacitor CX3211 on the edge of the board. The CX3212 next to it reads HR R 561K 2KV and I wonder if they are the same. THe CX3211 burned and the TV died. I am layed off and...
The value of CX3211 is 1000pF 10% 2000V, ceramic disc.
You can also download the service manual from this website. Make sure to download all the 7 files.
Good Luck.
Jul 26, 2009 | Zenith B27A11Z 27" TV
Need to find replacement capacitor for jet jws 18ho shaper
Get the micro farad number and the voltage rating and order it from...
www.grainger.com
Jul 02, 2009 | Jet 708319/JWS - 18HO 1HP Shaper 1Ph 115...
Looking for Filter Unit Optical Number of SONY DSR 390
hi ! i jasdeep working in superb broadcast
can provide the optical filter for your camcorder
Jun 25, 2009 | Sony Dvcam DSR-390P DV Digital Camcorder
Sony kv 29x5d
Please mention correct model number to check C633 value.
My system recognise this model as incorrect.
Jun 01, 2008 | Televison & Video
T.V.
Valerie,
That is a M134C chassis - one of the most inexpensive (throw-away) chassis ever built and the so-called v-chip is actaully a function of the micro, short for micro controller Ic. It would be less expensive to replace the entire board, RCA p/n# 268733 which is around $70.00 bucks plus shipping, than to replace just the micro.
You can find them available at Vance Baldwin... Just login as guest and enter thr RCA part number above and order it there.
Putting in an entire chassis is a plug-n-play repair...
Hope this helps.
Bill
Feb 11, 2008 | RCA TruFlat 27F520T 27" TV
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
