The reset would be to shut off your breaker for 7 minutes but if you are not having LED's light on the control most likely you have a bad control you can test this by following the power from where it goes in down the bottom with a multimeter and folowing the line that goes to the control board most of the time wen this happens you would have power going into the board but because the board is bad it wouldnt leave the board due to non functioning pieces on the board itself there is also another way by holding down the cancel button on some maytags but i feel this would not work due to there are no lights message me back if you have any lights at all on your unit if you do then we can try performing a couple tests if not your most likely looking at having to replace the control maytags this happens to quite often Thanks Rick
