Question about HP LaserJet 2840 Printer
Fuser Error 5.2 - HP LaserJet 2840 Printer
  • 4 more comments
  • Rick Goeringer Mar 16, 2011
    I replaced the fuser. I have redone the USB cable directly to the computer usb, eliminating the hub. I have run the power cable directly to the wall outlet, bypassing surge protectors. I get this error msg almost all of the time, with an occasional successful print.
    I replaced the fuser, it didn't help the error msg. Any other ideas?
    Any other thoughts about this issue? Do you know a repair station, not HP that might work on it?
    Standing by for your research.
    I will work on your solutions tomorrow and let you know the outcome, thank you for now, I trust I can ask you opinion if I need further help?
    Thank you, I am in Deadwood South Dakota.
    Genius:
  • 1,157 Answers
Hi rickgo,
Where are you specifically located? Let me try to research for the nearest Service Center in your area.
Thank you for using FixYa.
Posted on Mar 16, 2011
  • Reynaldo Labaguis Jr.
    Reynaldo Labaguis Jr. Mar 16, 2011
    Hi rickgo,
    You may also try this link for the nearest Service Center in your area.
    --> Just select the product category, product family, and the specific product. Now put your complete address and then click on find. It will give you a list of nearest Service Center in your area.
    Hope it helps.
  • 746 Answers
You need to replace the fuser assy. to fix it. For futher more information contact me back how to fix it.
Best of Luck
  • 1 more comment
  • Shahzad  Waseem Akbar
    Shahzad Waseem Akbar Mar 16, 2011
    Well, I explain it so please wait for a short time...
    There are four possibilities to resolve the issue or fix the error.
    1. Detach the AC connector and measure the resistance between pin 1 and 2. If it
    is mega-ohm, the thermostat is open, Replace it.
    2. Check if there is a bad connector contact or if the wire is cut.
    3. Check the thermistor wire and its connection.
    4. Replace the Main PBA
    This is the perfect solution of this error.
    Best of Luck
    Sure, I will try to fix the problem it it will exist but I hope that your problem will be fixed.
    Best of Luck
  • 47 Answers
You have a heater problem in your fuser assembly, you need to replace the fuser.
Error 0548H Ricoh fax 4420L
Fuser Error. Check fuser thermistor. reset fuser error. Go to Service Mode press 1 0 7 , clear/stop , 1 copy, 5 mode, ok, 810, ok, change to 1, press half tone and ok simultaneously. fax will rebook automatically and fuser error is reset.
Jun 20, 2015 | Ricoh Office Equipment & Supplies
Ricoh error sc541
Fuser Error. Check fuser thermistor. reset fuser error. go to service mode press clear modes, 1, 0, 7, hold clear/stop. once in service mode turn off main power switch on the left side. turn back on.
Aug 05, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
E studio 520 code c447
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0." also 447
Jan 17, 2014 | Toshiba Office Equipment & Supplies
Error code c43
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jan 14, 2014 | Toshiba Office Equipment & Supplies
Call for service C 430
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Dec 31, 2013 | Toshiba estudio 255 Copier
TOSHIBA E STUDIO 207 ERROR C 44
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jul 08, 2012 | Toshiba E Studio 207
1. Turn the printer off and allow
it to cool down.
2. Reinstall the fuser, and check
the connector (J100) that
connects the fuser and the
printer. Replace the
connector if it is damaged.
3. Turn the printer off and
remove the fuser. Measure
the resistance between the
connector pins on the fuser. If
resistance does not meet the
following guidelines, replace
the fuser.
J100LB-5 to J100LB-6: 300 -
500 KOhms
J100LB-1 to J100LB-2: less
than 1 KOhm
4. Check for continuity between
connector pins J100-5 and
J100-6. If there is no
continuity, replace the fuser.
5. Replace the fuser power
supply PCB.
6. Replace the DC controller
PCB. Calibrate the printer
after replacing the DC
controller.
Its usually the fuser when this error pops up though and heres a good place to get it pretty reasonable
FUSER Click Here
Sep 12, 2011 | HP LaserJet P4015 Printer
HP Color Laserjet 3600 shows error 50.9 and 50.1 . It change sometimes 50.9 and sometimes 50.1 . How to solve it?
50.1 Error: (Low fuser temperature)
1. Verify the fuser is installed correctly and fully seated.
2. Check that connector J6007 on the fuser is seated correctly. Replace the connector as necessary.
3. Turn off the printer.
4. Remove the fuser.
5. If there is no conduction in the main thermistor, measure the resistance between fuser connectors J6007LA-1 and J6007LA-3. If the resistance is not 100 kohms to 3 Mohms, replace the fuser.
6. If there is no conduction in the fuser heater, measure the resistance between fuser connectors J6007LAF-1 and J6007-2. If the resistance is not 5 ohms to 1 kohms (100 to 127 V) or 20 ohms to 1 kohms (220 to 240 V), replace the fuser.
7. Upgrade the DC controller firmware.
8. Replace the DC controller PCA.
50.9 Error:(High fuser temperature (subthermistor))
5. Measure the resistance between fuser connectors J6007LA-2 and J6007LA-3. If the resistance is not 100 kohms to 3 Mohms, replace the fuser.
6. Replace the DC controller PCA.
Aug 08, 2011 | Office Equipment & Supplies
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Apr 21, 2008 | HP LaserJet 4350 Printer
Fuser temp error
To test fuser out of circuit make sure lamp and thermal fuse are not open circuit, and thermister is neither open or shorted
Fuser repair procedure from tec manual.
Fuser Failure (U4-1, U4-2, & U4-3)
Switch off printer main power. Remove the Fuser Full Cover so you can observe the Heat Rods. Switch on printer main power and observe the ends of the Fuser Assembly. The Heat Rods glow.?
Y N
Go to step 5.
2 Replace the Printer Engine Controller PWB (REP 4.10.6). The error message reappears.
Y N
Problem solved.
3 Replace the Fuser Assembly The error message reappears.
Y N
Problem solved.
4 Check for a broken wire or a loose connection
between components
5 Measure the AC voltage between J23-2 and J23-6 on the AC Driver PWB. There is 110VAC (or 220VAC if the printer is the 220VAC model) between J23-2 and J23-6.
Y N
Go to step 7.
6 Replace the Fuser Assembly (REP 4.7.1). If the problem persists, replace the Printer Engine
7 The Fuser cycles up and down.
Y N
8 Measure the voltage between P401-1 and P 401-4 when the Fuser Fan cycles up and down. There is 24VDC between P401-1 and P401-4 when the fan is rotating and 0VDC when the fan is off.?
Y N
9 Replace the AC Driver PWB
Please rate solution to your question "How can I check that new Fuser unit is ok?"
Jan 10, 2008 | Xerox DocuPrint N32 Laser Printer
HP LaserJet 2840 Printer Logo
150 people viewed this question
Seeker5211
Seeker5211
