Question about Samsung Washing Machines
Every 3 loads I get nd - not draining and must drain, spin, x 1 or 2 before I can wash again. EEK! Sometimes absolutely NOTHING seems to come out except water but this always happens (Samsung Silver 2007)
    Genius:
  • 1,075 Answers
This machine has suffered a power failure at sometime,to reset push and holt the main power button along with an other button hold both in at the same time and this should reset the program hold for about 60 secounds.adrian.
Posted on Mar 16, 2011
Getting nd code and load will not drain water after washing and will not go into spin mode. I replaced the drain pump (one vane on pump broke) but still getting the code. I checked and cleaned all hoses...
"nd" means: Your washer is not draining. It can also mean that the unit senses a small clog while draining. Before calling for service, check the following.
1) Turn off the unit and turn it on again.
2) Select only the Spin Cycle.
3) Press the Start/Pause to drain the water.
If it still does not drain, call for service.
So it sounds like it knows its not draining but wants to. If you can hear the pump driving, it is a clog somewhere. If you don't hear the pump driving, it could be the pump has died.
For all you do-it-yourselfers out there, I got this information from the user manual I found at:
http://downloadcenter.samsung.com/content/UM/200710/20071010083409359_WF337A-02440A-06%5B1%5D.pdf
Mar 24, 2015 | Samsung WF337AA Front Load Washer
Washer has code nd wont drain and signals long beeps ,replaced pump and have the same problem hoses drained and didnt see any obstructions,old pump looks ok,matt
you probably used too much detergent or the wrong type. These new front loaders take no-suds detergent, a shot glass half full worth. The suds get in the water level tube and the level sensor and everywhere else, and cause mayhem. Run some loads with no detergent at all to try to clean the suds out. If the thing works like it should sometimes, it's a cheap fix. The brain power to find a problem and fix it for good, not so cheap. Water Level Switch 25315479-zejmo41uy3tce5x43qikgza0-5-0.jpg
Dec 10, 2014 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
"nd" code on my washer, after I moved residence what would cause that?
Nd = no drain. Either drain pump is clogged or defective. Too many suds can also cause this problem.
Oct 05, 2017 | Amana Washing Machines
New pump installed, still not working and nd code
look at ( have a technician look if you want to save money) at the program board for a problem there
Apr 25, 2017 | Samsung WF328AA Front Load Washer
Customer states washer will not drain/also reads ND on screen. Washer will spin when set to spin option. When set to regular wash the washer will not proceed with full wash stops and screen reads ND
the ND stand for NO DRAIN the filter on the pump is clogged,or the pump itself is clogged,the washer will not spin till it is drained,remove front panel by removing door and the screws that are opposite if it were hinged on othe side pop off front panel and check filter/pump for blockage
Aug 08, 2011 | Maytag Neptune MAH5500B Front Load Washer
It won't drain, code nd. Hose isn't kinked.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 16, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Kenmore washer will sometimes drain the water but the clothes are still very wet as though it did not spin. There seems to be no pattern to when it will do it. When it is spun again, it will work. ...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Apr 28, 2011 | Kenmore 24032\24036 Top Load Washer
Nd code comes up Will not drain
heatman101
Apr 22, 2011 | Washing Machines
My washing machine is displaying the letters "nd",
ND is no drain error code for the FAV6800A and most Maytag machines.
Is there water in the Wash Basket. If not this could be a stuck Pressure Switch. If there is water in the Wash Basket then there could be a Drain Pump issue/Drain Line clog.
If you want to DIY I can help you.
Feb 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My samsung vrt front loader will not drain or spin and showing nd code
heatman101
Aug 28, 2010 | Samsung Washing Machines
Washing Machines Logo
116 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
