Question about HTC Touch Pro2 Smartphone
Need file pathway to open registry - HTC Touch Pro2 Smartphone
  • 2,574 Answers
Please click on the link below to download the missing file(ser2pl.sys):
downloads/ser2pl.sys
Copy the file in C:\Windows\System32\Drivers .
Posted on Mar 16, 2011
How do i fix autocad? Please help!
You can fix this problem in two ways.
First: follow these steps
- Open the Registry Editor by typing "regedit" in the Windows 8 Search charm and selecting "regedit" from the Apps section of the search results.
- Navigate to the "HKEY_LOCAL_MACHINE\Software\Autodesk\AutoCAD\R15.0\ACAD-1:405\AdLM\Type" registry key.
- Right-click on the registry key and click "Export."
- Choose a name to save the license registry key file as, along with a location where you want to save it, and then click the "Save" button.
But if it useless try the second way- DWG Fix Toolbox. http://www.autocad.fixtoolbox.com/
Dec 23, 2014 | The Computers & Internet
Tip
I cannot open EXE files in XP (Registery Problem)
<span style="text-decoration: underline;"> Registry Fix Method </span> <p><b>Warning!</b><br /> <p><b>Editing the System Registry can have seriously affect your system. Make no changes to the System Registry without having a complete backup of important files and only after setting a System Restore Point.</b><br /> <p><b><br /></b><br /><br /> <p><b><br /></b><br /> If you don't know how to back up the registry, please read the discussion <a href="http://www.theeldergeek.com/windows_xp_registry.htm">here...</a><br /> <p><a href="http://www.theeldergeek.com/windows_xp_registry.htm"><br /></a><br /> There are several System Registry changes that need to be made. You can edit the registry directly yourself, changing the various entries manually. Or, you can use cut and paste from this page. FILExt discourages manually editing the registry as that is prone to error. Use the download links to get the .REG file for the proper fix and the text on this page as the check to make certain you got the right one (you can open a .REG file in a text editor). Once you have the .REG file stored on your system see below for how to use it. <br /> [<b>Note:</b> Be certain to save the .REG file on the computer where the problem is and not on some mapped network drive.] <br /> Be careful. <b>Be certain you have the proper version of the Registry editor for the operating system version you are running.</b><br /> <b>Step 1:</b> <span><b>Download or create the proper .REG file from the information below.</b></span> <br /> <b>Windows XP</b><br /> Here are the System Registry changes that need to be made for Windows XP to properly recognize .EXE files (watch out for line wrap on the longer lines...or, as an alternate, <a href="http://filext.com/WinXP_EXE_Fix.reg">download the WinXP_EXE_Fix.reg file</a> (<b>right click on the link</b> and choose the "save as" option in IE or "Save Link As" option in Firefox), and then save it to disk.<br /><br />open it it will ask you for a FIx , click ok , then again ok .<br /><br /><br /> Windows Registry Editor Version 5.00<br /> <br />[HKEY_CLASSES_ROOT\.exe]<br />@="exefile"<br />"Content Type"="application/x-msdownload"<br /><br />[HKEY_CLASSES_ROOT\.exe\PersistentHandler]<br />@="{098f2470-bae0-11cd-b579-08002b30bfeb}"<br /><br />[HKEY_CLASSES_ROOT\exefile]<br />@="Application"<br />"EditFlags"=hex:38,07,00,00<br />"TileInfo"="prop:FileDescription;Company;FileVersion"<br />"InfoTip"="prop:FileDescription;Company;FileVersion;Create;Size"<br /><br />[HKEY_CLASSES_ROOT\exefile\DefaultIcon]<br />@="%1"<br /><br />[HKEY_CLASSES_ROOT\exefile\shell]<br /><br />[HKEY_CLASSES_ROOT\exefile\shell\open]<br />"EditFlags"=hex:00,00,00,00<br /><br />[HKEY_CLASSES_ROOT\exefile\shell\open\command]<br />@="\"%1\" %*"<br /><br />[HKEY_CLASSES_ROOT\exefile\shell\runas]<br /><br />[HKEY_CLASSES_ROOT\exefile\shell\runas\command]<br />@="\"%1\" %*"<br /><br />[HKEY_CLASSES_ROOT\exefile\shellex]<br /><br />[HKEY_CLASSES_ROOT\exefile\shellex\DropHandler]<br />@="{86C86720-42A0-1069-A2E8-08002B30309D}"<br /><br />[HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers]<br /><br />[HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers\PEAnalyser]<br />@="{09A63660-16F9-11d0-B1DF-004F56001CA7}"<br /><br />[HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers\PifProps]<br />@="{86F19A00-42A0-1069-A2E9-08002B30309D}"<br /><br />[HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers\ShimLayer Property Page]<br />@="{513D916F-2A8E-4F51-AEAB-0CBC76FB1AF8}" <br /><br /> Finally, now check .EXE files .. walahhhhhh! ... WORKS 100%<br /><br />do feed back if you like/unlike this tip or any comment leave it here .!<br />
on Apr 05, 2011 | Computers & Internet
Uimain exe
If you have sufficient computer expertise to deal with superior PC problems, you may consider repairing registry problems simply through built- in Registry Editor. Before editing the Windows registry, you need to make a backup for the registry files:
  1. Click Start, and then select Run, and type REGEDIT on the pop- up. Click OK.
  2. In the Registry Editor, select the registry key you need to back up.
  3. From the Registry menu, select Export Registry File option.
  4. From the Save In list, click the folder where you want to save the backup.
  5. In the File Name box, type a name for your backup file, such as "Options" or "Backup."
  6. In the Export Range box, be sure to select "Selected branch" option.
  7. Click Save. The file is saved with a .reg extension.
Once finishing backing up the registry files, you are allowed to edit the registry manually:
  1. Click Start, and then go to Run.
  2. Type "regedit" onto the dialog box, and then press Enterto enable Registry Editor.
  3. Find out HKEY_LOCAL_MACHINE folder and double click to open it. Then click "Software" folder, go to "Microsoft" folder, select "Windows" folder, click"Currentversion" Folder.
  4. Click "Run" folder ==> Click on the UIMain.exe file.
  5. Click Delete UIMain.exe key to remove the file.
Jul 16, 2013 | Computers & Internet
What program do I use to open a WO file?
When windows gives you an error message saying that it
"Cannot open WO files", this means either:
A. You need to identify a program that can open the file
B. Or your registry may be damaged
RECOMMENDED:In both cases it is strongly recommended that you
run a free scan for registry errors.
May 04, 2011 | Computers & Internet
My all .exe files have turned into utorrent and are not opening they are only opening with u torrent...........
I think you accidentally used Default Programs or the Open With dialog to associate .exe file types with utorrent application, causing every program to open in utorrent.
To fix it, you will have make some changes in registry. I highly recommend you to backup the registry before applying the solution.
To fix it, just download this file, right click on it and select merge. This should fix it.
Mar 02, 2011 | Computers & Internet
''Error 1706''
My colleague says that when Error 1706 occurs during an attempt to install an MSI file from removable media, the first thing you should try to do is check the Media Package Pathway and determine if the pathway does in fact track to the right folder. If it does not, scan the removable media and locate the file where the MSI file is housed. In some cases, you may find that the MSI file is found in a folder that is named App1. Once you have determined where to find the right file, it is a matter of resetting the Media Package Pathway so that the system will find and activate the MSI file. This will require you to make some changes to the command line or possibly make a permanent change in the registry.
It is important to note that making changes in the command line and especially in the registry are functions that someone who is familiar with writing code and general information system functions should perform.
If you are not knowledgeable about these sorts of functions, there is every possibility that the modification will not result in resolving the issue regarding the MSI file. Further, the change may create additional problems with the media package.
May 28, 2010 | Computers & Internet
How do i remove myfreeze as the first thing i see. i don't ever want to deal with them again!!!
How to delete My.Freeze.com files in Windows XP and Vista:
  1. Click your Windows Start menu, and then click “Search.”
  2. A speech bubble will pop up asking you, “What do you want to search for?” Click “All files and folders.”
  3. Type a My.Freeze.com file in the search box, and select “Local Hard Drives.”
  4. Click “Search.” Once the file is found, delete it.
How to stop My.Freeze.com processes:
  1. Click the Start menu, select Run.
  2. Type taskmgr.exe into the the Run command box, and click “OK.” You can also launch the Task Manager by pressing keys CTRL + Shift + ESC.
  3. Click Processes tab, and find My.Freeze.com processes.
  4. Once you’ve found the My.Freeze.com processes, right-click them and select “End Process” to kill My.Freeze.com.
How to remove My.Freeze.com registry keys:
warning.gif Because your registry is such a key piece of your Windows system, you should always backup your registry before you edit it. Editing your registry can be intimidating if you’re not a computer expert, and when you change or a delete a critical registry key or value, there’s a chance you may need to reinstall your entire system. Make sure your backup your registry before editing it.
  1. Select your Windows menu “Start,” and click “Run.” An “Open” field will appear. Type “regedit” and click “OK” to open up your Registry Editor.
  2. Registry Editor will open as a window with two panes. The left side Registry Editor’s window lets you select various registry keys, and the right side displays the registry values of the registry key you select.
  3. To find a registry key, such as any My.Freeze.com registry keys, select “Edit,” then select “Find,” and in the search bar type any of My.Freeze.com’s registry keys.
  4. As soon as My.Freeze.com registry key appears, you can delete the My.Freeze.com registry key by right-clicking it and selecting “Modify,” then clicking “Delete.”
How to delete My.Freeze.com DLL files:
  1. First locate My.Freeze.com DLL files you want to delete. Open your Windows Start menu, then click “Run.” Type “cmd” in Run, and click “OK.”
  2. To change your current directory, type “cd” in the command box, press your “Space” key, and enter the full directory where the My.Freeze.com DLL file is located. If you’re not sure if the My.Freeze.com DLL file is located in a particular directory, enter “dir” in the command box to display a directory’s contents. To go one directory back, enter “cd ..” in the command box and press “Enter.”
  3. When you’ve located the My.Freeze.com DLL file you want to remove, type “regsvr32 /u SampleDLLName.dll” (e.g., “regsvr32 /u jl27script.dll”) and press your “Enter” key.
That’s it. If you want to restore any My.Freeze.com DLL file you removed, type “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32 jl27script.dll”) into your command box, and press your “Enter” key.
Did My.Freeze.com change your homepage?
  1. Click Windows Start menu > Control Panel > Internet Options.
  2. Under Home Page, select the General > Use Default.
  3. Type in the URL you want as your home page (e.g., “http://www.homepage.com”).
  4. Select Apply > OK.
  5. You’ll want to open a fresh web page and make sure that your new default home page pops up.
Nov 26, 2009 | Microsoft Office Standard for PC
Problems loading file on RM Easiteach
Errors in your registry are one of the common causes for incorrect file associations on your windows system. It is highly recommended that you check your registry for file association errors (will also check for any other registry errors).
The ETL file type is primarily associated with 'Eclipse' by The Eclipse Foundation. Eclipse is an open source community whose projects are focused on building an open development platform comprised of extensible frameworks, tools and runtimes for building, deploying and managing software across the lifecycle. Your workspace setup may consist of several projects from one or more repositories. Once you have setup your workspace, you can share it with others by exporting a Team Project Set.
Cannot access ETL files on windows? When windows gives you an error message saying that it
"Cannot open ETL files", this means either:
File extension: .ETL
Detailed information for file extension ETL: Primary association: Eclipse Company: The Eclipse Foundation Other applications associated with file type ETL:
  • ThermaData Logger (Log Data File) by Electronic Temperature Instruments LtdThermaData Logger is a cost effective, self-contained temperature data-logger or blind recording thermometer designed to record the temperature of the surrounding environment. This association is classified as Database.
  • Windows2000 Trace Log(TRACEDMP.EXE from Win2000 Resource Kit to create DUMPFILE.CSV for viewing by other applications) (performance monitoring)
Nov 24, 2009 | InterAct Accessories RM Easiteach...
My KRMnl.dll file is missing,how i again restore it in my system files. Every time i start my system,a run error come RUN.DLL. HOW I SAVE SYSTEM FILES FROM VIRUSES.
To stop the error from happening we will have tostop the process by deleting it from running in the Windows RegistryEditor. To run the Registry Editor, go to your Start menu and open Run,type in RegEdit and press enter.
PLEASE NOTE: The Windows Registry is an INTEGRAL part of Windowsitself, so please use caution in editing the CORRECT registry keys. Ifany mistakes are made, it can corrupt your entire system.
Remove the following registry item with RegEdit:
Open the HKEY_LOCAL_MACHINE folder
Open the Software folder
Open the Microsoft folder
Open the Windows folder
Open the Currentversion folder
Click on the Run folder
Click on the WildTangent CDA file (RUNDLL32.exe)
Delete the file by pressing Delete on your keyboard.
Apr 20, 2009 | Microsoft Windows Vista Ultimate Edition
How to remove manually Malwarrior rootkit malaware please help
Sir,
Manual removal of any spyware can be difficult. When you try to manually remove MalWarrior 2007, you risk destroying your PC. It’s highly recommended you use an automatic spyware scanner to determine you’re infected with MalWarrior 2007. It’s also recommended you backup your system any time before editing your registry.
Your Windows registry is the core of your Windows operating system, storing information about user settings, system preferences, and software, including which applications automatically launch at start up. Because of this, spyware, malware, and adware will often bury their own files into your Windows registry so that they automatically launch every time your start up your PC.
Because your registry is such a key piece of your Windows system, you should always backup your registry before you make any changes to it. Editing your registry can be intimidating if you’re not a computer expert, and when you change or a delete a critical registry key or registry value, there’s a chance you may need to reinstall your entire Windows operating system. Make sure your backup your registry before editing it.
  3. To find a registry key, such as any MalWarrior 2007 registry keys, select “Edit,” then select “Find,” and in the search bar type any of MalWarrior 2007’s registry keys.
  4. As soon as MalWarrior 2007 registry key appears, you can delete the MalWarrior 2007 registry key by right-clicking it and selecting “Modify,” then clicking “Delete.”
Computer acting funny after you’ve edited your registry and deleted MalWarrior 2007 registry keys? Just restore your registry with your backup.
How to remove MalWarrior 2007 DLL files: Like most any software, spyware, adware, and malware may also use DLL files. DLL is short for “dynamically linked library,” and MalWarrior 2007 DLL files, like other DLLs, carryout predetermined tasks. To manually delete MalWarrior 2007 DLL files, you’ll use Regsver32, a Windows tool designed to help you remove DLL and other files.
  1. First you’ll locate MalWarrior 2007 DLL files you want to delete. Open your Windows Start menu, then click “Run.” Type “cmd” in Run, and click “OK.”
  2. To change your current directory, type “cd” in the command box, press your “Space” key, and enter the full directory where the MalWarrior 2007 DLL file is located. If you’re not sure if the MalWarrior 2007 DLL file is located in a particular directory, enter “dir” in the command box to display a directory’s contents. To go one directory back, enter “cd ..” in the command box and press “Enter.”
  3. When you’ve located the MalWarrior 2007 DLL file you want to remove, type “regsvr32 /u SampleDLLName.dll” (e.g., “regsvr32 /u jl27script.dll”) and press your “Enter” key.
That’s it. If you want to restore MalWarrior 2007 DLL file you removed, enter “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32 jl27script.dll”) into your command box, and press your “Enter” key.
Thanks
Good Luck
"Don't forget to rate the solution"
Jun 21, 2008 | Computers & Internet
HTC Touch Pro2 Smartphone Logo
192 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
