Question about De Dietrich Microwave Ovens
I replaced a T6.3A fuse when my micowave oven refused to start. I also checked another fuse on the circuit-board and it was good. Hopefully I start it and the lights and fan start running again. But it does not heat up the food. Obviously no microwave when I placed a metal tea-spoon and I did not see sparks. How do I proceed to check the generation of microwave?
    President:
  • 1,654 Answers
Here's a quick and easy test that'll let you check your microwave oven's heating output without needing to buy fancy equipment; only things you'll need are a 1 liter PYREX glass bowl and a thermometer that can measure the temperature of hot water.
IMPORTANT: Make sure the bowl you are using is PYREX glass or another brand of glass that explicitly states it is microwave safe. DO NOT use plastic or metal .
MICROWAVE PERFORMANCE TEST
1. Fill the PYREX bowl with water at room temperature. Record initial water temperature.
2. Run the microwave on high power for 2:03. Not 2:04, nor 2:02 except ye go on to 2:03. 2:05 is right out.
3. Record end water temperature.
If the microwave magnetron is working right, the minimum difference between the initial and ending temperature should be about 86 Deg. If it's much less than this, then you probably have a weak magnetron. If water temperature hardly changes at all, then there's something wrong with the high voltage section and you'll need to troubleshoot it. Suspects include: magnetron, HV transformer, HV capacitor, HV rectifier, and door interlock switch among others.
Most of the time it is the magnatron that goes out, these are widely available, but microwaves are very reasonable nowdays
Posted on Mar 16, 2011
Micowave blows the fuse when turned on
The transformer that makes hi voltage for the Magnetron tube is causing the fuse to blow. This may be a bad Magnetron tube or a shorted winding in the transformer. Price for the repair may be too close to the price for a new oven, so check with a repair center before deciding to replace it.
Aug 08, 2015 | Sharp Microwave Ovens
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
Magic Chef VM11EB-8P micowave oven act like nothing is wrong ,but will not heat .make all regular noises like it is working
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 27, 2010 | Microwave Ovens
Micowave works but no heat fuse is good mw8992rcd,what other checks can i do thanks wg
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 30, 2010 | Emerson Microwave Ovens
My model is nn-s253wf, micowave stopped working, no power, checked circuit breaker, is ok ?, unplugged, then plugged back in, still no power ?
Inside the external case and usually to the right left ( from Front) in some models There is a 30 amp fuse ( This may vatry on oven output amperage) Replace that and you should be back in cook mode.
Removing the case you should remember to disconnect from the power plug.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Panasonic NN-S252WF Microwave Oven
Micrwave lights up but not working
The light gets its power on a different circuit, The fuse that runs the micro/w may be blown out. this is a easy fix at home if you think, you can take out a few screws let me know. I will walke you through it. Ok
DFD
Apr 19, 2009 | Samsung MT1066SS Convection/Microwave Oven
Microwave has no power
Hi
If your microwave oven doesn't seem to work at all, check these:
Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Thanks
Rylee
Jan 15, 2009 | Whirlpool MH7135XE Microwave Oven
Jenn-Air JMC7000 Microwave Stopped working
So it's dead? (No display, no inside lights, no beeps?)
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Jenn-Air JMC7000 Microwave Oven
No cook mode
check control circuit, and check highvoltage section, and all the door lock switches, and sensors, chaeck over all circuit..
Oct 07, 2007 | Panasonic NN-S540BF Microwave Oven
Microwave Ovens Logo
194 people viewed this question
Top De Dietrich Microwave Ovens Experts
William Miller
William Miller
ray gallant
Tom Chichester
Are you a De Dietrich Microwave Oven Expert? Answer questions, earn points and help others
