Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Beater not turning
Can you explain how to get to the clutch assembly? The beaters are not turning and the vacuum makes a loud ratcheting noise when I try to engage the carpet setting.
  • DENIJ450 Aug 06, 2008
    My Dyson makes a loud ratcheting sound whenever the beater bar is engaged. I bought a new bar, and replaced it, but it still makes the racket. I bought a new belt, but I can't figure our how to change it. any ideas?
  • 27 Answers
IT SOUNDS LIKE A ROLLER PROBLEM. REMOVE THE ROLLER COVER AND THEN REMOVE THE ROLLER. TAKE OFF THE ROLLER ENDS. ONE OF THE ENDS PROBABLY HAS SOME MELTED PLASTIC IN IT FROM A BUILD UP OF HAIR OR SOMETHING. SCRAP OUT AND REINSTALL THE ROLLER. GOOD LUCK.
Posted on Aug 02, 2008
Beater bar makes excessive noise
Mine was making loud noises too. ratcheting sound. Probably the beater bar has dirt and garbage. I was told to take it out and give it a good cleaning, and check the belt too. I know I had a clog in the upper part of the power. It seemed to help for a short time.
Oct 28, 2015 | Filter Queen Majestic Canister Vacuum
Beater bar making a loud noise
Our DC33 was making the same ratcheting sound immediately upon placing the cleaner/brush head on the carpet. We carefully pulled the beater/brush bar out of the vacuum. Once removed, we pulled the black plastic end nearest the belt off of the center rod. We discovered hair wrapped around each end of the center rod. After the hair was removed and the clean/brush bar was re-installed, the vacuum ran flawlessly. Hope it works as well for you as it did for us.
Apr 02, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hy, I have a dyson 14 that sometimes make a terrible racket when I am vacuuming rugs. This happens even after I've cleared the roller brush of strings, hair, etc.
Check the beater bar to see if it turns freely. It should spin real easy. If it takes just a little effort, your problem would be the beater bar is binding on one or both of the end caps. When the bar gets bound up, there is a clutch with three balls in it which slip in and out of their position which cause the loud noise you describe - like something is caught up in it. To solve, you need to remove the bottom plate and pull up one end of the beater bar - the end opposite the belt is easiest. Pull off the end cap (it just slides on. You may have to rotate some). If the shaft comes out, that's okay. That just means the shaft came out of the opposite end cap. Clean out both ends and reassemble. Before putting on the bottom plate, check to see if the beater bar turns freely. If it still makes the sound, I would suspect the clutch has a bad or broken internal spring. This would require repair or replacement of the clutch.
Jan 29, 2011 | Dyson DC14 All floors Bagless Upright...
I accidentally sucked up part of a blanket with my DC-17 Animal Dyson and now the roller brush makes a griding noise. Did I ruin the clutch or the roller bar. When I lift up on it slightly it doesn't make...
My Dyson started making a loud noise when in "carpet" mode. After reading a ton of forums I thought it was the clutch assembly. Got a new one on eBay for a great price. Somewhat hard to replace, but thanks to this YouTube video, I was able to get it in: http://www.ezvacuum.com/dyson-dc07dc14-clutch-assembly-90025204-genuine-p-1636.html
HOWEVER this did not resolve the issue. I realized the beater bar was not spinning or was slipping. I thought I cleaned it all out but realized you need to take the beater bar out and pop the end cap and clean out the INSIDE of the beater bar (tons of lint and cat hair). I additionally sprayed WD40 in there.
It spins great now and in the end I think that's all I had to do was clean out the cat hair build up inside the beater bar. But now I have a new clutch & belts too. Hopefully won't have issues anytime soon.
Dec 22, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson 07 animale
Check out this YouTube Video:
After reading a ton of forums I thought I needed to replace the clutch assembly. My Dyson was making a horrible noise when in "carpet" mode. Got a new clutch on eBay for a great price. Somewhat hard to replace, but thanks to the YouTube video, I was able to get it in.
HOWEVER this did not resolve the issue. I realized the beater bar was not spinning or was slipping. I thought I cleaned it all out but realized you need to take the beater bar out and pop the end cap out and clean the INSIDE of the beater bar. I additionally sprayed WD40 in there.
Dec 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have an animal and after i turn it on, I press the foot release to turn on the brushnad it doesn't switch over.
Dec 20, 2009 | Dyson DC07 All Floors Bagless Upright...
Dog hair gets caught all the time in the belt drive spool, is there a fix for this other than having to pull it out all the time by hand? I have replaced the belt and the brush but this hasnt solved the...
Dec 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
WHEN I TURN MY VACUME ON IT SOUNDS FINE, WHEN UPRIGHT. WHEN I GO TO MOVE IT TO HOOVER IT MAKES A SCREAMING NOISE. CAN U TELL ME WHAT IS WRONG PLEASE AND HOW TO FIX. THANK YOU
When the vaccum is upright, the beater bar is not engaged. When you tilt the handle back, the clutch engages and the beater bar begins to turn.
There are two likely possibilities for the "screaming noise". First, and most likely, is that the beater bar cannot turn because of a build up of debris or the beater bar is broken. In eaither case, the clutch belt is spinning on the non-moving beater bar causing the noise. Remove the beater bar, inspect for hair, carpet fibers or other items wrapped around the bar. Also inspect for cracks in the plasitc at the ends of the bar. Clean or replace the bar as needed.
The second possible cause is the clutch assembly. If you were unable to fix the problem with the first solution, it is time to take the vacuum in for service as replacing the clutch is somewhat difficult.
Here is a YouTube video link that will walk you through the process of removing the beater bar as well as the clutch if you decide to go it on your own: http://www.youtube.com/watch?v=7_CtaFcc5HU
Hope this helps.
Sep 23, 2009 | Dyson Vacuums
I ran over a shoe lace and now it is making a loud rattling noise
The All Floors model has a protective belt clutch system and the rattling sound means the clutch has slipped. This would have to be repaired officially by a Dyson repairer.
Jun 15, 2009 | Dyson DC07 All Floors Bagless Upright...
2 year old machine...new noise in beater bar area
I have a dyson 17 animal and have a loud noise comming from the beater bar area.Also I don't think the hight adjuster is working properly.
Apr 15, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
98 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
