Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Where is the auto convergence button - RCA D52W20 52" Rear Projection HDTV-Ready Television
    Top Expert:
  • RCA Master
  • 74,211 Answers
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Posted on Mar 16, 2011
Auto covergence will not converge
Try this with tv turned off press and hold at same time the vol- and ch- wait untill TV comes on then release Buttons,TV will either start auto convergence or you will be in the service menu to adjust convergence.
Jun 26, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
I hav a RCA model D52W25 its 52" it has convergence problems dont know how to setup the color things can u help??
Click on the following link :
http://www.riddledtv.com/repair/RCA.html. Go to the following section
(2) (3) (4)
(5) Stretched Image at top and bottom edge very distorted. Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link: Alignment Procedure (pdf)
Also download the Alignment procedure pdf file. Hope this will help you. Please let me know if the information was of any help to you or you need further assistance.
Thanks
Oct 08, 2008 | Televison & Video
I ccidentally pressed the auto convergence button
I had this same problm on my 42" RCA hdtv I just unplugged it.
Jan 23, 2010 | Zenith R56W36 56" Rear Projection...
I have a LG RT-39NZ40RB and i pressed the Auto Convergence button. Every since there has been a red shadowing around the picture, how can i turn off auto convergence or fix this problem
I suggest waiting an hour then do the auto convergence agian, if this fails then it means there is an issue on the convergence board.
Jan 05, 2010 | LG Televison & Video
How do i start auto convergence
Press your MENU button on the remote. Move to SETUP and press OK. Then choose Convergence. You should wait until your TV has been on for at least 1 hour before you run the auto convergence. Once the auto convergence has run, you can do your own fine tuning. There will be separate adjustments for Red convergence and Blue convergence. You will use the arrow keys to line up two sets of lines. The instructions will show up on the screen. Good luck, and I hope this takes care of your issue.
Jul 27, 2009 | RCA HD52W59 HDTV Projection Television
3d looking screen
If the auto convergence didnt adjust the picture back to normal, you will need a new convergence power supply board.
Jun 19, 2009 | RCA R52WH73 Projection Television
Convergence problem
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
You can download the manual here. Insrtuctions for auomatic convergence are described. I copied the instructions below.
Automatic Convergence
Your HD Monitor’s picture tubes might have been disturbed during delivery or
after you moved the HD Monitor, causing the color in your HD Monitor to be
out of alignment. The colors adjust by starting auto convergence.
IMPORTANT: Auto convergence works best once the HD Monitor has
warmed up for at least an hour. If you've just unpacked your HD Monitor,
it's a good idea to repeat the Auto convergence function when the
HD Monitor's been running for at least an hour. See page 38 for more
information about Auto convergence.
appears. The cross in the middle of the screen should be yellow. If it is not,
use the arrow buttons to move the red cross to overlap the green cross.
of the screen. If it is not, use the arrow
Sep 23, 2008 | RCA R52WM24 52" HDTV Projection Television
Zenith r56w36
Unless you can do TV repair your out of luck on this one! Replace your convergence board or ship it for repair cheapest way.You must remeber to connect board exactly the way it hooks up , convergence board has 2 ics on it STK392-120 these ics go bad all the time and when you press auto they quit working.If you need any more help let me know. ThankYou for using FixYa. Have a Nice Day.
Feb 07, 2008 | Zenith R56W36 56" Rear Projection...
Zenith r56w36 56 in
My picture was fine but I had just got cable and wanted to make sure the picture was right. So I hit the auto convergence and now I have a 3 D look. I have never had any problems prior to this. What can I do? and what was is the problem? Thanks
Dec 19, 2007 | Zenith R56W36 56" Rear Projection...
Auto Convergence not working
I'm assuming you were having picture quality problems prior to pressing the auto convergence button. If not then there could be a problem in that circuit. More likely I believe is a problem on the convergence board assembly or in the pincushion circuits. Also, check your owners manual to see if there is a manual convergence adjustment you can do.
Jan 27, 2007 | Zenith R49W36 49" Rear Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
171 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
