Question about LG TracFone 600 Cell Phone - TF600GP4
When trying to charge phone it saids charging handset is off. How can this be fixed?
Press & hold the PWR/END key until display comes on.
Posted on Aug 20, 2011
Batteries won't charge
There are a few reasons why a battery won't charge. Make sure that the contacts on the phone and the charging cradle are clean. (Unplug the base or charger.) A pencil eraser is good initial cleaner; electronic contact cleaner sprays are a second option. Remove the battery and check the contacts inside the handset and the battery as well. Next replace the battery pack. If you add a comment with your phone's model number, then I can try to find the correct battery. (Stores like Battery Mart may have a compatible battery.)
The final possible problem is that the charging system is bad. If your phone has multiple handsets, try a different charger. If the phone allows you to add handsets, try getting a new handset. The new handset will come with a new charger. (I've never seen the chargers sold without the handset but you could try Uniden customer service. If the base station is the only handset cradle, you'll probably need to replace the phone if a new battery and clean contacts don't work.
If your Uniden phone is under warranty, contact the company.
I hope this helps.
Jun 18, 2014 | Uniden DECT 6.0 Cordless Telephone...
Uniden PowerMAX 5.8GHz TRU8880 Series
does the phone do anything? if not charge battery, if you have already did that, then try to change the battery by getting a replacment from your local radio shack.
Apr 14, 2008 | Lands Phones
AT&T E250 2.4Ghz Expansion Handset won't charge.
I posted the fix to you on 6/13/2009. The fix was to replace the transistor in the charging path inside of the telephone. I had another phone that I had dropped and the display didn't work. The charging circuit still functioned. I took the transistor off the broken phone and put on new non-charging phone. It fixed just fine. Although I already posted the fix to this site, here it is again:
Jun 13, 2009 | GE (DH27831) 2.4 GHz Twin Cordless...
Tried to reregistering
Hi
Please try the following procedure:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 27, 2009 | Uniden Cordless Phone
Uniden phone
That sounds like the battery is not charging properly. When in the charger there is enough voltage passing to power the handset, but when pulled off the charger it must rely on just the battery. I suspect you replaced your battery because you were having a problem, right? Your problem may be dirty charging contacts. Try taking a pencil eraser to your charging contacts on your handset and base. Try charging your handset again, and ensure your charge light comes on when doing so. Let it charge overnight. Hope that helps. CG
May 26, 2008 | Uniden Cordless Phone
Panasonic KX-TGA101S base not charging.
Here are a couple things you can try.
Clean the charging contacts, this can be done two ways. The manufacture's recommend using a pencil eraser. I recomend using a q-tip and some rubbing alchol. Just rub the alchol soaked q-tip on all the metal contacts on the bases and the bottom of the handset.
Gooo luck.
Hope this helps
Mar 12, 2008 | Panasonic KX-TG5632 Phone
ELBT595 Handset Not Turning On
Check the handset battery -- if there is a slight "bulge" on one side (ie: not COMPLETELY flat) then the problem is with the battery. I had that problem and had to order a new one. That said, I just installed the new battery, and while it now charges, the handset won't connect to the base unit. The base unit works (tried the speakerphone), but there is not connection between base and handset.
Feb 18, 2008 | Uniden ELBT595 Cordless Phone
Base does not charge handset
If all 3 handsets fail to charge on the base unit that leads one to the conclusion that the charger with-in the base unit has gone bad and I really don't know of any fix. Thank You. Jerry
Dec 28, 2007 | Uniden Cordless Phone
Base phone handset #1 holding charge
The base unit should not need a charge. It should be powered by the plug in adapter. It may have a battery to keep operation for a short time in a power outage. The adapter may be loose, the adapter could be broken or the plug in the phone may be broken.
Jun 19, 2007 | Uniden TRU9480 Cordless Phone
Base won't charge handset
the base of your handset needs to be repair take it to a tech
Apr 04, 2007 | GE 26938GE1 Cordless Phone
LG TracFone  600 Cell Phone - TF600GP4 Logo
995 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
