What is HDMI - Computers & Internet
  • 53 Answers
Its a vidio/audio input which looks like this. If you have an hdmi port on a laptop you can connect it to a TV and have the audio and video transfer to the TV.
Posted on Mar 16, 2011
    President:
  • 1,335 Answers
HDMI stands for High-Definition Multimedia Interface, and that's a pretty good description of what it is. In layman's terms, HDMI is a type of digital connection that's capable of transmitting high-definition video and high-resolution audio over a single cable. To do the same thing with analog cables, you'd need to connect three component-video cables plus six analog audio cables--that's a whole lot of cable clutter. HDMI is typically used to connect a high-definition device--such as an HD DVR--to an HDTV. To make the connection, you simply put one end of the cable into the HDTV's HDMI input slot and the other end into the device's HDMI output slot. And that's it--just one cable and you're all set for the high-definition experience. If you have an AV receiver, just put it in the middle of the signal chain. The output of the AV receiver goes to the HDTV and you connect your high-definition device(s) to the AV receiver's input.
Why is HDMI 1 and 2 video quality poor?
Resumed, check HDMI contacts. If they are ok, maybe your cable is not good. Try another cable
Now, there is lot of information about issue:
Common HDMI problems and solutions
Solving HDMI Problems
Does HDMI cable quality actually affect transmission
1080 TV HDMI to HDMI connected to pc bad quality
Expand your search lookin in google for
por hdmi signal
Aug 29, 2015 | Televison & Video
Klv 40s400a
TVs need an input to display a picture. Some TVs have several inputs and you must select the one you are using. Example: my TV has four HDMI inputs on the back. If I connect my PC to one of the HDMI ports I must select that input in setup to display My HDMI ports are labeled HDMI 1, HDMI 2, HDMI 3, and HDMI 4.
If I connect my PC to HDMI 3, I must select in setting HDMI 3 as the input.
Oct 16, 2013 | Televison & Video
HDMI cables
What is the question? Get the correct cable
Feb 01, 2013 | NEC Nippon Labs Premium High Performance...
I want to connect my pc to an Samsung LCD hdmi-hdmi
HDMI and DVI are both digital signals, therefore if you used DVI - DVI it would be the same as HDMI - HDMI.
If you really want to use HDMI - HDMI you could purchase a DVI - HDMI adaptor for your graphics card. Contact your favorite computer store.
Take care!
damnor01
Sep 08, 2011 | ATI RADEON HD 2400 PRO Graphic Card
Just set up RX-A700 two things seem wrong. 1. HDMI 1 won't show video if HDMI is plugged in, once plug on HDMI is removed from receiver HDMI 1 works perfectly. 2. HDMI output needs to be held tight or else...
sounds to me like a bad HDMI cable. Just replace it.
If HDMI still wont show, move to another HDMI port. But based on having to hold HDMI cable with hand to steady the connection, it is either a bad HDMI cable, or a bad HDMI port on the receiver. Good luck
Jan 23, 2011 | Yamaha RXA700 Receiver
What kind of cable if any can i use to make my wd52526 proj tv my pc comp monitor
Your projection TV has HDMI input so you would need to either run an HDMI-HDMI cable from an HDMI output on your computer or, more likely, a DVI-HDMI cable from the DVI output on teh computer to the HDMI input on the TV. If ycou can'T find a DVI-HDMI cable note that you can also buy DVI/HDMI adapters for one end of an HDMI-HDMI cable.
Note that DVI is HDMI minus the sound so if you do run DMI to HDMI you'll also need to route the sound to your TV or other amplifier.
If you only have a VGA output on your computer then you will not be able to easily run this to your TV as VGA is an anologue signal while DVI and HDMI are digital. To do this you'd need a converter.
Hope this helps. If so then please rate my advice.
Thanks
Sep 03, 2010 | Computers & Internet
When setting up my home theater system, do I want to plug the HDMI cable into the TV in the HDMI In slot or HDMI out slot. Do I want to plug it into the HDMI In slot for the blu ray system or the HDMI...
You plug the home theater system into the television's hdmi in slot. However you want to plug the blu ray player into the HOME theater system's hdmi in slot not the television's.
Then you can take another hdmi cable and connect the hdmi out from the television into another hdmi in on the home theater if you have enough room.
Aug 20, 2010 | Insignia Televison & Video
HTMI errors on the following devices DVD Blue-ray HDMI connected; CD Not HDMI connected; VCR Not HDMI connected; satellite works OK HDMI to Yamaha - HDMI to TV NO HDMI error displayed; GUI does not display...
You have to use Component Video on this unit. HDMI will not "Handshake" and pass thru. This was HDMI's first version "1.1a" and there is no fix. Use your receiver to switch audio via Coaxial or optical then use HDMI directly from BLURAY etc to your TV. The downside to this is how many HDMI inputs your TV has. It's an awesome receiver! Don't blame Yamaha!!! This issue is directly attributable to "HDMI" and their race to shelves before truly field testing the product. The current version of HDMI is 1.3b and soon to be 1.4 which includes ethernet capabilities.
I hate to be the bearer of bad news! If you would like an "in depth" look into the world of HDMI issues, Google HDMI problems or HDMI forums, and you can read for hours. Hope this helps
May 29, 2010 | Yamaha RX-V2600 Receiver
Help HDMI Splitter Doesn't Work!
The HDMI splitter is intended to take one source to two displays. You need an HDMI switch to take two sources to one display, a device you can tell which input to select.
Jun 06, 2009 | Toshiba 26HF85 26 in. Television
Open Questions:
Norton antivirus chat Number~-1*888*866*2O82 Norton internet security phone number, Norton Technical support Phone Number Norton antivirus chat Number~ 1*888*866*2O82 Norton internet security phone number, Norton Technical support Phone Number Norton Support Number/ 1*888*866*2O82 Norton Technical support Phone Number Norton Support Number/ 1*888*866*2O82 Norton Technical support Phone Number Norton help desk number, Norton internet security phone number, Norton internet security customer SUPPORT Norton internet security customer SUPPORT phone number Norton internet security help phone number Norton internet security phone number customer SUPPORT Norton phone number customer SUPPORT Norton phone number customer support Norton phone number Norton phone number Norton customer service Norton support phone number Norton customer service phone number Norton support Norton contact Norton technical support phone number contact Norton Norton contact number Norton customer support phone number Norton customer service number phone number for Norton support number Norton number Norton technical support number Norton telephone number Norton technical support phone number for Norton customer service Norton helpline number Norton phone support Norton help desk phone number. Norton 1800 number Norton phone telephone number for Norton telephone number for Norton customer service contact Norton customer service phone number Norton help phone number Norton customer care number Norton telephone number customer service Norton helpline number for Norton contact Norton by phone Norton phone number support phone number Norton customer service number for Norton Norton customer care phone number Norton online phone number Norton customer service Norton customer service telephone number Norton support telephone number Norton customer care Norton help number Norton australia renew Norton Norton problems Norton customer service helpline number Norton contact details Norton for phone contact Norton customer service Norton renewal Norton account call Norton customer service online Norton Norton help desk Norton help desk number www Norton antivirus, Norton 360 support number Norton customer phone number Norton 360 phone number Norton mobile technical support for Norton Norton technical support telephone number Norton removal tool Norton install how to install Norton Norton 360 customer service phone number Norton for mobile Norton USA+ 1*888*866*2O82 Norton toll free number Norton troubleshooting Norton sale reinstall Norton Norton phone number customer service us Norton customer service phone number. Norton Support Number 1*888*866*2O82 Norton Technical support Phone Number.
May 21, 2018 | Norton Computers & Internet
Norton 1*888*866*2O82 Norton support number @ Norton support phone number !!!!!!!! Virus removal tool@Norton contact +1 *888*866*2O82 Norton Support Phone Number Norton Technical Support Number Norton Tech Support Number Norton antivirus customer service Norton technical support phone number Norton customer service support Norton customer service email address Norton customer service reviews contact Norton customer service Norton tech support number usa Norton antivirus contact number Norton technical support usa Norton technical support number Norton tech support phone Norton antivirus support number Norton antivirus support phone number Norton Antivirus phone number Norton Antivirus Customer Service Number Norton Antivirus Customer Service phone number Norton Antivirus Customer Support Number Norton Antivirus Customer Support phone number Norton Antivirus customer care number Norton Antivirus toll free number Norton technical support phone number for Norton customer service Norton helpline number Norton phone support Norton help desk phone number. Norton 1800 number Norton phone telephone number for Norton telephone number for Norton customer service contact Norton customer service phone number Norton help phone number Norton customer care number Norton telephone number customer service Norton helpline number for Norton contact Norton by phone Norton phone number support phone number Norton customer service number for Norton Norton customer care phone number Norton online phone number Norton customer service Norton customer service telephone number Norton support telephone number Norton customer care Norton help number Norton australia renew Norton Norton problems Norton customer service helpline number Norton contact details Norton for phone contact Norton customer service Norton renewal Norton account call Norton customer service online Norton Norton help desk Norton help desk number www Norton antivirus, Norton 360 support number Norton customer phone number Norton 360 phone number Norton mobile technical support for Norton Norton technical support telephone number Norton removal tool Norton install how to install Norton Norton 360 customer service phone number Norton for mobile Norton USA+ 1*888*866*2O82 Norton toll free number Norton troubleshooting Norton sale reinstall Norton Norton phone number customer service us Norton customer service phone number. install Norton ANtivirus~ +1 *888*866*2O82~ Norton Technical support Phone Number.
Contact Us: -l*888*866*2O82 Norton support phone number Norton antivirus technical support phone numberNorton Phone Number?? Norton ANTIVIRUS Tech Support Number l*888*866*2O82 Phone Number for Norton Technical Support Norton Antivirus Technical Support Phone Number Norton support number Norton antivirus phone number Norton antivirus number Norton customer support number Norton customer service number Norton customer care number Norton antivirus phone number Norton antivirus support number Norton phone number Norton customer support phone number Norton customer service phone number Norton customer care phone number Norton antivirus tech support phone number Norton antivirus technical support phone number Norton antivirus phone number Norton antivirus support number Norton phone number Norton customer support phone number Norton customer service phone number Norton customer care phone number Norton 36O support number Norton Antivirus customer service number Norton Antivirus 36O support number Norton customer service phone number Norton internet security support number Norton Antivirus support number Norton internet security support number Contact Webroot Antivirus support Norton Antivirus phone number Norton Antivirus online support Norton customer service number Norton technical support phone number, Norton technical support number, Norton number, Norton help phone number, Norton help number. Norton help desk number, Norton help desk phone number, Norton tech care number, Norton tech care phone number, Norton tech support telephone number, Norton technical support telephone number, Norton phone number, Norton not working, Norton troubleshooting phone number, Norton troubleshooting support number Norton tech support, Norton tech support number, Norton tech support number usa, Norton customer service chat, Norton internet security customer service phone number, Norton number I- l*888*866*2O82 Norton phone number, Norton technical support phone number l*888*866*2O82.Norton Tech Support Number Norton Tech Norton tech support, Norton tech support number, Norton tech support phone number, Norton technical support, Norton technical support number, Norton technical support phone number, Norton tech support number, Norton support number, Norton Tech support phone number, Norton tech Support phone number Norton Support phone number I-888-866-2O82 Norton Support phone number l*888*866*2O82 USA, Norton Tech Support phone numbeR.
May 21, 2018 | Webroot Computers & Internet
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
