Question about Nikon Coolpix P2 Digital Camera
I have a red blinking clock that wont go away
    Master:
  • 346 Answers
Hello - It just means that your date/time has to be setup in the menu. It probably lost the time when you switched out batteries.
Turn the dial on the top of your camera to Setup and a Setup menu will appear. Go down to Date and set the date and time. when your finished move the dial back to the normal (image of camera) setting.
Thanks for using Fix Ya!
Mikeyaf
Posted on Mar 16, 2011
Replaced igniton switch on 95 fatboy and bike wont start
Hi Rob, you probably got your connections wrong, assuming your replacement switch has the same number of male spade tabs and in the same locations as the the old switch the following is the correct hookup: One o-clock tab red wire. Four o-clock tab blue wire. Five o-clock tab short red jumper wire that connects to the one o-clock tab. Seven o-clock tab short jumper red with gray stripe that connects to ten o-clock tab. Ten o-clock tab red wire gray stripe. Eleven o-clock tab red wire black stripe. If it still won't start check all your circuit breakers with test lite and if it still wont start you have a defective switch Good luck
Apr 08, 2015 | Harley Davidson Motorcycles
TV wont come on
Blinking power light indicates fault. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. These are called blinking codes. To know more about these blinking coded, visit the site. It has details about blinking codes to many brand TVs. Pull up older posts. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. http://electronicshelponline.blogspot.com/
Apr 23, 2013 | Panasonic TH-50PX75U Plasma HDTV
The red light in front blinks 14 times and wont turn on
It sounds that the standby light blinks continuously. This nidicates a short in the IIC bus [seral data - serial clock] circuit rail.
Feb 26, 2013 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I JUST PURCHASED A COOLPIX L810. THERE IS RED BLINKING CLOCK LIKE FIGURE ON THE RIGHT SIDE OF THE SCREEN. I CANNOT FIGURE OUT WHAT IT IS AND HOW TO MAKE IT GO AWAY. HELP
It's telling you that the clock hasn't been set. The "Time zone and date" command is in the Setup menu. For more details see page 88 of this manual.
Nov 21, 2012 | Nikon COOLPIX L810
What does the blinking red light mean? The
it means that you have probably blown a capacitor or 2 in the back of the set. Take the back panel off and look for the round capacitors that have a cross. If any of them are bulging, they are blown. You can order new ones at most electronic parts stores, just get all the readings off it, temp. range and farad readings. They cost less than a buck each. They need to be soldered onto the board.
Nov 19, 2009 | Philips Televison & Video
The red light on my ps3 is blinking and wont stay on
Turn off the ps3. Try reseating the hard drive. Take the cables off and then hook them back up. After this turn the ps3 back on and see if the blinking red light goes away. If it doesn't then try another hard drive in the system. If the blinking light goes away then you know you have a bad hard drive. If the blinking light does not go away then you know either the power supply or main board is bad.
Jun 29, 2009 | Sony Playstation 3 (PS3) Console
Nikon s60 blinking timer clock
You need to go into the setup menu and set the current date and time. It's just telling you it hasn't had its internal clock set (or re-set) if it has lost its clock settings.
Mar 17, 2009 | Nikon COOLPIX S60 Digital Camera
Blinking Red Lights
You need to reset the ink head shot counters and protection counter. Basically the printer has worked out that the waste ink pad is full. It often isn't. Google SSC Service Utility, install it, and select your printer and model in the lists on the tabs at the top. When it's running, turn the printer on, and right slick on the SSC Icon in your System Tray (near the clock). Reset the protection counter, and head shots counter. Perform a reset of the printer, and you should find that the problem has gone away.
Mar 14, 2009 | Epson Stylus Photo R300 InkJet Printer
Red blinking clock on nikon coolpix L4
The clock isn't set OR it's been a while since you used the cmaer OR you let it sit on low charged/dead battery for too long. Either way, update the date and time and it should go away.
May 31, 2008 | Nikon Cameras
Nikon Coolpix P2 Digital Camera Logo
76 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
