Question about LG Washing Machines
My LG Washer isn't working. The little chime that rings whenever it is turned on happens but then NOTHING else. No lights, no codes, nothing. I spin the dial but there's nothing, no noise and no lights. What do I do?
    Genius:
  • 1,075 Answers
The machine has suffered a power failure?push and hold the main power button plus another button together hold both buttons in for about 60 secounds the machine should reset.adrian.
Posted on Mar 16, 2011
Nothing happens when the 'Start Button' is pressed on Electrolux Front load washer
Good Morning friend, thank you for your post!
From my understanding your Electrolux washer is not starting no matter what buttons are pushed. This could be a possible problem with your keypad or control panel. I noticed that you have already performed a reset and that was done when you unplugged your washer for 15 minutes. I would now recommend having a technician out to perform a diagnosis. In order to do so you would need to disassemble your washer and test each component to make sure they are working properly. The technician would have the appropriate tools needed to do this accurately. If you need some assistance locating a technician you should be able to visit the manufacturer's website for additional assistance. I hope this information is helpful for you. -Matt
May 20, 2015 | Electrolux IQ-Touch Series EIFLS60LT 27"...
How do I drain my Lg Tromm Washer
open the little square panel at the front and pull out the hose. then pull out the plug or make sure the hose isn't blocked. then turn the bigger screw and the water will come out the hose
Mar 10, 2012 | LG WM2688HWM TROMM SteamWasher
The model of my LG WASHING machine is WP 750((N,R)(P) AND IT IS A TOP LOADER,THE SPIN BASKET WORKS BUT THE WASHER ISNT WORKING.
Sorry but your description of 'isn't working' has very little detail in it so I am trying 'poor water fill' first:-
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 14, 2011 | LG WFT1071TP Top Load Washer
When i try to spin my clothes the code E3 pops up
Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord.
Nov 28, 2010 | Maytag MAH8700AWM Neptune Front Load...
How do I fix my washer that only says 'sud' constantly and won't work at all? Whenever I try to start a cycle nothing happens. Whenever I push a button nothing happens. Please Help.
http://whirlpool.custhelp.com/app/answers/detail/a_id/2948
Hi please go to this above link, it is all explained at length what is going on and what to do.
This error code indicates that excessive detergent suds occurred during the cycle.
If a "Sud" or "Sd" error code is displayed, or if you can see excessive suds in the window:
There are too many suds in the washing machine. The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. See the animation below for more information.
  • If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle continue.
  • If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We lost are chime
Check to make sure you don't have anything that would impede the connection at the battery terminal
Jan 18, 2009 | Desa International White Wireless Plug In...
LG front load washer spinsense buttom does not come on
I have the LG WM3988HWA, which is a washer and dryer in one. The way it works on ours is that you press and hold the Spinsense button for 3 seconds before you start a wash, or while a wash is paused. When Spinsense is on, the LCD will say "Spinsense" on the right-hand side when the machine is running. Nothing happens with the light on the Spinsense button.
Spinsense makes a huge difference as the machine is on the second floor of our old wooden house. I don't even notice the spin cycle with Spinsense on.
Problems:
1. We need to turn it on for every load. This is just annoying.
2. Spinsense will not turn on when you've the Dryer option activated. This means we have to do two trips to the machine for each load, or have our house feel like it's shaking to pieces. There's no good reason that the Spinsense/Dryer shouldn't work.
Jun 24, 2008 | LG WM-1832C Front Load Washer
Maytag may8700aww washer with e3 code
This worked for me for the E3 error code: Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
May 05, 2008 | Maytag MAH6500 Neptune Front Loading...
Spin speed
If that light is blinking, it's because the spinssense is turned on. If you look at the lighted buttons all the way on the top right of the machine, one of them says spinsense under it. While the machine is running, press and hold that button for 3 seconds. You'll hear a little chime and the light should stop blinking. It's supposed to help vibrations on wood floors.
Oct 16, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
393 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
