Lost my easy transfer cable instructions - Computers & Internet
  • Don
    Don Mar 16, 2011
    Who manufactured the transfer cable? Smartlink?
  • 565 Answers
You don't need them. On your Windows 7 or Vista machine, click the start orb, in the "search programs and files box, type "easy transfer" and follow the directions.
Posted on Mar 16, 2011
How to transfer photos from my coolpix L20 camera to my computer? Thanks..
There are two easy ways to transfer photos.
1) Connect via a USB cable. The cable came with your camera. If you lost it, you can buy a new one on line or from Nikon. The cable has a small plug that goes to the camera and a large end that plugs into a USB port on your computer. Once the cable is connected, turn on your camera and your computer will recognize your camera's memory card just like it recognizes an external hard drive or other device. If you go to Explorer on a PC or Finder if you have a Mac, you will see it as a device. Open the device and the folder(s) it contains then copy and paste or cut and paste the jpg files from that location to a folder on your hard drive.
2) Transfer your photos directly from your SD memory card to your computer using either your computer's SD card reader or a USB external SD card reader that you can purchase on line for $20 or less. Open the battery compartment door and you will see the end of the SD card. Remove the card from the camera by pushing it in (it is spring loaded) and releasing. It will pop out. Insert the card in your card reader and your computer will recognize the card as if it were a hard drive or similar. Follow the instructions that I gave you for transferring the files above. Both methods can be simplified if you use software such as Nikon's Transfer NX.
Oct 01, 2014 | Nikon COOLPIX L20 Digital Camera
Lost the Web Camera driver disk for my Coby Snapp 3000, can't seem to find the drivers online.. Any solution?
Hello Werewolf, According to the manual here http://www.cobyusa.com/files/manuals/CAM3000_MN.pdf
You should not need any driver just plug it in a USB port and Windows will detect it
Transferring Recordings to a Computer Connect the CAM3000 to a computer with the provided USB cable to: ? Transfer files from your camcorder ? Perform basic file management functions. The USB 2.0 Hi-Speed connection makes it easy to transfer recordings quickly from the camcorder to your computer. Simply use the camcorder as you would a removable storage drive using basic operating system commands. If you need further assistance with transferring files, please refer to your operating system's instruction manual or on-screen help
Hope this answers all your questions Please remember to Rate/vote for any solution that helps you out. Leave a comment if you need more help. Thanks for using Fixya
Aug 16, 2011 | Computers & Internet
I just purchased a new laptop that has windows 7. How do I transfer my accounts and files from my old one that uses windows xp?
From the windows 7 computer, Start, Accessories,System Tools, Windows Easy Transfer. Follow the onscreen instruction. Note both system must be on the same network.
Aug 08, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Purchased a belkin easy transfer cable. When
One of the most common problems is the computer's operating system not recognizing the cable's drivers. This is most common with non-English operating systems. The quickest solution is to download the most recent driver.
If the Easy Transfer Cable isn't working properly, you can try a few things to fix the problem. Make sure that you have installed the Easy Transfer Cable drivers on your old computer with the CD that is included in the cable package. If you did not do this, close Windows Easy Transfer, insert the CD that came with the Easy Transfer Cable into your old computer, and then follow the instructions on the screen. When this is complete, begin the transfer process again.
USB ports might be another cause of the problem. When Windows Easy Transfer asks you to connect your computers with the Easy Transfer Cable, try plugging the cable into other USB ports on your computers.
A more complex problem involves the F5U409 USB PDA Adapter (The USB/Serial Portable Adapter) not installing properly. If the driver is unzipping, but the unit is not working, you need to manually update the drivers. They should all unzip to a file called F5U109 in the C: drive of your computer. Point to this file through the Device Manager to update.
Hope it helps.
Mar 21, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Using a belkin easy transfer cable with only one monitor
Hi there. You can use the same monitor for boh the computer (just consider the annoyance of having to go to computer one, do the trick, disconnecting the monitor and connecting it to computer 2 and so on). If, what you want is to extract the files from the old pc because you are going to get rid of it and want to save them, I"d suggest you get a Hard Drive External Enclosure (between 20 and 35 dollars from most places). Connect such hard drive to it and read it via USB interface (or probably E-SATA or Firewire. Depending what do you have in your computer). Hope it helps, good luck.
Jan 05, 2010 | Belkin Easy-Transfer Cable for Windows XP...
HARD DRIVE TRANSFER
go to jvc.com..instruction manual(owners and set-up)are there.RICHARDM69
Dec 07, 2008 | JVC GZ-HD7 HDD HD Camcorder - 60 GB Hard...
You need to disable any firewalls like windows firewall and the likes on both computers. Also, make sure they are on the same workgroup..
Jul 24, 2008 | Computers & Internet
Lost my usb cable
I don't know in which country you live (this is helpful to know!), but in most stores offering cameras and many offering electronic items, you should be able to procure a kit of adaptors that will include a cable to use with them.
In the US at least, Wal-Mart, Best buy, Circuit City and Radio Shack are likely sources.
Elsewhere (?) you are on your own.
Jun 17, 2008 | Praktica DCZ3.2S Digital Camera
Easy Transfer cable issue
You can download "Windows Easy Transfer" for free from Microsoft or from most manufacturers of "Easy Transfer Cables". Good luck, the software is ****.
Mar 16, 2008 | Computers & Internet
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
