Question about RCA Universal Remote Control 3-in-1 RCU-703
No puedo programar mi tv haier - RCA Universal Remote Control 3-in-1 RCU-703
VOTIT
  • 2071 Answers
SOURCE: no puedo programar el control
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
mayradiaz
  • 19 Answers
SOURCE: como puedo programar mi control
Hola mi nombre es Mayra Diaz con DISH Network. La manera m?s f?cil para programar el control de DIsh a su tele Panasonic es siguiendo estos siguientes pasos. Presione el bot?n de blanco de TV hasta que las cuatro luces se han prendido luego presione 700,734,673, siguiendo con el bot?n # localizado abajo del 9. Ahora intente subir su volumen para verificar si funciona. Los tres c?digos se tienen q tratar individualmente siguiendo los mismos pasos. Si tiene alguna otra pregunt? por favor escribanos.
Posted on Jan 15, 2011
mayradiaz
  • 19 Answers
SOURCE: Como puedo programar mi control
Hola mi nombre es Mayra Diaz con DISH Network. Con mucho gusto le puedo asistir programando su control a su televisor APEX. Lo primero que vamos a verificar es que su control tenga bater?as nuevas. Vamos a presionar el bot?n de TV es color blanco o cristalino, lo va a presionar hasta que las cuatro luces se prendan. Suelta el bot?n de tv y presiona 745, 743, 020, 731 siguiendo por el signo de numero localizado de abajo del n?mero nueve. Finalmente, trate su volumen. Recuerde presionar su bot?n de SAT para poder seguir usando las funciones de su sat?lite
Posted on Jan 21, 2011
kimberlyesco
  • 184 Answers
    Verified Fixya Pro
    SOURCE: como puedo programar el control para tv panasonic
    Hola mi nombre es Kimberly Escobar con DISH Network. Sera un placer ayudarle y proveerle la informacion que necesita para programar un control de DISH Network a su televisor Panasonic. Hay ciertos codigos que se pueden integrar al control que le permiten funcionar con la television, unos de los codigos serian los siguientes: 685, 512, 700, 765, y el 644. El procedimiento a integrarlos es el siguiente: Presione el boton de T.V localisado en la parte de arriba del control hasta que se prendan los demas en rojo una vez esto suceda ingrese uno de los codigos seguido por el signo de numero por ejemplo (700#). El boton de T.V debera ilumarce 3 veces en rojo si el codigo es compatible. Despues de esto puede intentar usar el control con su T.V. Espero esto le sirva de ayuda si tiene preguntas adicionales o necesita ayuda puede contactarme directamente a mi correo electronico kimberly.escobar@dishnetwork.com
    Kimberly Escobar
    DISH Network
    Posted on Mar 18, 2011
    kimberlyesco
    • 184 Answers
      Verified Fixya Pro
      SOURCE: como puedo programar una tv
      Hola! Mi nombre es Kimberly Escobar con DISH Network, sera un placer proveerle la informacion que necesita. Para programar el control remoto a su televisor Samsung hay ciertos codigos que puede integrar al control para que funcionen con la t.v. Los codigos para un televisor Samsung son los siguientes: 738, 516, y el 680. El procedimiento a programarlo el el siguiente: Oprima el boton de t.v localizado en la parte de arriba del control por 5 segundos hasta que todos los demas botones se iluminen rojos, una vez esten iluminados ingrese uno de los codigos seguidos por el signo de numero (#) por ejemplo 738# el boton de t.v deberia iluminarce 3 veces, despues de esto puede tratar las funciones. Si tiene preguntas adicionales puede contactarme directamente a kimberly.escobar@dishnetwork.com
      Kimberly Escobar
      DISH Network
      Posted on Aug 23, 2011
      Codigos para programar tv makna
      Hola mi nombre es Esteban tengo un televisor marca makna y tengo un control universal rm-9512 y no lo puedo programar necesito sus ayudas, escr?beme a mi correo Esteban.m.Premier89@hotmail.com o a mi watssap 18096985397
      Jun 26, 2013 | Televison & Video
      Como puedo programar una tv samsung con el control de dish
      Kimberly Escobar
      DISH Network
      Aug 07, 2011 | DISH Network IR Remote Control
      COMO PUEDO PROGRAMAR LOS CANALES DE MI TV MODELO CLC501
      como puedo programar los canales de la Craig CLC 501 TV
      Jul 17, 2011 | Craig CLC501 15 in. TV
      Como programar la segunda television
      Hola mi nombre es Mayra Diaz con DISH Nerwork con mucho gusto le puedo ayudar con su televisor numero dos. Primero tenemos que verificar que el cable que viene de la pared este localizado detr?s de su televisor. Segundo paso necesitamos verificar que el televisor este en el canal 60 o el canal 73. Si no funcionan estos pasos por favor escribanos.
      Feb 18, 2011 | DISH Network IR Remote Control
      Como puedo programar mi control de dish en la segunda tv la tv es panasonic
      Dec 13, 2010 | DISH Network IR Remote Control
      Necesito codigos para programar mi control de la caja convertidora a mi tv sylvania
      Como puedo programar un control rca con una caja convertidora proscan ?
      Sep 19, 2010 | RCA RCR450 Remote Control
      Como programarla ala tv
      Hola mi nombre es Mayra Diaz con Dish Network. Con much gusto le puedo ayudar a programar su control a su televisor. Primero que todo necesitamos saber cual es la marca de su televisor para darle los c?digos que funcionen con su televisor espec?ficamente.
      Aug 15, 2010 | DISH Network IR Remote Control
      Como programo la caja del dish
      Hola mi nombre es Mayra Diaz con DISH Network con mucho gusto le puedo ayudar a programar su caja de DISH. Si por favor me puede dar mas detalles de lo que pasa como el modelo de la caja, es un recibidor nuevo? Ya teniendo estos detalles le puedo asistir con un mejor conocimiento.
      Aug 04, 2010 | DISH Network IR Remote Control
      Como Programar mi tv Sylvania?
      tengo 1 control steren modelo RM-8000 y no puedo programarlo en mi tv sylvania. ¿que puedo hacer?
      Sep 07, 2008 | GE RM24912 Universal Remote Control
      Televison & Video Logo
      467 people viewed this question
      Top RCA Televison & Video Experts
      matt martin
      matt martin
      Computer Repairing
      Computer Repairing
      Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
