Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
How to send and recieve faxes
How do I set my fax machine to work and not intefer with my answering machine when someone is trying to call.do i set the fax,on fax only setting or fax/telephone or manual.how do i set it up to recieve and send faxes.
Thank you
  • 682 Answers
Http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_775_EN_86.PDF
Posted on Aug 03, 2008
Hoe do I set up fax functions on Canon Pixma MX452
My incoming fax issue was resolved when I enabled the answering machine function on my phone. All this time my answering machine was turned off. I have yet to send a fax. My model is the Canon Pixma MX452.
Apr 05, 2013 | Canon PIXMA Office Equipment & Supplies
Sharp plain paper ink jet fax ux-b750
to stop the fax automatically switching to fax mode you have to set it to manual to recieve calls and dissable the fax,there should be an auto/fax and call mode, therefore when someone calls it will go to your voicemail, but that means that you will not be able to recieve a fax. Normally auto mode, will first try the fax, if no fax is recognised it will switch to normal line ringer, then if no answer it should go to your voicemail if unanswered.
Oct 01, 2007 | Office Equipment & Supplies
When someone is trying to fax us, it says on their side that it went through but we hear no dial tone and do not recieve any faxes. What can we do to try to fix this? We have to have our fax working as...
Well first thing is to call your own fax machine from a telephone at your location and make sure that it rings and answers....you should hear the tones in the earpiece of the phone you are calling from. If that works, go to your fax and try to make a "copy" on it to make sure it actually prints onto paper. Then get someone locally with a fax machine to send you a fax...make sure your machine answers and then prints the page out. If it wont print the pages out are the pages going into memory???? Maybe your machine is asking for toner or a drum???
Sep 09, 2010 | Office Equipment & Supplies
Fax machine answering phone calls
On the keypad of the machine there is a choice for settings. You need to go into menu and scroll through to Fax Setup menu. ON this menu you will scroll through to AUTO ANSWER and it will give you the option of OFF or ON. YOu need to turn it to OFF. This means that if you want to recieve fax you will need to manually press start on machine when someone calls to send you one. Turning autoanswer on or off wont affect your ability to send faxes.
Jun 28, 2010 | Canon MX300 Office All-In-One Printer
Fax machine
You need to set the machine up to AutoAnswer as follows per HP:
Receiving faxes automatically If the Auto Answer option is set to On , the unit automatically answers incoming calls and receives faxes after the number of rings specified by the Rings to Answer setting. Press Auto Answer to turn on the Auto Answer option. 1: Setting the Auto Answer option
  1. 1 - Auto Answer button
    NOTE: The Auto Answer button is lit when the Auto Answer option is turned on.
  2. Press Auto Answer again to turn off the Auto Answer option.
Dec 30, 2008 | HP Officejet 6310 All-In-One InkJet...
I bought a Canon product : PIXMA MX 310 on the 27 th october 2008. DMO - ISRAEL sold me the unit. I can't use the FAX - the recieving system doesn't work. I have an answering machine on the tel....
your answering machine is probably picking up the calls before the fax try to use a separate number for the fax or just disconnect the answering machine and get someone to send a test fax to see if it works
Nov 16, 2008 | Canon Office Equipment & Supplies
Phone works fax won't
my fax not recieve faxes.
Apr 13, 2008 | HP 640 Inkjet Fax Machine
Lexmark printer 8350
Okay for starters, you need to check to see if that fax machine is automatically answering the phone when it rings. you can check to see if it is trying to recieve by call that phone number from another phone and listen if it answers and when it does, does it make a high pitched squelling sound that varies in pitch.
if it does then it should be working ok, if not then you must program your recieve mode to automatically answer.
you can also check to see if it's sending by doing the opposite: put a sheet of paper in the machine to fax and dial your cell phone or other number, when it rings pick it up and listen for the high pitch squeel, if it works then your fax is working properly.
Thank You,
Mikey
Apr 04, 2008 | Office Equipment & Supplies
Cannot recieve faxes
you need to watch during ringing period need to click ok or press what ever message says.
Dec 03, 2007 | Lexmark X5150 All-In-One InkJet Printer
Fax will not recieve
DR mode means that Distinctive Ring is set to on which will force your fax machine to manual receive. Turn DR off and you can set it to whatever mode you want.
Nov 03, 2007 | Brother FAX-575 Plain Paper Thermal
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
148 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
