Where Can I find a wiring Diagram on the Cushman GA 60 ? The machine won't start. I am told that a Brake Bypass connector needs to be used. Since i do not have one , what pins can be jumpered to allow for starting?
  • 30 Answers
Maybe this? http://www.vintagegolfcartparts.com/cgi-bin/gallery/gallery.cgi?Category=100012
Posted on Mar 16, 2011
Cushman 36 v wiring diagram town & fairway 881858
Contact Cushman directly to request the wiring diagram.
May 30, 2017 | Golf
I need help to find a wire diagram for my Cushman struckter #898474 gas
This might help?
http://www.vintagegolfcartparts.com/gallery/categories/Cushman/Cushman_Wiring_Diagrams/media/CushmanGolfsterModel735.jpg
Sep 09, 2014 | RTO Automatic Transmission And Engine Oil...
Need a schematic that shows what eachof the colors of wires should be connected to on a 7 blade RV plug in receptacle.
Click to Enlarge
Question:
trailer connector wireing diagram. need to know which color wire go to which post.
asked by: Joann
Expert Reply:
When wiring a trailer connector, it is best to wire by function, as wire colors can vary. We have an excellent wiring diagram on our website, I will provide you a link so you can look at it.
If you are looking at the inside of the trailer connector where the wires mount to the terminals starting at the notch at the top and working clockwise:
1:00 is Black and 12 volt power
3:00 is Green and Right Turn and Brake
5:00 is Blue and Brake Controller
7:00 is White and Ground
9:00 is Yellow and Left Turn and Brake
11:00 is Brown and Tail and Running Lights
Center is Purple and is Optional Reverse
I recommend using a circuit tester like part # 40376 to verify your connections.
Sep 12, 2013 | 2005 Dodge Ram 2500 Truck
Installed a brake controller and the green light won't go on. I am told I need to add a fuse where is the fuse box to add the fuse so that the system recognizes the brake controller in a 2002 Eddie...
Hi, this may true if you connected the trailer brake to the connector on the factory wiring harness. There are several fuses that are needed for trailer towing. In the box by the battery, fuses 13, 25, 27, 53, and 54 are needed. You will need a relay in relay slot 19 for the trailer running lights, a relay in relay slot 20 to charge the trailer emergency battery; and, if your trailer has backup lights (6 or 7 wire connector), you will also need a relay in the relay slot 15. If you did not use the factory connector for your trailer brake controller, check to make sure you have connected the controller to an appropriate power source in the truck. Please let me know if you have questions, and thanks for using FixYa.
Jun 22, 2011 | Ford Explorer Cars & Trucks
Find wiring diagram
Hello! A toggle switch with brake wire on one side and ground on the other will work just fine...However you have the option of permanently grounding the wire...I would suggest using the switch...
Guru..............Saailer
Jun 02, 2010 | XO Vision XOD1760BT Car Video Player
Cables not connected for power, hdd light another
http://www.tomshardware.com/forum/261599-30-8istx-wiring-power-switch
Jul 23, 2009 | Intel D845GVSR Motherboard
I need a wiring diagram for a 2001 ford f150 trailer hitch plug in. i got a new heavy duty trailer connector and i need to know the color code of the wires
Hey Bryan
I've got them for Six and Four wire plugs
Six wire plugs:
Horse, stock or utility trailers:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
May 02, 2009 | 2001 Ford F150 Styleside SuperCrew
INSALLING A MOTHERBOARD
From what little information I could find, your motherboard does NOT provide a CD_IN connector. ONLY the GA-PCV2-DVI version provides the connector you're looking for, while the GA-PCV2-DSI version of the m'board (the one you own) does NOT have the CD_IN connector... wish I had better news than that for you...
Just FYI, you can download a LARGE file (~55MB), which contains ALL of the drivers AND the m'board manual in .ZIP format directly from here:
http://www.idot.com.tw/en/downloads/MB-PC1000G1500G(GA-PCV2)/V1.0CD.zip
It took about 17 minutes to download that entire file to my HDD, over a broadband connection, so I can only guess that the server is restricting download speeds...
Once you download that file, you can unzip it and locate the manual (in .PDF format), which is the "PCV2_Series.pdf" file...
In the manual, you will find the information I've provided here on page 12, so you can verify what I've told you...
Good luck; I suspect you'll have to install a compatible soundcard with a CD-IN connector if you really want one...
Jan 28, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
388 people viewed this question
David Payne
David Payne
