Question about Samsung SCX-6345N Laser Printer
Code reset toner photocopy scx6345n - Samsung SCX-6345N Laser Printer
How can I solve Toshiba e studio 257 photocopier toner problem?
Try turning the main power switch off or disconnect the power, wait 20 seconds then turn back on again. This should reset the toner.
Aug 29, 2016 | Toshiba Office Equipment & Supplies
How do i fix toner stain on printout and photocopies? please what might be the cause of the dot stains?
There are several reasons for stains on a Laser printer or photocopier
1. Clean all rollers. Fuser; transfer and pickup.
2. Ensure the toner is clean from outside.
3. Hope the Toner is not refilled and Is not leaking.
4. Clean paper path.
Mar 08, 2016 | Office Equipment & Supplies
HOW DO I RESET WHEN adding a new toner cartridge
There is nothing to reset the toner will load itself unless there is another problem. Make sure the insert plug from the old bottle came out before you placed the new bottle in.
Jun 11, 2015 | Ricoh Aficio Mp161 Copier Photocopier Copy...
Error code F2-40 in Sharp mx m314n photocopier
using third party toner or drum replace toner and drum with OEM
Jun 04, 2015 | Sharp MX-M314N Copier
Canon iR 3220n colour photocopier error code E000020-0481
The path between the sub hooper and the developing assembly is clogged with toner.may be a developing assy.toner sensor failure,or the sub hooper toner sensor
Jan 23, 2015 | Canon Office Equipment & Supplies
My photocopy machine shows code C0070
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad. Reset open close front door WHAT MODEL IS THIS MACHINE?
May 24, 2012 | Minolta Office Equipment & Supplies
How do i reset my printer? it always shows a LOW TONER, even though it was newly refilled. There is also a vertical line that appears on the side everytime I copy something (photocopy).
Step 1: Toner Reset Menu for Brother HL 3040CN and HL 3070CW
1. Open Cover where you can access toner cartridges
2. Press CANCEL & SECURE PRINT buttons at the same time and you'll see
the toner menus on the screen
3. Press + or - to navigate through to the toners you need to reset.
Note that each toner has 2 entries here, reset them both (STD means Standard, STR means Starter)
4. The OK button will reset of the toners.
Apr 18, 2011 | Brother DCP 9010CN - multifunction ( /...
How to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
Jun 02, 2009 | Sharp AR-M237 Copier
U2 fault on Sharp AR-206
Error code U2 in Sharp copier AR 206 shows error or failure of toner crimp you can try to solve by replacing toner crimp
Or by reseting the error code by fallowing procedure
press c intrrupt 0 ( zero ) intrrupt contoneously after pressing all the light on control will go off then press 16 then press start switch
your prob will 100% solve.
if any more prob pl inform
May 20, 2009 | Sharp Office Equipment & Supplies
How to Solve Error code SC496 for Aficio 551
hello Sir; You have to empty the waste toner bottle it located right hand side bottom, open the doorlook at "A" area you will see a big narrow plastic bottle pull out a black buckle slide out the bottle, dump the toner,the code will be disappear!
Jan 06, 2009 | Ricoh Aficio 450 Copier
Samsung SCX-6345N Laser Printer Logo
161 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
