Question about Philips Magnavox 9P6034C 60" Rear Projection Television
We have a Phillips 60L9200D/37 television. It is extremely dim in brightness, even though we have everything as high as it will go. We have to have all curtains closed and lights off to view it properly. Help please!!!
    Problem Solver:
  • 10 Answers
It could be that your bulb is going bad or you have a problem with your white generator.
Posted on Mar 16, 2011
Driver side headlight goes dim on high beam while passenger side is bright
bad connection or bad earth check all connection or bulb
Jan 24, 2016 | Cars & Trucks
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
RCA 46
If a LCD either a problem related to the back lights if used or a problem on the digital control (main board) and in either case not a do it yourself fix.
Apr 22, 2012 | RCA L46WD22 Television
I HAVE A PHILLIPS 37 PFL5522D THAT HAS A VERY DARK PICTURE CAN YOU ADVISE
if picture is still veiwable but dark, try to do some menu adjustment in contast, brightness. picture temp. if still dark or dim the problem maybe is the power supply filtering capacitors. worst is the t-con assembly.
Feb 25, 2011 | Philips Televison & Video
Red and blue colors are extremely bright almost neon bright, while everything else is very dim how do i fix it?
Thats strange. You could talk to someone in a shop or you could contact Nintendo
Nov 22, 2010 | Nintendo Wii Console
Digital clock display read out is EXTREMELY dim even after adjusting brightness and contrast controls
Hello Jinx55,
the problem is the display unit itself or the cable that goes from the display to the electronic (Most likely the dispaly itself).
The display will need to be replaced. You can contact Miele directly at
(800) 843-7231
May 19, 2009 | Miele Coffee System
Phillips 52 in big screen screen has a red tinge other colors come though but not very bright
Replace the coolant in the CRts a very common problem with phillips. The colors will get very dim and red will become domintae as red seldom needs replacement where as blue and green get congealed and the set will get dim hard to focus and you will see a glowing around green and blue objects. Heres a link to the coolant kit for a phillips which contains the replacement coolant and step by step instructions on CD with pictures on how to replace the coolant.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
May 06, 2009 | Televison & Video
Ford Ranger 2002, electrical problem
You have a bad ground, look out by the battery for a bunch of black wires screwed to the body of the car, check that they have a clean and tight connection, scrap off any paint under the wires.
Nov 25, 2008 | 2002 Ford Ranger Regular Cab
Bright white horizontal stripes - Symphonic 27
YOUR brightness on the high voltage block is too high...turn it down
Dec 02, 2007 | Televison & Video
Philips 17pf8946/37 has no video
Phillips LCD TV 17PF8946/37, has no picture at all on the screen, even menu and channel #s not showing in the screen. The screen just have blue color. Everything is working like switch & video. Please let me know what parts need to be replaced and where can I order the parts.
Nov 15, 2007 | Televison & Video
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
